Hey, funkflix, I have just updated CBId 8.21 for you. Now it estimates a QuantiSpeed performance rating and correctly reports processor’s code name. Thanks for the cooperation! See you later!
I'm not sure why anyone would call the M2N-SLI a bad overclocker. bachus_anonym was able to hit a 400HTT here:
http://www.xtremesystems.org/forums/...d.php?t=102595
In any case, I had reported some voltage observations in that thread. Now that I have made some measurements with a better multimeter, these are my most current observations:
1) The vcore runs slightly higher (.02-03v) than what it is set at in BIOS
2) PCProbe reports about .05v higher than actual measured vcore
3) 3rd party utils report about .15v lower than actual measured vcore
4) The BIOS automatically overrides vcore to add .1v when FSB is set greater than 250
Thx mate, i will take a look at it tomorrow. :) :toast:Quote:
Originally Posted by VVJ
I wrote a email to asus bcs. of that problem, let's see what they will answer.Quote:
Originally Posted by bzo
If u set ur Vcore to Auto in Bios, what voltage is shows to u with DMM/PcProbe? (need to know the defualt voltage of ur cpu too)
Thx in adavnce! :)
Any news so far?!
Can you tell my whats the default C&Q Vcore of this chips if the stock is 1,2?
I sold the system. :(
