Damn it must be such a nightmare building a cascade like that, and then finding you have problems and it needs taking apart :(.
it is a pain for sureQuote:
Originally Posted by Brettbeck
well got the unit working and stable after fitting the new temprite 900 oil sep gased the 2nd with R507 and ran it for an hour just to make sure all the oil had returned back to the compressor
then vaced it down and regased with R23
just had the unit running for 2 hours without load on the evap just to make sure that all temps and pressures would sit stable before i moved it over to the bench
and hooked it up to the QX6700
load testing tomorrow now
some picks
http://www.benchtec.co.uk/1/cascade4/1/4/DSC00498.jpg
best unloaded temp
http://www.benchtec.co.uk/1/cascade4/1/4/DSC00496.jpg
i did not have the time to try in the end as i want to do some benching before this ln2 evaps from last week:)Quote:
Originally Posted by SoddemFX
i have a pot reay to go on a 8800gtx
Hey Baz, wher'd you get LN2 from in the UK :confused: ?Quote:
Originally Posted by bazx
Nice to see your cascade up and running properly :D!
B.O.CQuote:
You mean the huge 240+ litre tanks? Or do they actually let you buy smaller quantities?
hehe 50L hereQuote:
http://www.benchtec.co.uk/1/ln2/ln2.jpg
Isn't that a 25litre dewar :p:? I could swear I saw that on eBay a while ago!
Rofl at some of those pictures baz, I liked the saussage roll experiment :D!
Great work, build it not only functional but make it look NOT like a crows nest and build it safe,all stages that require safety devices, You and your customer will both sleep better at night. Sign your work as a painter signs his creations. Be proud of a job well done.
Walt
i was looking at this unit last night and thought it could
do with finising off
things left
fit the case to the 3rd stage
fit an extractor fan to the 1st and 2nd stage same as the one below make up safty guard
fit switches/tempdisplay/gauge to the front pannel
new things
a water cooled DSH to the first stage same as the one on cascade 5
change refrigerant from R507/R23/R1150
to R507/R1150/R1150
here is the top case still with its cover
http://www.benchtec.co.uk/1/cascade4...3/IMGP0015.jpg
http://www.benchtec.co.uk/1/cascade4...3/IMGP0016.jpg
that is a very nice cascae there baxz, cant wait till tomorrow with QX6700 benching ;) good luck
hehe thanks
just fitted the case and i wish i had done it earlier now
just got to make up the water cooled de-superheater coil for the first stage
after looking how tight it is for space in there i will be mounting it in the top case
http://www.benchtec.co.uk/1/cascade4...3/DSC00818.jpg
That's one impressive unit! Keep it up!
thanks clash:)
just made up the water cooled de-superheater coil 1/4 in 1/2 and fitted it
was quite tricky getting it in
just need to vac down and re gas
http://www.benchtec.co.uk/1/cascade4...r/DSC00822.jpg
A master piece, i shall be finishing mine when i return from holiday in 2weeks Baz. Seeing this just makes me all excited.
:drool:
Me want case.
Well not much on build l8ly due to work but it will start again now i have paid off 2 holidays. Its finished but 1st compressor is shabby. :shakes:
I would have certainly come along with paul sunday if i was here, a lads holiday taking 1st priority :yepp:
Again nice build mate and once mine and pauls cascade is done im sure ill be ing seeing you ;)
Dave
