Sure nice, Intel has plenty of reserve left. Any chip could be XE cpu, no probz getting that speed at default volts :)
I am currently testing 7x472 = 3.3 for 24/7 stability and it seems fine so far
Great job Kunaak, Ds3 is a funny little mobo :)
:toast:
Kunaak, did you use the vdroop mod too? If so how much of a difference did it make to your overclocks?
regards
Raja
show bios setting please....:clap:
I still haven't had much luck finding a good lead on the Vdroop mod, so I still havent been able to do that.Quote:
Originally Posted by raju
32M at 515. :D
http://www.xtremesystems.org/forums/...1&d=1154760545
Update
Bandwidth Shot for FUGGER ;)
(I see why you wanted everest... Sisoftsandra doesnt read anything other then the boot up speed... so no use using it with clockgen)
http://www.xtremesystems.org/forums/...1&d=1154762765
how did you get CAS5 to show in CPUzQuote:
Originally Posted by Kunaak
Memset, then close memset window by pressing XQuote:
Originally Posted by dinos22
Amazing :eek:Quote:
Is that the BIOS Voltage, e.g. Vmch not working!? I'm using DS4, adding any Vmch(+0.2,+0.3,+0.35....., I didn't get higher FSB.
Dinos
werent you doing 515 UNMODDED ?
thats gotta be the unmodded record dont it ?
and kunaak,
why you gotta live so far north i need mine modded.
so how did your north bridge temps react to the extra voltages ?
along with other parts of the board.
same for vdimm increase ?
Nice clocks, what make heatsink do you use?
TINTIN, the MCH voltages work just fine for my board.Quote:
Originally Posted by TinTin
after adjusting my VR, I have about a .3 offset, for 1.45 volts to 1.75 volts max. to adjust the voltages I just use bios + the offset.
set 1.45 volts, + the .3 offset and get 1.75 volts max.
this board has a OVP at 1.76 volts or real close, so I am definatly pushing my luck when maxing out the voltage.
pass the OVP limit, and the board will fail to post, no matter what.
you have to get below the OVP limit to make the board post again... so adjusting the VR to get lower then 1.75 volts is what it takes to get it to post again when you go too far.
What Heatsink am I using?
Thermalrigh SI-128 + 120mm Adjustable Enermax fan (nothing like a tornado fan)
Really impressive, good work.
520MHz 1M but not me....previous owner...yeah this is a great board i have as wellQuote:
Originally Posted by Lestat
