Right now my set is sitting at 1080mhz 5-5-4-12-21-2T 2.28vdimm
I'm trying to tweak my timings, maybe 4-5-4 or 5-4-4. Any suggestions?
Try 2.4vdimm maybe.Quote:
Originally Posted by Dillusion
Edit: 1100Mhz @ 4-4-4-10 w/ 3:5 and 2.4vdimm
http://img141.imageshack.us/img141/7...ial2wz6.th.jpg
D'9s like the V.dimm increase if you crank them up. 2.4 it's fine, If you can try to have a fan blowing air on them it does help over the long run.Quote:
try 4-4-4-x-42-1T @ 2.4 to see where they will max out.
I'm reading that Micron D9s and the Gigabyte DS3 don't play nice together... Is this true?
Is it worth it for me to buy these if my OCZ Plat is stable at 5-5-5-15 (445 - 450MHz) with my e6300 (3110GHz) Is it worth $50 more than I paid for the OCZ sticks to get the Crucials? What is the typical overclock for an e6300?
Very nice, a low cost high quality kit. :)
i ordered my kit tuesday night and got it for the $229, finally i buy i feel some what safe with cause i now the price ain't gonna drop anytime soon
about time a cheap, overclocker-friendly 2gb kit comes out. RAM prices are absolutely rediculous. this crucial is definitely worth the money.
Should I get the Crucial or the Team Xtreem 2 Gb Kit DDR2 (2 x 1Gb) 3-3-3-8 667 Mhz for 280 @ Tankguys?
It's up to if you want to pay the extra $50. I think this Crucial Memory has proven itself to be a real good bargain.Quote:
Originally Posted by Mdrei
Well the question is: Will the extra 50 buy me anything better? They seem to be using the same chips and timings are pretty much the same.Quote:
I seriously doubt the 50 bux will be worth it. The results posted in this thread about the Crucial's speaks for itself :fact: . Hell, I even bought another set. Thanks again Nicepun! :clap:
Well I just bought a set too... I hope they play nice with my DS3 and E6300. Now I just need to sell my OCZ Plat. PC6400 4-5-4-15 kit.
well i maxed everything out last night, ram hit 1100 mhz at 5-5-4 with 2.37vd but this was because my CPU only does 2800mhz.
My 24/7 OC is 2.17vd @ 5-5-4-12 and 1080mhz
Curious, have you tried running @ cas 4?Quote:
yes. cas 4 produces a boot error 'cannot find file xyz.dll' at boot. if the voltage is raised it goes away, but for a 24/7 OC im not too concerned with the extra 2-3% of cas4/5
They said they were going to ship to canada a year ago, whatever happened to that??:confused:Quote:
Originally Posted by lowfat
FYI...The other set I bought are able run 500+ FSB also. Interestingly enough, I found out Windows XP only supports up to 3 GB of ram. I guess I have to wait for Vista to enjoy 4 GB.
newegg went backup to $249:mad:
***EDIT***
Went back down, bought a set.
I found List of chips used on DDR2 RAM modules which says that both RAM use the same chips.
Nice find, which chips arguably are suppose to be best?
Thanks brother for the info. Grabbed me a set for 229.00 shipped.Quote:
Originally Posted by The Nemesis
Damn i got them already, Newegg ROCKS.
Got mine just now.... will test tonight but I am still waiting for a bios update from Gigabyte to fix the Micron D9 issues.
so how high can we set the V before the crucial warranty voids?
also does taking off heatpreaders still void warranties? I would like to check if mine are D9GMH as well.
i think it's 2.2 before voiding warranty and removing the heatspreaders should void it too. mine sitting in a box somewhere out of reach right now
