I feel tired just looking at all of that work. :p:
'grats on the work and the dedication to go with it.
crazy cool case i love it
Dude thats totally extreme worthy nice work man !!!!!!!!!!
i like the paint work and the polishing videos
Your Case is Great :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: great job man!:clap:
wow mortal... You've got almost the exact same setup I just ordered :) And you're sXe and you're an Anthony Green fan! :eek: a IKTPQ fan too? I think we're somehow realated.. or maybe you are me in some other dimension? ;) haha :p:
"smoke's filled the air and I'm struggling to breathe"
NysoO: Awsome job you're doing there :shocked: The paint work is near perfect and the design is stellar! I'll be posting a worklog of my own case design and build soon :)
Keep up the good work and keep those pics comming! :up:
*subscribed*
is it finish yet?? :D
very nice worklog.. :)
ZZup, the project is actually starting to run to the end. Most of the design and modification is done. But this is todays update.
Got some critics on how the front fan would get air, so sawed out a hole in the front door and put on some c-strip. In the same time I painted the inside of the door black.
http://bandwidth.se/images/1227
From the beginning I was thinking about mounting the rad on the outside, therefor I got a ugly hole for the radiatorhose. So, made a aluplate that i mounted with insexscrews.
http://bandwidth.se/images/1228
New angle :)
http://bandwidth.se/images/1229
http://bandwidth.se/images/1230
Shine
http://bandwidth.se/images/1231
Pictures really can't give the real-life experience. The clearcoat and the polish
doesn't have its real depth.
http://bandwidth.se/images/1232
The things that are left to do.
Hole on the top for the fillport.
Soldering on a 4-pin molex for the frontdoor leds.
Mounting the glass in the sidedoor.
Make holes for the sidedoor thumbscrews.
//NysoO
woohoo Hardware PRON!
finally an update for this awesome project
keep up the good work
do you have another worklog somewhere else? Like sweclockers or something?
Did some finnishing stuff.
Soldered on a 4-pin molex on the electricalcables to the front LED's.
http://bandwidth.se/images/1238
I also soldered on a connector for the startbutton
http://bandwidth.se/images/1239
Drilled a 25mm hole and mounted the fillport. It was actually kind of nervwrecking as I have done so much job one the case, so, just a little mistake would be a disaster, but I took my time and it came out nice :)
http://bandwidth.se/images/1240
Mounted the glass.
http://bandwidth.se/images/1241
Saw that someone polished his fillport, so did the same thing. Looks nice I think :)
http://bandwidth.se/images/1242
just SICK!! KEEP US POSTED! :clap:
your polish needs more compound. its not smooth enough .
if you have time, you can always 1500grit wetsand it
clearcoat it at least 3 layers to get it thick enough
then 1500>3000grit wetsand, then orbital buff it.
only problem with this is that. its a steel case?
you gotta sand it all times its smoother then smooth. or else grooves show up after clear drys and hardens
That Fill port looks absolutely awesome !!!!
Thumbs UP !!
The last watercooling components arrived.
Ek fullcoverblock plus delrin anyone?
http://bandwidth.se/images/1695
http://bandwidth.se/images/1696
http://bandwidth.se/images/1697
Swiftech Apogee GTX
http://bandwidth.se/images/1698
Flat?
http://bandwidth.se/images/1699
no algaes in my loop, with this PT nook :D
http://bandwidth.se/images/1700
The graphicscard and motherboard arrived today :)
Asus blitz formula SE
http://www.bandwidth.se/images/1705
http://www.bandwidth.se/images/1706
http://www.bandwidth.se/images/1707
http://www.bandwidth.se/images/1708
http://www.bandwidth.se/images/1709
And XFX 8800Ultra :)
http://www.bandwidth.se/images/1710
Nice gear! Maybe some NB/mosfet/??? waterblocks too? :D
update!!!!!
AndM: Thanks! I think I'll go with the motherboard as it is though :)
disruptfarm: It will come soon enough :)
Very nice work indeed :)
You have a lot of potential keep up the good work ;)
subscribed
Oh man that is a nice project... thank you for getting good parts to go with your case... i have seen too many nice cases with crappy internals which just don't do them justice.
very nice hardware im almost jealous :D
I wish someone would give this guy a job. He is too talented to not go into PC design......
:up: :cool: :up:
love this computer great work highly detailed!!!
Hopefully ill have a cube mod in here soon!!!!!.......
