I just installed the latest Bios from MSI and it ran right of the boxQuote:
Thanks;Quote:
Originally Posted by nn_step
I will receive this board in a few days:
http://www.newegg.com/Product/Produc...82E16813128020
for my backup and storage system. I was planning on just putting an old single core chip in there. But now, the 65nm chips' prices are so low, I might be changing my mind.
So what do you think are the chances of getting a brisbane in there and booting up?
probably pretty good, though isn't that board an overkill for personal backup and storage?Quote:
Well, I guess it can be a little overkill; but I'm getting it as part of a trade.Quote:
And the storage I'm refering to is going to be pretty hefty, probably with two SCSI controllers (PCI, speed is not paramout with these), one with RAID5, and possibly another PCIe SATA controller.
umm you do realize that SATA storage is a good deal cheaper than SCSI right?Quote:
And since it is just backup and speed isn't the highest requirement (since you be limited by Ethernet speeds) you could get away with EL Cheapo software raid
Yeah, I realize that.Quote:
But I guess for me, good reliablity of the RAID controller would be important in handling certain critical data that I need to make sure to keep; I may need to run RAID with some hot spares. And dual Gbit ethernet definitely helps too.
so, where's the results?
what exactly type of results are you looking for?Quote:
Originally Posted by flclisgreat
He said tomorrow, I wanna see this thing @ like 3.2 on air.. possibly more..
I want to see 3.4 on water & 1.5v haha
Soooo, are they coldbugged? ;)
NN_Step I would like to see results from Cinebench x64, WinRAR compression, PCMark5 and if you have time then pls try to boot OS @1.9GHz/0.9V ;) (CPU-Z screen would be awesome).
Fastest SuperPi 1M & 32M run please.Quote:
Super PI is kinda useless "benchmark".We need Cinebench x64 and Winrar.Also what MSI mobo is nn using with this baby?Quote:
Originally Posted by oicurafox2000
For "you" perhaps its worthless,but its what I'm interested in,so thanks for your opinion,but its just that "your opinion".Quote:
Originally Posted by informal
i want to see 4 ghz with dry ice or LN:DQuote:
Originally Posted by mAJORD
Well i meant it means almost nothing to the real world perf. Don't get upset:),i'm sure nn will post SPi results.We know how K8 performs in this synthetic test by now.It may be interesting to see the effect of L2 added latency of 2 cycles (compared to WIndsor).It might affect the results in Spi in 1-3% range.Quote:
Thus far only 3.05Ghz with 1.5v, I'm gonna up it to 1.65v and see what it doesQuote:
Originally Posted by Solarfall
Do you have any sophisticated cooling like water/fridge/winter outside your room?? ;)
http://www.amdzone.com/modules.php?o...tid=282&page=2
3600+ @ 3.1ghz stock cooling. not bad :) :)
nope but I have 8C ambient or -18C ambient outside ;)Quote:
Originally Posted by Lightman
No, but he has a starcruiser that he can hop in when he wants. He'll just have to fly to the ice planet Hoth and bench there with the beasties...Quote:
:rolleyes:
I expected better OC results. :(
Mine does 2.85ghz (300x9.5) on 1.35v. I havent tried higher because my BIOS is having temp issues, says its at 60c (its obviously not, HSF Is cool to touch) so I dont wanna hurt my little cpu just yet.
Right now im running 290x9.5 @ 1.325v 24/7
As long as dual mprime runs stable you can't damage the CPU. It is unstable from heat much earlier than it breaks from heat.Quote:
Originally Posted by Dillusion
Just watch mprime and tune the box down when mprime complains or crashes.
