I spent almost 1.5 weeks everyday...tried all combinations in bios and still found a few new combo that worked:)
After ran almost all 975X boards on the retail market, I can say that this BFG 680i board is the most challenging and fun to oc.
nice rig man...great score on 3d06...been thinking of of going sli myself.Quote:
Originally Posted by billdavis
..back on topic...have you tried higher volts to cpu? higher than 1.5?
Originally Posted by icon57
thanks and thanks, I wish I had more time to tweak!
I have only tried up to 1.47v isnt anymore than 1.5v pushing it for a 65nm chip?
________
Mercedes-benz u.s. international history
this might sound like a dumb question....but I owuld like to know who all has a computer case with 3pins for the power led...and have gotten it to work with the 680i board? if you have how did you do it?
Try the settings I posted. Also try using only one of your 2GB kits. You should be able to drop your vdmm a bit too then. FSB voltage should handle 1.5v and northbridge may need to be increase to 1.5 or 1.55v typically the system raised the northbridge and other voltages by itself when set to auto and running high FSB. Only my BFG required an setting of 1.55 northbridge and that was @ 1850 and above. The Evga ran with everything set to auto except vFSB up tp 1865/465FSB.Quote:
I cut mine in half along the center since there's only two wires. White and green. The middle one for me is emty/no connection. I then placed the green on positive & the white on negative.Quote:
Originally Posted by Grinch
I've been running my e6600 with 1.58v since early sept and had no problems(on water).Quote:
I guess i have a dud, my evga with p20 bios won't even hit 1600. I have tried everything setting memory slower than rated speeds dropping multi down to 7x. disabled alll spectrums and have tried just about everything in this thread.
e6600 @ 2.8ghz l630a
2 gig 2x 1gig dominator 6400c4
evga 680i evga 8800gtx
sblive xfi platinum - ocz powerstream 520w
I guess i am going to have to get a new power supply to get where i need to be but i thought these conroe's were supposed to use less power.
Looking into this one
http://www.newegg.com/Product/Produc...82E16817703006
"I cut mine in half along the center since there's only two wires. White and green. The middle one for me is emty/no connection. I then placed the green on positive & the white on negative."
Could you take a pic and let me see? I hate to modify my case wiring for 1 mobo...just wanting to see how hard it is...:toast:
Originally Posted by bigjohns97
have you tried "unlinked" in bios when raising the fsb?
Yes, I have tried unlinked and linked:sync and am unable to hit 400fsb.
Meanwhile my dominator is running nicely @ 400mhz 4-4-4-10 1t.
But right now i am stuck @ 1400-1500 fsb and everything after that is hit or miss.
What does it usually mean when you overclock and windows boots, loads and then freezes in windows?
?not enough vcore?
________
BMW E23
i just ordered this board.i'm gonna see what's gonna offer
crap..I would ahve tohught you would be ok with that psu...Quote:
what else are you running
I didnt think a 8800gtx/e6600 would be that power hungry....
Your PSU should be fine. I use the same psu on my testbed. It did 3DMark06 with 7900GT's SLI & a 7900GS over 4 hours orthos stable.Quote:
http://img.techpowerup.org/061119/E6...k06 465FSB.jpg
http://img.techpowerup.org/061119/5h... 465FSB942.jpg
Nemeisis
where do you get the temp bar in the top right of your desktop
________
Essential vaaapp
That's everest. When it's running you can set the utility to dsiplay various temps, voltages, & Fan RPM's in the box & on the taskbar. Not good to run during Pi, or when trying for MAX 3DMark06 score, etc though.Quote:
Originally Posted by Dumo
One thing that makes this board "fun" to OC is the fact that when you set something to high in the bios, you dont have to disassemble your case to clear the cmos. Just give it a few seconds and it'll come up in safe mode. only 2 times out of 60ish i've had to pull out my xfi and 2nd 8800 to get to the clear cmos jumper.
well, ive spent some time on this board and no dice here.
I am on quad core, so I dont know how different that makes it... but I cant push anything higher than 320ish
Im in 680i hell.
on a side note, memory does well.
Yes, means your close, and usually you can get there with a voltage bump.Quote:
2 raptors a 300 gig sata2 and a sata cd-rom burner and xfi platinum.Quote:
Originally Posted by nealh
I agree that this PS should be enough, but i would hate to think i just got a lame board.
BTW I am now @ 350(1400) fsb x9 @ 3.15ghz stable. So my chip is average but my board seems to be very below average.
memory running great @ 400mhz 4-4-4-10 1t
got to be something else..maybe you should list you bios settings for the guys here to help
I have not heard of a 680i not doing 400fsb
give these settings a go.Quote:
Code:CPU Configuration
Limit CPUID MaxVal (Disabled)
Intel SpeedStep (Disabled)
CPU Thermal Control (Disabled)
C1E Enhanced Halt State (Disabled)
Execute Disable Bit (Disabled)
Virtualization Technology (Enabled)
System Clocks
CPU Multiplier (9 X)
PCIe x16_1, Mhz (Auto) or (110)
PCIe x16_3, Mhz (Auto)
PCIe x16_2, Mhz (Auto) or (110)
SPP<->MCP Ref Clock, MHz (Auto)
**HT Multiplier**
nForce SPP--> nForce MCP (5 x)
nForce SPP<-- nForce MCP (5 x)
**Spread Spectrum Setting**
CPU Spread Spectrum (Disabled)
HT Spread Spectrum (Disabled)
PCIe Spread Spectrum(SPP) (Disabled)
PCIe Spread Spectrum(MCP) (Disabled)
SATA Spread Spectrum (Downstream)
FSB & Memory Config
FSB-Memory Clock Mode (linked)
FSB-Memory Ratio (Sync)
FSB (QDR), MHz (1600)
MEM(DDR), MHZ (800)
Memory Timming Setting
Memory Timming Setting (Expert)
tCL (CAS Latency) (4)
tRCD (4)
tRP (4)
tRAS (12)
Command Per Clock(CMD) (2T)
**Advanced Memory Settings** (everything here to auto for starters)
tRRD (Auto)
tRC (Auto)
tWR (Auto)
tWTR (Auto)
tREF (Auto)
System Voltages
CPU Core (1.50)will vary depending on your hardware
CPU FSB (1.50)
Memory (2.20)will vary depending on your hardware
nForce SPP (Auto)(some boards need more)
nForce MCP (Auto)(some boards need more)
HT nForce SPP<->MCP (Auto)(some boards need more)
Yes those are basically the settings i have set but i had some minor changes.Quote:
Originally Posted by The Nemesis
Anyways i tried those settings exactly and got the same result.
Just to clarify i cannot run linked unsynced anything @ 1600fsb
Right now these are my current settings.
same as above but i disabled sata spread spectrum
1400fsb 800mhz ram 4-4-4-12 1t
cpu @3.15ghz
all voltages on auto except vdimm @ 2.2
[HTML]CPU Configuration
System Clocks
CPU Multiplier (8 X)
**HT Multiplier**
FSB & Memory Config
FSB (QDR), MHz (1860)
MEM(DDR), MHZ (930)
tRCD (4)
tRP (4)
tRAS (12)
tRRD (Auto)
tRC (Auto)
tWR (Auto)
tWTR (Auto)
tREF (Auto)
System Voltages
CPU FSB (1.50)
nForce SPP (Auto)
nForce MCP (Auto)
HT nForce SPP<->MCP (Auto)[/HTML][/QUOTE]
how do i copy my bios settings like this
and does Execute Disable Bit make any diffrence
________
Vaporizer
