VERY CLEAN build :D
VERY CLEAN build :D
did most of the insulation
http://www.benchtec.co.uk/1/cascade3...6/DSC00347.jpg
http://www.benchtec.co.uk/1/cascade3...6/DSC00345.jpg
Ohh great looking, did you try it on load, for what tubing/size is that sleeving?
thanks
i think thats as good as i will get with r23
just hooked it up for some load testing and manged to pull the cpu out the socket
i am going to get a load tester now:D
http://www.benchtec.co.uk/1/cascade3...6/DSC00331.jpg
Amazing dude. Look forward to full final pics of it all enclosed in the case! If ya thinking what i am still then yes to your answer!!
Looks awesome Baz :D!
This Is Ownage :d
forgot to post the evap work
picks can be found here
http://www.benchtec.co.uk/1/cascade3/build/evap/
http://www.benchtec.co.uk/1/cascade3...p/DSC00290.jpg
http://www.benchtec.co.uk/1/cascade3...p/DSC00282.jpg
nice, like the way ya did the evap:toast:
how thick is the base of that evap.
Is it hard to brase without getting any solder in the ring part?
MMmMmmmMmm... i like the brazing job :)
with the mount i am using i have to get the cap as close to the suction return as posQuote:
Originally Posted by kayl
as for the brazing it depends how long the brazing rod is
ie for fine work i use a shorter length as it will shake less well some times:D
i will check with ld for the base thickness
@jin thanks
That brazed evap is excellent. What did you use to clean it?
I see on the picture of your purging setup, you have the N2 bottle connected to the capillary tube which is fed into the bottom of the evap. But what is the other part of capillary tube there for?
Holding the evap in place I wonder?
Could be, but I would think that captube wouldn't be strong enough for doing that. I may be wrong though.Quote:
Originally Posted by n00b 0f l337
It doesnt look like captube to me though. Maybe to just push some more purging gas into the evap?
Yea possibly :) .
I want that Oxy-Acetylene brazing setup hehe :D . I used one last week to braze my first unit up, and they just put out some insane heat!
Only problem is cost really, I was told the portapaks are really expensive.
the other wire is just to balance the evap and hold the cap tube out of the way
while brazing
Oxy-Acetylene is by far the best for this job but as others have shown not essential
i use 3x different nozzles for brazing these are BOC sizes
number 1 for fine work and most of the pipes
number 3 was used to braze up the tes2 1/2 to the hx
number 10 for the evap 3 could also have done this but not as quick
if you were using Oxy-Acetylene for the first time i would say use the number 3 for the evap
Looks crazy nice :)
