Crediki if you don't paint your case I am going to :slapass: :slap:
I have no intention what-so-:banana::banana::banana::banana:ing-ever of painting my case.
Why would I bother with something that gives me no performance or noise advantage? I dont do "looks" improvements.
maybe you can build yourself a big box to put your case in there and call it "Dead Man's Chest" :)
Positioned the rad.
haha give us a play by play!
Do those EK barbs fit the Storm with the supplied o-rings or did you get different ones?
I had to use both the ones that came with the barbs and the stock storm ones.
Are these the newer EK barbs or the older one..the newer ones..bought in the group buy have a larger O-ring that may be adequate and not need both stock Storm O-ring and EK O-ring..should not as per Eddy..but always leak test to be sureQuote:
Originally Posted by creidiki
The MCW60 will require both O-rings from reports
Newer, 14mm OD. They will probably fit a Rev. 2 without need of extra O-rings, but I have a Rev. 1.
Its borderline anyway, the outlet barb was sealing but the inlet wasnt.
Oh..missed the fact you have rev1 storm
I assumed it was revision 2:slapass:
The newer EK barb should seal fine on Storm rev 2 with just EK barb
Very nice bro. The project looks good. I like the performance over everything else attitude.
Good work. lets see it done.
Screwed in the fans yet? :p:
No way lol, its 30c here, im too busy eating ice cream and trying not to melt.
Bah 30c, thats nothin, we hit 39c here yesterday. A real mans comfort temperature.:rolleyes:
about 30 here too! who said it was cold in norway?
Not if you are used to 15-20C... the UK just isn't geared for that kind of heat... or the cold for that matter..., in fact, come to think of it, anything out of the norm really...Quote:
Originally Posted by Batman!
95+ degrees F here. humidity about 75+%, and still have another 4 weeks+ of summer................oh yeaaaaaaaaaaaaaaaaaaaaaaaaaaaaa NOT!
norm=raining. if it get's too hot here the roads melt. You think I am messing?
Creidiki needs a vacation! Pronto! :p:
:D
I'm drunk, I think this is a good time to fit my FCX1800 block :lol2:
Just perfect... :)
Beware of the mofsets. ;)
Yarrr! Someone hand me the pickaxe!
argh, why are all floppy cables 45cm long >_<
Because that would make life easy to have them any other length. And we can't have life being easy...can we?
-Ghent
Ayup, that would be wrong :o
I ended up using a flat ribbon cable lol.
