coolaler, do some 7x and 8x multi max oc tests!
im sure a lot of us would appreciate it..:woot:
What's up with this? He's using an X6800, it should be able to go way beyond x11 multiplier? :confused:
Don't you get it?!...Is running the CPU at default..Quote:
Originally Posted by drwowe
Look at the picture again. It says MIN=6, MAX=11. :stick:Quote:
You are talking about LDT/HT frequency. You can't do 3x500 because there is no 500 in bios but only 1300 quad pumped = 325 :) Your max cpu speed would be 9x325 assuming you have 6600
common rule of thumb was ldt multiplier x fsb should = lower then 1000 when overclockingQuote:
hey cooler, do the new dfi boards still support the cmos reloaded function? i think thats what its called
the bios presets you can label
i LOVED that
Move along there¨s nothing more to see here :slapass: :(
pretty dissapointing :(
Exactly. This is why I decided not to go for this earlier on in the month.Quote:
Originally Posted by lowfat
P5B Deluxe FTW now.... No SLi, but with most of you waiting for DX10 and me having a 7950GX2. Everyone's a winner! ;)
yea with the new bios update, the p5b is replacing my ds3Quote:
Originally Posted by Moonrakerâ„¢
P5b/P5W ftw....
you never know things might change with this board too.
I have just preordered my Asus 590sli and after looking at this itseems quite scary , unless the temps are real and thats what is stopping coolaler
You only see 1300 quad pumped... If that is the only visible option, what's wrong with that?!.. You have the LDT multiplier option... Who need's FSB?!Quote:
Originally Posted by kiwi
There's 3 variables in equation regarding FSB, LTD Multiplier, Quad pumped FSB and nominal FSB. We can always change two, the third will result from other two.
If you have 1300 Quad pumped FSB limit and lower LTD to 3x, what FSB you will have?!... 1300/3= 433 FSB x9 (CPU multi) = 3900mhz!!
Get it?!
Yep, my bad! Sorry!!Quote:
man i hope it goes higher, i have the P5NSLI (570) and my max stable for 24/7 is 333mhz. I just bought the board because it was cheap and hoping it would last me till the 590 was out... dont tell me mine goes higher
Damn, I was drooling over this thing. I thought THIS is my board. :dammit:
ok that makes no sense.
the LDT multi and Freq. has no effect on your FSB.
just cuz you set 1300mhz LDT doesnt mean your FSB instantly jumps up now does it ? no
it didnt mean that on amd and it doesnt mean that now.
Well, I like my DS3. Thanks, coolaler. :)
push it further.. :D
nice job !
temperatures looks pretty hot for a small oc :/
bad sensor/bios ?
Well...What can i say?!... Reading you, makes me think that is as been a waste of my time.. :(Quote:
Originally Posted by Lestat
Do you care to read my posts, again?!.. It's appears you didn't understand..
DFI's tool reads within 1 degree of coretemp with my 975X/G. Those are very similar to the temps I get with my system on stock voltage and my ultra-90.Quote:
Originally Posted by herderien
Sir Coolaler , do you think it will get better? or this is it.
Man , i have ordered mine and this is making me regret it , but its cool in the gaming department , isnt it? I have a 7950 and thatswhy i have optedfor this route.
ALso the PSU is sexy
300fsb was just a small test I think. He isn't done for sure ;)Quote:
Nice going Coolaler, now crank it up ;)
