http://img220.imageshack.us/img220/8156/jht2.png
vdimm 2.46
Very nice modules I wish i still had my team kit or else I may be able to hit 600 :)
msimax: please add your voltage
overcrash: Spi stable? :)
EVGA 680i
X6800
Team Xtreem
Tuniq Tower 120
VDimm: 2.5v
656MHz (DDR2-1312) @ 5-5-5-8
http://img154.imageshack.us/img154/6836/ddr21312hq1.jpg
I would show CPU-Z, but it doesn't read memory speed or timings on 680i boards.
Also Orthos stable at DDR2-1201 (5-4-4-8). Not sure why Nv monitor is showing weird numbers.
http://img300.imageshack.us/img300/8...1201544zd5.jpg
Still testing.:)
^^ Very nice :)
http://www.overclocking-masters.com/...23.htm#p137023Quote:
Originally Posted by K404
:( sorry, i`m only adding 2GB kits... 600++ seems a bit easy for 2x512.
VERY impressive clocks though!
im at ddr2-1200 at 5-4-4-12 with 2.425v.
Join with Team Xtreem 800C4
p5w dh change p5b-d
http://kepfeltoltes.hu/061115/1200_w...toltes.hu_.jpg
Memory: Crucial 667 Anniversary Edition 2x1GB
SuperPi 1M
651Mhz 2,45V P5B-Deluxe (no mod)
http://i79.imagethrust.com/t/473255/1m12890.jpg
SuperPi 32M
http://img503.imageshack.us/img503/9...1mhzmv8.th.jpg
NICE!!! Not bad for $230 huh?Quote:
Originally Posted by MidnightMadness
It's much better than i expect :D
Crucial 667 Anniversary 2x1GB :)
620 Mhz 2,4V P5WDG2 WS PRO
SuperPi 32M
http://img157.imageshack.us/img157/3...mkasak6.th.jpg
http://img246.imageshack.us/img246/9...czytwf0.th.jpghttp://img242.imageshack.us/img242/6...apisaa8.th.jpg
As per sig, 2x1GB G.Skill PC6400 HZ
600MHz 2.45Vdimm set in bios, P5B Dlx WiFi
Timings are a bit loose, these are not the best set of HZ I have seen
2:3 5-5-5-15
Super Pi 1M
http://img183.imageshack.us/img183/1634/1m600qi1.th.jpg
System:
- Intel Core 2 Duo E6600 Conroe QPGE B1 Step 5
- Swiftech G4 Storm/Thermochill 120.3/MCP650 + Kayl 100W Custom PSU
- Asus P5B Deluxe 0804 bios (upgraded from 0405 bios)
- 128MB Gainward FX5200 PCI card
- 2GB OCZ PC2-8000 Titanium Alpha VX2 Micron D9GKX
- 500GB Seagate 7200.10 SATAII
- LiteOn 165H DVD-ROM
- FDD
- 1KW OCZ ProXStream 1000PXS Quad PCI-E psu
Managed to break DDR2-1200Mhz barrier :)
PCI Express Frequency: 100
PCI Clock Synchronization Mode: 33.33Mhz
Spread Spectrum: Disabled
CPU Vcore Voltage: 1.5 (1.448) - set higher than needed for test purposes
Memory Voltage: 2.45v
FSB Termination Voltage: 1.3v
NB Vcore: 1.65v
SB Vcore (SATA/PCIE): AUTO
ICH Chipset Voltage: AUTO
Memory Remap Feature: Disabled
Configure DRAM Timing by SPD: Disabled
DDRAM CAS# Latency: 5
DRAM RAS# to CAS# Delay: 4
DRAM RAS# Precharge: 4
DRAM RAS# Activate to Precharge: 12
DRAM Write Recovery Time: 6
DRAM TRFC: 42
DRAM TRRD: 10
Rank Write to Read Delay: 10
Read to Precharge Delay: 10
Write to Precharge Delay: 10
Static Read Control: Disabled
Modify Ratio Support: Enabled
Ratio CMOS Setting: 9x
CIE Support: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
CPU TM function: Disabled
Execute Disable Bit: Disabled
PECI: Disabled
@605Mhz 5-4-4-12 at 2.45v
http://fileshosts.com/intel/Asus/P5B...lidated_tn.png
http://fileshosts.com/intel/Asus/P5B...3s985ms_tn.png
http://static.flickr.com/122/301707877_1132a951d9_o.jpg
altho i would really like to say my ram is runningat 1378mhz like nvmonitor shows, it is only running at 1225. nvmonitor does not show correct bus speeds for the 680i yet. cpuid only shows spd and correct cpu fsb/clock speed. cpuid also shows wrong chipset.
anyway, g.skill pc2 6400 HZ @ 5-5-5-15 @ 2.425v, 612.6mhz. guess i will have to wait for these utilities to catch up.
Hey! Updated. I was hoping to jump in with this before the 680I results started pouring in...please can we keep this for 965 and 975 chipsets...If Kunaaks results are anything to go by...600MHz will be too easy on 680I chipsets
Sorry Politenessman!
Why my score werent added to the list ?Quote:
DAMNIT... Looks like I updated it and didnt save the changes...Sorry Kas (also to alphaOne and Eva)
How comes I'm hitting 600MHz with only 2.1V set in BIOS?
My DMM reads ~2.15V.
You're all using 2.3V or higher. :confused:
Crucial DDR2 Tenth Anniversary PC5300, 2048MB Kit w/two matched DDR2 667mhz.
http://img161.imageshack.us/img161/6...0mem250pa2.jpg
Mobo: Gigabyte GA-965P-S3
:D
623mhz 5-4-4-15 2T 2.5v
http://img297.imageshack.us/img297/5702/3333333ia7.jpg
1230Mhz. @ 2.4v :D Crappy SuperPi 32Mb time with looser post 400mhz strap on P965 chipset, but nevertheless - its the RAM that counts here right ?
http://i97.photobucket.com/albums/l2...5-5-30Supe.jpg
http://i29.photobucket.com/albums/c2...superpiWEB.jpg Heres mine. Quad doesnt want to go too high fsb on this board. Adding vdimm helps with timings but Im not in the mood to push comp too hard till my phase gets here.
p5b-d ,Team Xtreem 2.45v
http://img270.imageshack.us/img270/175/6005555yr2.jpg
K404 - Why my score of 1M werent added to the list ?
