great review FUGGER !
FUGGER what sound are you going to use w/ that setup? External, audiomax, or pci flex solution?
I used an older cat driver, you would need to check the bench run for exact revision . I think it was 6.4
On the 375 FSB problem, what multiple are you trying to use? I had a problem with 10x and lower.
Onboard sounds is good enough for me.
I have tried the 8, 9 and 10 multi. I cant do 400+ with the 11 multi on water. I guess I will wait for the prices to come down on the pc6400 ram you are using.Quote:
Originally Posted by FUGGER
Woah I didn't even notice the board has built in LED's, :banana::banana::banana::banana:ing sweet, since my cheap ass won't buy any cathodes. :cheers:
Any feedback on this?Quote:
Originally Posted by Kabauterman
nice board I have one, it can boot up 445 out of bios with no mods....
The only issues i am having is running Crossfire, I think it still needs some bios work.... even with the latest final...
I managed a nice superpi with water, certainly not xtreme but ok for me anyway......
http://upload4.postimage.org/1215510/photo_hosting.html
http://worldoverclockingleague.org/f...topic.php?t=10
Ok, I have also an Abit AW9D, with multi 10 I´ve FSB 413, but I have still problems with my memory. On Asus P5B Deluxe, DDR2-1200 4-4-4-5 is no thing, on Abit - maximum DDR2-950 4-4-4-5 :(
http://img242.imageshack.us/img242/148/x6800iu9.jpg
Nice memory clocks!! what memory are you running?
Cellshock DDR2-1000 4-4-4-12, its a brand from MSC in Germany.
Look: http://www.xtremesystems.org/forums/...d.php?t=116624
it is same version as posted by fugger.... no need for upgrade...Quote:
Originally Posted by MJRL
Here are my 1st impressions of the Abit AW9-Max..
Using the new bios 1.2..
Tested iwth E6700 ES cooled by a TT Big Typhoon, memory sticks are TG 667 3-3-3
Photo:
http://pedrorocha.planetaclix.pt/Aw9_BT.jpg
Moderate OC ;)
http://pedrorocha.planetaclix.pt/Abi...900_10x390.jpg
More agressive OC to test the limits of the CPU / Mem :
http://pedrorocha.planetaclix.pt/Abi...00_440_333.jpg
Not bad :D
One of the big advantages of the Abit over the P5W-DH is that you can use ESpeedStep and C1 with any voltage or with any multiplier - that helps a lot to keep the CPU cool:)
I will test the board with single phase and will post results..
Originally Posted by tictac
12 Beta is not the Same like 12 Final ...
this BIOS is from yesterday (Postet from Abit Worker in German Forum)
This is the result with my abit.
Setting:
enermax 600w coolergiant
abit aw9d max
conroe 6800 b2
thermalright xp90c
asus 7600 GS
http://www.pctuner.info/test/results...203206_445.JPG
bye
roro,
what are your voltages' settings?
Sorry, double post.
the voltage setting is 1,58 volt to vcore cpu for the 445 Mhz fsb screen's
This is the new screen with this mainboard, full air cooling. I have changed the original thermich pad under the chipset with the artic silver 5. The new result with this event is 454 Mhz full air.
http://www.pctuner.info/test/results...232255_454.JPG
Bye and sorry for my bad english.
roro,
MCH and FSB voltages?
Mch is 2 v. :)
http://img1.spx.pl/u/lol_16054t.jpg
Vmch 1.9V
Update with ln cooling. The mb is very very good.
http://www.pctuner.info/test/results..._abit10047.JPG
:D
Wtf :eek:
What setting's in bios ?
Stock board's no mod ?
Yes, no mod. In bios vcore max, mch max ....... :D boot in bios at 458 Mhz.
I got mine only yesterday!:)
E6600 B2 (week:25)
Abit AWD9-Max
Water Cooling Corsair COOL
2x1Gb Mushkin Redline XP2 8000
OCZ Modstream 520 12U
Here are my results:
[IMG]http://img77.imageshack.us/img77/955...pi13093qh3.jpg[/IMG]
[IMG]http://img152.imageshack.us/img152/3...arabit2im6.jpg[/IMG]
[IMG]http://img154.imageshack.us/img154/3...draabitxt1.jpg[/IMG]
Vcore:1.62, NB: 1.95V, Mem.:2.45V
How can I disable the Thermal Management (Thermal Monitor)??
