Nice board out there :up:
Bad price out there :(
i'm waiting for abit and dfi 680i boards; i want sli; i want to overclock....too much tinsel and crappy hps on asus striker for me.
check out the dfi 680i thread for dfi 680i pic...it looks a bit light on the chipset heatsinks. abit at least has a decently large looking hs on one of the chipsets.
coolalers tests re this abit in9 look convincing to me.
'kin heatpipes allright; kin waiting for 'kin decent 'kin choice for my 'kin shopping; how much more testing do they have to do on these 'kin boards b4 i can get my 'kin hands on them? i'm sick of this amd 3500 p o crap already!
let's see now; shopping for: e6400, gskill6400hz2gig, sli mubbberboard - only i cant get one...
(silverstone zeus850 + second 8800gts as sooon as i have bashed out my common sense brain cells.)
still waiting.....i think i need another hobby besides obsessing over pc hardware :/
might get away with 600w with 8800gts sli
any word on this board?
wow... the heatsinks are soldered to the motherboard
http://images.tweaktown.com/imageban...2XMAX_010l.jpg
Hmm...your source? I don't want to believe it =PQuote:
Originally Posted by P_1
sigh. Those are what abit calls OC stips IIRC. Theyre nothing more than strips of metal that work like heatspreaders to keep the backside of the board around the PWM and CPU socket cooler. My AW9D-MAX had them, before it crapped out on me :mad: Its doubtful that it helps much if at all, but...:fact:
The Molex connector on the Abit Max was actually an output not an input (at least that's what I thought I read in the manual, it's for fan's etc in the upside down motherboard mounting cases), I'd expect the same with this board...
regards
Raja
Looks a nice board but ill stick wiv my rd600!
Originally Posted by mr_knowitall15
Correct... if anything its more copper in the PWM circuit so its a good thing.
Abit overclocks IN9 32X-MAX to 557MHz FSB
MOTHER***** :shock: :slobber: :D
Edit
http://www.bit-tech.net/news/2007/01...to_557mhz_fsb/
Guy, link does not work. Check it plzQuote:
Originally Posted by Smy
Wow. . .I played with one of these at the Abit OC'ing event on 12/15. FUGGER and I had some fun with his three stage cascade and some LN2 runs. I was able to hit 530fsb on this at that event. . . now they're hitting 557. . . niiice! The engineers I spoke to said they'll only be satisfied once the bios allows the fsb up into the 600 range.Quote:
I too am going to break down my rig, sell off my DFI Expert mobo, Mushkin Redline DDR ram and my FX-60 and snag one of these and a X6800 and maybe a set of Dominators. Time to take a walk to the dark side. . .
i'm still hangin out for this board.... the dark side indeed...must have good PWM - the voltage / stability thing is the main reason i am looking at this board - what is max vcore? any1 know?
I am used to dfi's sweet sweet power / stability. Asus options leave me in a cold sweat in this regard. Wish i knew more about this ABit board - i wanna know the voltages
QFT! Asus = :slapass:Quote:
Originally Posted by adamsleath
My next board will most certainly have a digital PWM solution.
The only crappy thing about this ABIT board is that there is no way you will be able to get a waterblock on the SB with one of the fasteners directly under the graphics PCB like that... what where they thinking?
Crotale is testing this board right now:slobber: :slobber:
http://www.xtremesystems.org/forums/...d.php?t=129017
Nice 1
Anyone know when this board is expected to land? Mid Feb most likely? I like the 6 Sata's.. :)
supposed to be out next week in Europe.
I`ve had this on pre-order for weeks from UK store, for £234.00. ETA is 08/01/07, but i wouldn`t count on it, this date changes nearly every week.
Would be great to get a firm release date for a change, i`m sick of waiting for this .
customer :stick: ABIT
maybe they need more oompha-loomphas in the abit factories :p:
would tt big typhoon overhang the edge of this abit board? - i think so (122 x 122 tt bt)
scythe ninja (110 x 110...x150high) may just fit in my inverted case (but i'm going off a scaled photocopy of the abit board...!lol!) ninja overhangs board edge by 3mm...tuniq tower 108 x 133 - 2mm extra space.
my current xp-120 should fit with hpipes facing far right edge of the board and the bulk of the hs fins over hanging the motherboard heatsinks - would be good for airflow over mobo sinks.... unfortunately 120 not the bestest hsink around...this would be much easier if didnt have this inverted case!!!...or just went for water :(
