Originally Posted by Nasgul
I used my Corsair XMS2's which are rated at 2.1v and it booted fine, sure I got an CPU error but that's becaues of the 0204 BIOS and use my 256MB flash drive to update the BIOS and everything worked.
Do you see the blue ASUS logo light up inside? If so, try checking the power switch plug, the one connected at the bottom right hand side. The Reset and Power pins are so close to each other that I didn't plug the Power correctly which caused my system not to boot but the LED light was on.......so check that up. should be: .._.. / Space in between the Reset and Power pins.
