Not quite...Quote:
So, you (Marci) mean like that?
I really think that a fillport is not needed, alsi top barb.
Like this:
http://marci.over-clock.com/res3b.jpg
Not quite...Quote:
Like this:
Wow. Kind of unique. Nice design but I'm guessing you would need a pretty decent pump for that.
Is there really that huge of a difference between T and reservoir?
Marci; so yith your design, you would need one bottom fitting from the side to enter the small tube?
Please explain how wouild the barb threads be connected into bottom POM?
Not thought about it hard enough yet... replace small tube with small T-Piece? *shrug* Sling the small tube, and just use a rigid divider across the bottom piece of acetal... similar to...Quote:
http://www.performance-pcs.com/catal..._Res_t_LRG.jpg
So (for instance) on one side of divider would be 1x side fitting and the base fitting. On the other side of divider would be remaining side fitting... first way that springs to mind.
I've simply gone for the option that provides the most useable configurations from the res so that it appeals / is useable in the majority of setups...
Pump choice is irrelevant. You would generally only ever be using 2 of the 4 fittings... the remaining 2 would be plugged.Quote:
Nice. So you would use the 2 you want? The top and bottom or another variant as well, like top and 1 side?Quote:
With the one Marci show, there's about 3-4 diferent configuration possible. Which is nice since the majority of res out there only have 1-2 configuration.
Any 2 or more you want of the 4 available. Can use as many or as few fittings as you like. Entirely up to the person fitting it in their loop and how they want it setup. There is no rule that says a reservoir should only have 2 connections.
EG: Position res on case panel above DDC Ultra. Go from base fitting straight down to DDC Inlet. Come back into res on one of the 2 side inlets. From the top fitting, run a line up to roof of case to a delrin fillport or similar for convenience of filling.
Nice work EK and Marci nice implementation. Thanks for answers.
Maybe Marci needs royalty check for help. :p:
Aerial view of base POM... redline denotes separator, either machined into acetal (difficult) or simply a separate piece of acrylic bent as necessary and glued in place.
http://marci.over-clock.com/res3c.jpg
Bingo - perfect.
Seen your post over at Bit-Tech forums - disagree - top inlet necessary as a filling point... better to keep imo and leave it to customer whether to use as fillpoint and plug, or run up to fillport or similar... or even another res... meaning yours can be used for aesthetic purposes to supplement a current system...
OR...
Remove the top fitting completely for a basic model. Make the base POM available for purchase separately for those that want ultra-flexibility... ie: 3 possible fitting points at either/both end(s) of the reservoir - remove "standard" (no-fitting) top and replace with a bought-separately 2nd base. (The additional holes could also be used to mount submersible temp-probes etc).
And then do as we did with the Thermotube - make it available in varying lengths from 3" upto 10" or similar...
As tube to POM is threaded rather than chemical joint, make tubes available separately too for customers who for instance purchased a tall res initially, but then move to smaller case and want to shrink the res and vice versa.
Marci I dont understand why you need a seperator for if you already got an intake tube going from the top? I can see it for the 2 sides port if you planning to use just that.
NM..Okay I see Eddy redraw that a little better.
Because some customers may choose not to use top fitting as intake.
It's all about giving the end-user a CHOICE, flexible enough to match any case / routing configuration that user may have... without imposing rules of "you must use this as inlet and this as outlet".
Only pair not to be used simultaneously would be the base fitting with the side fitting which shares the same half of the base - air'd just get sucked thru rather than bleeding / gathering.
Some users may choose to lie the tube down in base of case for instance, and use top fitting as inlet, base fitting as outlet, and one of the side fittings to run up to either a secondary reservoir or fillport.
Either way, if two fittings are used, there MUST be a 3rd point thru which the end-user can actually fill the reservoir with water.
If base fitting isn't used when piped into system, this then makes a superb drain point...
LOTS of options depending how/where the customer wants to mount the res.
This would work perfectly in my build that I'm planning for the summer. If you build it, I will buy.
Alright, I'm ready to buy that thing! How many weeks to months before we can possibly get one? You'll have standard G1/4 plugs to cover the unwanted holes?
nice stuff so far folks. all the more help for bleeding is good / with options for better / and hopefully with a way to make it help look speed best *shrug
Marci, you don't like the plexi to have threads right?
Then how should the acetal top and bottom be connected to the plexi tube?
With 2 o-rings a la Coolplex?
See here:
http://www.xcsystems.nl/images/189_0.jpg
I think that the top fill-port fitting adds a great deal of flexibility to the res and I for one would order it that way. I also like the idea of the different sizes so every case could use the res.Quote:
Originally Posted by Marci
So when can we put our orders in? :slobber:
Edit: I also like the idea of having a port for my temp probe.
The top and tube will be connected with thread, and sealing with one O-ring on each side.Quote:
Originally Posted by Garrett
edit... my bad typing...
Nope... misquoting... I don't like plexi threading onto metal. Metal and plastic expand and contract at different rates, thus resulting in splits in the acrylic over time - frequent occurance with Innovatek Tank-O-Matic reservoirs and other brands using threaded joint from acrylic to metal.Quote:
As long as it's acrylic to similar non-metal material, threads are fine.
Thanks for clearing that up :) (my bad)
This could be a kickass reservoir then :thumbsup:
I still think the res is too long (tall)... Does it need to be that big? I would shorten it by about a third to make it easier to fit in places.
Alternatively, you may be able to offer two body lengths... a short one and a longer one?
Well that could be fiixed if it comes in different sizes, like on that length and one shorter and one longer!
But thats up to Eddy!
I just got back from the hardware I bought a big brass T fitting, 2# 1/2 Id barbs that the tygon will barely strech over. 2# adapters so the barbs would fit into the T. And a 14"L 3/4" id brass pipe. This should be easier for bleedin' the air outta' my lines. And act as a res of sorts. Hopefully it won't hurt my temps. Though it might not be big enough for the air to give a chance to rise up. Oh well well see.
Of course there will be different sizes of reservoir...
