How did u apply grease inside the socket? Did u put it in the center? Or also over all the contact points?
I know whith the other sockets u just smear it all over the socket, but since the 775 doesnt have pins, doesnt the grease block the contact between the socket and cpu?
If you use grease all over not just middle square. Have a look at this post for example.
