If the temps are rising a bit, it seems to work, so there must be some kind of a barrier on 20-21°C for one core?! Now on 23/27°C and it is working flawless. :)
How did you get cpu % working?
Found the bug! thanks. I will get you a new build of the driver tonight when I can compile it and email it to you. :)Quote:
Originally Posted by funkflix
-FCG
It's gone back to reading both Core No. 2 (CPU 1) temps now
So, let me make sure that I understand this. It was correctly updating the temperatures for both cores....and they were two distinct values. And then it just changed over to only displaying temps for one core on both sensors? Did you change ANYTHING? Reboot? Does it revert? Did you open another program that may be accessing the same registers? This is my most elusive "bug" although I'm not sure if I can do anything the fix this (although I really hope these is some explaination to it).Quote:
-FCG
Don't think I did anything to affect it
I tried reapplying the most recent you emailed me and same thing
Have you tried a simple reboot? I really need to track this down...
I reinstalled MBM and the patch 2 from scratch and it's working again :D
So final should be pretty soon I guess :)
oh no wait a second, it's stopped working again.. :stick:
that's at least a clue....it tells me that the problem most likely lies in how I am accessing MBM5 shared memory for writing. I have an idea. Stand by, Larry. New DLL and SYS files coming this evening. ;)Quote:
-FCG
Cool, btw can you try making the plugin use sensors 27 and onwards or something
because the nvidia plugin uses sensors 25 and 26 :(
The highest supported number is Sensor 32. So if I want at least 8 contiguous sensors (really, 16 in case someone decides to get cute and run a quad Clovertown setup) that I would need to go, say, Sensor 9 through Sensor 24. I don't think anyone uses Sensor 9 now so that should be safe. I will include this change in the next build that I send you, Larry.Quote:
-FCG
Nice one, cheers bro
edit: or I could send you the nv plugin and you could modify it for me to use sensor 20 and 21? I got no clue how to do it.. :-p
i will test later on a clean OS with only mbm instaled, that i used to make it work for p5b dlx, ill see if i can get two different temps since for me it always showed only core#1. ill install/reinstall with patch or without to see if i can find some pattern
that would be great. please do. i will email you the latest build.Quote:
Originally Posted by Millyons
Same thing dude, Core 1 is being duplicated to Core 0 :(
But atleast it no longer conflicts with nv plugin :thumbsup:
http://img392.imageshack.us/img392/1...empmbm5pp2.png
edit: haha woops the coretemp was showing 59/60 right before I pressed print screen, but believe me, it's reading just Core 1 haha woops :slap:
email coming your way, aslong as it doesn't get rejected by your companies webmaster thing this time.
Thanks for ur email, but now it is always on 0/0°C! :(Quote:
Originally Posted by freecableguy
Change to Sensor 9 and 10 :)Quote:
Hehe, thanks mate, did not read the readme.. ;) Works "perfect" now!Quote:
Are there any configs for the other senors on P5B?
Can you post some screenshots? :)Quote:
and have you tried:
http://www.xtremesystems.org/forums/...d.php?t=125201
Thanks for the link, but how i get this update working? :confused: I installed it, but do not find anything to get it working?!Quote:
Screenshots later, when it will work! :)
to get MBM working or the coretemp plugin?
The Update from ur link! I tested P4P and P4C, but both settings don't work for me. Always 9,xxV for the +12V.
