no tweaking @ 1m?
no tweaking @ 1m?
Somebody know what is the WR max Mhz DDR2 speed?
i GUESS its 670mhz with A-DATA EPP...but im not sureQuote:
Originally Posted by over@locker886
Don't be so scared of 32M, Vince :D With those mems and MAXI, I'm sure you could submit a sweet, 600+MHz result to EnJoY's database :fact:
Did I mention already, great results? Haha, I guess I did, already 2 times - never enough :lol:
Thx;) I found same.Quote:
Originally Posted by ocfx
Originally Posted by bachus_anonym
thanx bach,
hehe.. you know I leave 16m and 32m alone.
32m doesn't scare me :D, 3dmark 03 does.
@kunaak:
Are you using the ddr2pcb when you say you dont need to desolder the coil on your p5b?
yes.Quote:
Originally Posted by k|ngp|n
Figured you had to be or had it wired in somewhere out of the pic. All my tests on both p5b and p5w are done using no maximizer pcb at all, just straight vdimm feed to the slots directly from the maxi in case anyone was wondering. It may bypass some of the vdimm vreg ciruitry on the mobo this way as well. I am sure HIPRO could answer that. My ddr2 pcb should be showing up soon.Quote:
Originally Posted by Kunaak
Originally Posted by VictorWang
Interesting, I am getting this at 3.6Ghz, 540 5-5-5-15, p5b dlx. So 490 3-3-3 is pretty much = 540 5-5-5
http://img208.imageshack.us/img208/8835/36ghzvf9.jpg
You're right of .......everything you said.....:DQuote:
