Btw : when You beat my score :DQuote:
Originally Posted by Athens[2004]
:toast:
And mem only 930 with vmem ? Poor card :p:
:toast:
nice core you got there man :) i get with poor stock aircooling and vmod to 1.45V - 715mhz core and 900mhz memories..
will put the card on single stage phase change this week and we'll see the results... :)
Very nice scores @stingush especialy with single core a64. Post a pic of your vgpu .
Thnx Tom.
vgpu mod done!!1 finaly 1.48v under 3dmark 06 & 2.14vmem both full load.
http://img145.imageshack.us/img145/4387/dsc06227ua9.jpg
http://img99.imageshack.us/img99/8083/dsc06228co8.jpg
http://img145.imageshack.us/img145/6412/dsc06226rm5.jpg
Start searching card limits [cpu speed low ]
http://img99.imageshack.us/img99/9669/06in1.jpg
http://service.futuremark.com/compare?3dm06=637960 .
So @DEVIL K-ce can u feel my breath or not yet :toast: :D
Thnx 4 the help Tom . :D
:toast:
At this rate you will be passed my SLI score with 7900GS :embarrassed:
I plan on doing some benching this weekend with the setup, it's still stock at the moment as they are supposed to be my gaming cards.
Regards
Andy
Thnx. This weekend is my weekend too :D
Tom
Good work :toast:
GPU clocked :slobber: I have only 745MHz at 1.45-1.47V and no more.
But my mem running on 2.25V with 980MHz ;)
Simply cable mod :banana:
Go clocking :devil:
btw : I in weekend start to play with 79GTX + dry ice. GTX moded of course ;)
More volts!Quote:
Whats the temp on gpu with 1,48v?
39~idle , 43-44 under atitool stress . watercooled , asetek dyo on vga , eheim 1250 & alphacool nexxos xtreme 240 [litle bigger than black ice xtreme 240]
http://service.futuremark.com/compare?2k1=9090661
Not sure how much 2001 likes this new nvidia driver but I am getting lazy in my old age and cannot be bothered to change it :)
Single card is about 53k non moddied.
Regards
Andy
This is SLI setup :rolleyes:Quote:
Originally Posted by zakelwe
If yes - You got nice score :toast:
I had a few runs today but i free too mutch gas from single stage and run discharged so cant hold cpu test's for 03-05-06 , so 01 only :) . [card on water]
http://img417.imageshack.us/img417/5343/0111vw7io1.jpg
http://service.futuremark.com/compare?2k1=9091918 .
Any updates Athens?
Nope . 775-780core & 940-950mems is the max that card can do with water. With numbers ~60k 01 , 12~ 05 , ~27k 03 , 7-7.5~ @ 06 .
with some quick runs. So i need to freeze the card for better scores on 03-05-06 and when i have time i ll try to fit my single stage on gpu .
Have you disabled the overcurrent protection?
Sounds good, looking forward to seeing your results. I'll be putting mine under dry ice in a bit, just waiting to get the container done. I hope they dont have an early coldbug.:)
?? overcurrent protection ?? tell me more . :DQuote:
Originally Posted by aspstein
@ MTP04 , awaiting your result's to . good luck :toast:
Modded and tested my card last night
http://i107.photobucket.com/albums/m...79GS_63963.png
On air the card likes delta 40, on phase change the card likes best delta 0 or negativ delta. Somthing like -20 or so (about 235 in Nibitor).
Overcurrent protection mod
http://resources.vr-zone.com/Shamino/79mmod2.jpg
Havent done this mod myself, and my card run 840/860, but i think im going to up the volts to 1,7 and remove these two resistors. And maybe try with some dry ice. Then the card would really fly :D
?wtf? impresive . !!!! , i think i must combine tec for vga ang my single on my cpu for >60k on 01 .
You can run 05 and 03 without the CPU tests. Just hit esc
Nice clocks there Aspstein!
What vgpu did you need to get those clocks? Also was that on air or phase?
Now lets not steel Athens thread here....
I used 1,5V and phase, tried to do the 1,7vgpu mod tonight, but that doesnt work. 1,6vgpu works, and I will give it a go as soon as i can get some dice. Then maybe wee would see some 900 core action.
No mod on the mem yet either...
Im surprised you guys havent tried unlocking your cards yet :p: My BFG 7900GS OC has unlocked to 24x8 as another BFG 7900GS user on tech powerup. http://img171.imageshack.us/img171/6...ckedym0.th.jpg
Not Bad at all :fact: :banana: This card even came with a $40 rebate :D
ill tried mine :( nothing. [except if i doing something wrong..]
http://img171.imageshack.us/img171/6471/untitledlg5.jpg
Maybe we have not got the BFG ? :p: Nice to know though :toast: Maybe this is a real sleeper :)Quote:
Originally Posted by Inteleron
Regards
Andy
