I'm officially pwned, well done sir. ;)Quote:
Originally Posted by Shaotai
Since this 1407 is exactly the same as every other bios we've had for this board, there isn't really much further to discuss.
actually, not quite.Quote:
Originally Posted by don_vercetti
I can boot past 380x10 (390 with some luck) with 1407 while i was stuck at 370x10 with 1402.
To bad it isn't even near stable at those speeds.
Also, the memset timing trick doesn't seem to work with this bios, it gives best results at spd timings.
and i have to do a cmos reset when i try cas 4 timings, the board just hangs before post!
K 1407 Bios allowed me to break again the 400Mhz barrier up to 445Mhz now, Multiplier downwards works fine 2. I downgraded to 1305 again after 1405 release.
Benching the rig now at 8 X 400 1.420 volts. Running 24/7 at 7 X 400. Thing is if I use a lower multiplier most of my hardware detections programs ( everest home, coretemp) etc detect my CPU speed and ram speed wrong
CPU-Z detects the 7 X 400 the other detect 7 x 457 really weird. But it's Orthos stable at the moment at 8 X 400.
Anyone else having this software bug ? The added cooling did miracles ( north - and southbridge helped a lot when using this board a recommendation to all users
http://users.pandora.be/OAP/Ultra120.jpg
@ Leeghoofd
That is because your North Bridge Core Clock (NBCC) is maxing out. Default is as you know 266 MHz. When you use the 7X multi the math is like this :
8/7*400 = 457,142 MHz NBCC clock.
But when you use the default multi (8X) then the NBCC = the FSB.
You are most welcome... and most humble too. Hope you get the right mobo for testing, maybe try the P5B Deluxe for the high FSBs.Quote:
Originally Posted by OPPAINTER
1407 is official
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...20DH%20Deluxe/
Originally Posted by Leeghoofd
Yeah, everything but CPUZ detects the wrong SPEED, right now I have it 8*450 and Sandra, Orthos, etc. think it's 9*450 (I wish). But I love to been able to lower the multi. Oh yeah, I've been able to boot into windows @ 470FSB. NB is watercooled and I have the 1.85vmch version.
can you show a pic of the watercooling you put on the NB.Quote:
Originally Posted by nicepun
what was your limit before that bios?Quote:
thats normal, asus mobos don't update DMI after multi or fsb change, so most programs can't read proper cpu speed.Quote:
Here you go!!Quote:
Originally Posted by NO1B4ME
http://img507.imageshack.us/img507/6...0006xw5.th.jpg
