I have actually two of these boards, but I haven´t even tested the other one.Quote:
Thanks for mod, pics are great as always :)
Even children from kindergarten would understand them :p:
Nice one there.Quote:
Originally Posted by The Stilt
What was the VDIMM at? And what's the max possible with the mod?
Since the TForce 590 SLI Deluxe also has similar 2.3V jumper, do you think the same mod can be applied to the mobo?
Btw, I'll be getting a TForce P965 pretty soon... :toast:
The same mod should work with all Biostar boards with similar overvoltage jumper. The original resistance should be checked before doing it thou.Quote:
Originally Posted by pcmoddingmy
The maximum voltage?
Enough :D
sounds like a great board. Can't say I've seen much for Biostar boards for sale here in Canada though.
Ahh, forgot to mention the MOD - impresive !!
Any other mods, simply as hell ??
Nice board indeed with bios update. Gosh i should have bought this board when i was deciding what i'am gonna buy P5B or this one.
wonder when newegg will get this board in stock?
:eek: :eek: :eek: :eek:
what about second board?
does this motherboard use sub 1:1 dividers
How did you do to have 6-7 multi in cpuz with your E6700 , i presume you modded bios to boot with 7X multi ?
And what are your bios setting to do 533mhz fsb ?
RAM dividers have you got them under 1:1 or no?
hey Pt1t what's your mobo like with new bios stilt is using
I´m using E6700 ES B0 stepping which has unlocked multiplier.Quote:
Originally Posted by Pt1t
The multiplier can be selected from the bios.
If I boot with 10x multiplier CPU-Z will display 6x - 10x multiplier.
If I boot with 7x multiplier CPU-Z will display 6x - 7x multiplier just like in those screenshots.
Where in the bios ??? , mine ES step 5 got also unlocked multiplier.
And the others setting ?
do you use tforce oc software to do + 500 mhz or other one ?, because it s max 500 in bios.
Did you change bios since the last you gave me ?
The Stilt used mine bios , 08-03 , but he changed some ram timming ,new memtest ,Quote:
Originally Posted by dinos22
for fsb i think it s the same.
My board can do Pi @ 8*490 , ram 1:1 in aircooling. But i cant do more than 500mhz , with 6X 7X ... . Maybe it s because he waterccoled the chipset, mine is stock cooled with a7n8x 's like heatsinck :D
is this a chipset limitation or what for 965 not to be able to run below 1:1 ratio :stick:
Back when I was looking at 939 and AM2 for a new build I was actually shocked to see the awesome OCing reviews their $75 754 and 939 Tforce boards were getting. Glad to see them delivering on the Core 2 duo side of things also.Quote:
european users
there are 2 interesting threads
here in german :
http://www.forumdeluxx.de/forum/showthread.php?t=255386
here in french :
http://www.overclocking-masters.com/...-duo,t3427.htm
thanx to bodo666
thanx to Stilt
now waiting for the "clouded in mystery" Foxconn 965
French is my thread :D and german spoke about my thread on xs and about this one :DQuote:
Originally Posted by mine
Stepping 6F5 (B1) is not unlocked, the multiplier can be only adjusted with EIST.Quote:
I used Clockgen to raise the FSB from 500MHz.
I´ll try to extend the bios FSB range from 500FSB to 600FSB later today.
Thanks,Quote:
but clockgen with pll ?
and your bios setting, do you put all voltage (exept vcore) on max ?
I´ll post them later today.Quote:
I´m currently at work.
:D me too :toast:
Stilt, you were running SLI on the Biostar according to this post: http://www.xtremesystems.org/forums/...8&postcount=64
Did it work right out of the box with Big Sams' modified drivers?
And are the cards detected in the 4x slot? It only uses about a third of the connectors, so its hard to imagine.
If that works without much performance loss, the Biostar will be THE budget board to get :)
SLI works with any driver which has the internal checks disabled.Quote:
Originally Posted by Fr3ak
To make SLI work the PCI-E buses must be enabled by bios.
Of course the board must be made physically compatible first ;)
so it's 130€ ?
