Originally Posted by jimwah
Are you running 1:1 PhydomiR? ie 1240/620 (fsb/ram) at the mo? Set mem timings manually, loose enough & correct vmem for the GEIL?
My NB voltage is ~1.55v, memory 1.9v, and vcore default at 7x345mhz (or 1380/690 in fsb/ram terms). Also fsb termination is @ 1.215v, this is from memory so forgive any mistakes - I can't reboot this machine atm to check.
With a higher multiplier chip I suppose you might need more vcore, I'm not sure when the vcore requirement ramps up for higher mhz C2D, since mine is only 2.4Ghz atm. GL
