You think the chipset is very hot ?:confused:
http://images.anandtech.com/graphs/d...1222/13738.pngQuote:
Originally Posted by kosmonova
i think not ;)
komonova means CQuote:
look at the screenshot's 58-67-73C Chipset Temperature.. :confused:
Power consumption has nothing to do with chipset temperature. There are much more components on board, not just socket and chipset.Quote:
Originally Posted by somwhere_there
i think it has something do do with it, but its not the full story.
look at the 680sli - high power consumption and hot temperatures.
i think its the same with nf4, e.g.
but regarding the price which will be around 250€, dfi could have installed a better chipset cooler, something semiactive like asus did it on the p5w dh which is even cheaper:slapass:
seems to bee a good board with an insane bios for an insane price
yesQuote:
Originally Posted by Kasparz
73C it's very HOT! :nono:
Originally Posted by musashi01
MSRP is $220... thats not too high for a breand new board IMO. Especially with a featureset like this one.
not only that, the chipset is brand spanking new as well, im sure the price will go down in a while.
these are some good news, you got a source?Quote:
Originally Posted by Revv23
220$ would be something around 175€ - i doubt the baoard woill be that cheap here but... it would bei nice:rolleyes:
True but Xtreme cooling + non XE cpu desperately needs > 550 fsb :)Quote:
Originally Posted by kiwi
Then stay on P5B. Why invest in LN2 is you cant afford a high multi cpu?
This thing with mods should hit 530 or so, thats not so bad at all... only e6300 users need to worry, but even so 500fsb is 3.6ghz...
well said, people have to start accepting this..
regards
Raja
I've given up on trying to discuss the value of this board's 511FSB & memory clocking potenitial. I rather hope people pass on it. It increase's my chances of getting one the first week they come out.:)Quote:
Originally Posted by raju
I bench only DI which is rather cheap :)Quote:
As for LN2/DI and lower multi cpus, it is not just money, it's fun getting lower binned cpus higher than XE :)
QFT! :toast:Quote:
Well if its all about FSB to you then obviously 965 is your only choice, no other chipset even has a chance at seeing 600mhz.
Looks awesome indeed. Kinda makes me wanna get back into benching.
funny to see an ATi/AMD chipset with an Intel CPU, especially on the box.
sorry about previous post - my bad :slap:Quote:
Originally Posted by Atrin
made some conclusions based upon power consumption without knowing subject (2x :slap: )
but what about that high temperature - 73C :eek: it's just a bad stock cooling for chip or some deeper issues?
See http://www.xtremesystems.org/forums/...&postcount=906Quote:
Originally Posted by qdemn7
thanks :toast:
thx :toast:Quote:
If I get this mobo 1st change will be Swiftech MCX159 Northbridge Cooler
plan using above with Thermalright Ultra 120 & 38mm Fan
Think that will help improve cooling.
BSQuote:
it's 3.5GHz on an e6300
learn math
Originally Posted by xlink
pretty rude. my argument still stands. :slap:
Pictures of board’s detail.
http://img204.imageshack.us/img204/9...x320015sy2.jpg
http://img66.imageshack.us/img66/3994/icfx320016rn4.jpg
http://img65.imageshack.us/img65/5117/icfx320017nd0.jpg
The lab test system details
CPU: INTEL Core 2 Extreme X6800
MB: DFI LANParty UT ICFX3200 T2R/G
DRAM:CORSAIR Dominator TWIN2X2048-8888C4DF
VGA:Nvidia 8800GTX
HD:Seagate 7200.10 320GB
POWER:Corsair HX620W Modular Power Supply
Cooler:TT Sonic Tower
http://img66.imageshack.us/img66/1804/icfx320014gk0.jpg
Used X6800 series multiplier crack, can keep the processor uprise even
after x11.
http://img65.imageshack.us/img65/2002/rd60013xqa1.png
8800GTX the default 576/900 MHz
3DMark2003
In an environment likes 680i, it runs 10% lower
http://img66.imageshack.us/img66/2692/rd6002003hz7.png
3DMark2005
In an environment likes 680i, RD600 runs almost the same to it.
http://img66.imageshack.us/img66/6407/rd6002005aj6.png
3DMark2006
http://img66.imageshack.us/img66/9113/rd6002006qm8.png
About the 3D rendering, RD600’s performance is quite good. It equipped with
the highest model of NVIDIA~8800GTX. Only 3DMark2003 was performed so-
so. The result of other 2 like: 05/ 06, were the same to NVIDIA’s 680i. Hope
that NVIDIA has a better driver of 8800GTX for RD600 to improve the
performance in 3DMark03.
FSB part:
Not long ago, the highest FSB of Intel platform that I tested is
ASUS P5B-Deluxe
My first X6800, which tested with P5B-Deluxe, was worked steady
at highest FSB497. But the result of DFI’s RD600, worked steady at FSB520.
http://img66.imageshack.us/img66/3653/rd600520cd6.png
My second CPU, E6300 gained highest FSB470 and worked steady
(no matter how high the voltage I increase).
The highest FSB of RD600 is 485. This’s worked steady too.
(the same E6300, also no matter how hard I increase the voltage,
it just can’t push the FSB a little higher.
I think it must about the physical limitation of CPU itself)
http://img66.imageshack.us/img66/14/rd600e63fd2.png
At last, the DDRII settings of RD600 are totally free for user to adjust.
Not necessary to accord with the FSB ratio.
CPU:500X7=>3500Mhz
DRAM: DDRII 1200 CL4 4-4-9 2T
(rest of some minor parameters are so tight)
2.35V, a single Super PI 32M finished
http://img214.imageshack.us/img214/7...1200pistl2.png
2.38V double Super PI 32M finished
http://img65.imageshack.us/img65/355...1200pidix9.png
Although, I’m not test this board very detail.
But I’d like to make a initial comments of 1st part test.
Merits
1.BIOS options and settings are various and comprehensive
2.Built-in total 8 x SATAII ports and the 3rd PCIe~ physics card,
expansibility is really high
3.The performance of FSB is excellent; almost can compares to Intel’s chipset.
4.Memory adopts an “open-structure” for users to tweak.
You can tweak how fast you want the DDRII to be.
Not limited by CPU FSB ratio anymore.
5.The board adopts some good features like: 6-phrase digital PWM,
Dual gigabit LAN, Debug light and on board power/ reset buttons.
Rich features!
Things need to be improved:
1.Price of RD600 is as high as 680i, hope there will be a new cheaper version
that built without Promise RAID chip.
2.If the in-box bundles and package can be improve next time, it’ll be great.
3.The north bridge and areas around should have a better cooling solution,
especially when FSB overclocked more than 500.
4.The BIOS sometimes show a incorrect clocking, when FSB is overclocked.
Although, RD600 is the last chipset that ATI designs for Intel platform.
But DFI still tried their best to make it perfect as a LANParty series product.
A highest FSB and the high “tweak-ability” of memory settings are the
biggest merit of the board’s itself. Moreover, some of the setting and
performance are even better than 965/ 975 and 680i chipset.
If some minors issue that I mentioned about can be improved, I think
LANParty ICFX3200-T2R is the best choice of all Intel platforms.
windwithme will test two in-coming products:
Performance and Overclock
7900GS Phoenix version
http://img204.imageshack.us/img204/3...x320019bv7.jpg
The mid-range motherboards of Intel’s platform
MSI P6N SLI Platinum
http://img204.imageshack.us/img204/4...x320018on3.jpg
