problem with kentfield isnt the clocks, it is the damn mobo's
sure 9x is great and all, but currently the limit with P5B dlx is 12.
What is the max FSB that you can grab with 12x multi?
You should see the Nforce chipset struggle with anything past 290 with kentfield, it is bad!
badaxe2 will help with the FSB issues, and im sure more mobo's will follow.
If you can fight the heat of this bad boy, it will do great clocks on air.
3.5vcore on stock vcore is easy :)
