Thanks for the help, still a no go. What about dual priming with 2, sp2004. I can get CPU 1 to prime but CPU 0 will not (at the same time). I get no errores it simply stays stuck at test 1. I can get each to prime separately no problem.
Thanks Absolute_0 !Quote:
Though you not so far as my 7900 Gt mod 1.5v is just set @700/1700...;)
( solder mod )
Regards
E6700 OEM at 3.6GHz dual prime stable
PCI Express freq = 100
PCI = 33.33
Performance = Auto
FSB = 360
RAM = 900Mhz
Vcore = 1.5375V
Vmch = 1.55V
Vdimm = 2.0V
Vfsb = AutoHyperpath 3 = disabled
RAM Throttlig = disabled
EIST = disabled
Virtualisation = Enabled
I can get it up to 380x10 (haven't tried any higher) and it will run dual SuperPi 32M and all of the 3DMarks but it craps out of Prime/Orthos within seconds regardless of voltage.
At 3.6GHz my idle temps are 32°C and when under Orthos it reaches upto around 55°C (room temp is 23-24°C).
http://i11.photobucket.com/albums/a1...AM3_127096.jpg
This is at stock clock. Use this to determine how well you OC your e6700. I figured out what was wrong. AM3 does not like ATI Tool/Cat 6.3 (shrug). As long as I don't use iit I am able to bench.
http://i11.photobucket.com/albums/a1...AM3_130481.jpg
Again CPU at stock. VC Overclocked...This doesn't show the red screen I get using ATI Tool to OC it. Oh well.
E6700 Retail at 3.65GHz dual prime stable
PCI = 33.33
Performance = Auto
FSB = 365
RAM = 2.00
Vcore = 1.55V
Vmch = +.2V
Vdimm = 2.2V
EIST = disabled
Virtualisation = disabled
on ds3 355~360 max stable with TT BT, but 365 on water so far and still tuning.
what MB are you using, this is pretty good.Quote:
Originally Posted by Hassan
ds3 I think
THought so, I was wondering why you set the PCI Express freq = 100 instead of leaving it at auto.Quote:
Originally Posted by Mykou
MY MSI bios is pretty bare so if I don't include something chances are i don't have the option, lol.
E6700 retail@3.6ghz 27/7 gaming stable
Vcore 1.52
Memory 2.1
360 fsb 4:5 ram
MSI 975X platinum V2.1
http://img130.imageshack.us/img130/1...ture007yy0.jpg
Having fun with G skill PC 6400@PC 8500 ( 800@1050 4-4-3-15 :woot: ) and booting at desktop without any pb :D
Manual settings
1.4V bios 1101 :slap:
http://img143.imageshack.us/img143/200/snap3hn1.jpg
Not superpi 32 M stable nor orthos lol but could'nt even boot at desktop before with such frequency and timings ;)
Improve my aquamark too still leaving my chip@3.5 ghz ( Still 7900Gt@700/1700 1.5V mod) :)
http://img81.imageshack.us/img81/5136/aquakt9.jpg
Could load and run Prey for 10 min all settings high but my eyes just tired then I go on later ...:nono:
hmm if only I had Vdimm modded .. :D
G skill :banana: :banana: :banana:
wow all the oc 6700 AM3 scores are very consistent...I guess week23 was good week :)
Guys are you actually seeing an increase in FPS in games? For example stress tess on CS:S or Half Life: Lost Cost
Here is an example:
http://i11.photobucket.com/albums/a1...700/HL2_LC.jpg
again CPU regular clock
Use this to bench against it when OC so you can see if you are noticing increase in performance.
I'm topping out around 3.7 Ghz, this with 1.57v in BIOS
i stopped it but idk how much longer it will run, i'm going to try more in a sec
http://img.photobucket.com/albums/v7...l/9970b2ae.jpg
had to clockgen from 3.46
I noticed Games do run alot smoother than with my old 2.9ghz opty, esp Oblivion.
Absolute, getting pretty toasty. Anyone know at what temp these chips throttle down at?
I believe it's 60.1C I believe
Temps are way off, i think it's closer to 50c :D
Here we go with 1.60 volts set in BIOS
http://img.photobucket.com/albums/v7...l/49112660.jpg
http://img.photobucket.com/albums/v7...l/c19fbdfe.jpg
:clap: :clap:Quote:
Absolute_0 Temps are way off, i think it's closer to 50c :D
So what ram frequency and timings do you run ATM ?
I have 26° ambiant , so I won't try 1.60 v Absolute_0 :nono: :nono: :p:
E6700ES B1 St5 (1stage phase-change)
Asus P5W DH no mods
Corsair 8000UL
Vcore = 1.55V (BIOS)
Vmch = 1.65V
Vddr = 2.4V
Max screen: http://valid.x86-secret.com/show_oc?id=109883
Benchable:
http://img421.imageshack.us/img421/9450/pi32m01jj6.gif
:woot: :woot:Quote:
Originally Posted by Big_Sam
Vcore 1.55V !! :eek:
what bios do you have ?
hmm stepping 5 ...:D
BIOS - 0701Quote:
Vcore = 1.250V - 3.6G
Vcore = 1.375V - 4G http://img97.imageshack.us/img97/209/spi02xy6.gif
Vcore = 1.550V - 4.3G
These are values which are established in BIOS, real on 0.02V below in range 1.5V - 1.6V in BIOS.
So when I set ATM 1.51v in bios , my real vcore is just about 1.49 or just depends on what bios is used ?Quote:
Probably it depends from concrete MoBo, I do not know it. I use digital multimeter for measurement Vcore.Quote:
Under loading Vcore falls still on 0,02V ! :)
Do you think pc probe enough accurate to show vcore ?Quote:
I do not believe programs :D
brand new whitebox E6700ES Step 5
first boot
http://simon.webideal.ca/Bench/6700%201m.JPG
it's priming as I write @ 3.7ghz 1.45v bios
Sam, is 4G with 1.375 also on Phase ?
I need 1.55V for 4Ghz on water, that's why I'm asking. Same cpu btw, but Intel Bad Axe 302 modded as mobo.
Still have to upload my screens. I'll post it later :)
