450fsb @ 1.6vQuote:
Originally Posted by Rol-Co
Yep i know where to buy it, IN belgium :banana:
450fsb @ 1.6vQuote:
I'm having issue with not being able to set cas manually in bios. My Mushkin HP5300 I'm trying in there has spd of 3-4-4-8 at 4200 and when I set ram multi to 233 ie 4200 to max fsb I can't get even 333mhz stable due to ram :(. Even at default fsb, I can't assign cas manually to 4,5 or it won't post.
will try new bios and report back
retail 6300 on watercooling
http://users.skynet.be/pt1t/biostar/Ip96a803.rar
but i allready posted it on previous page.
wow that's a big difference with the new bios
Thanks for the bios Pt1t :toast:
Here is a modified version with following changes:
**Unofficial Release**
For: Biostar TForce P965 Deluxe (Broadwater-6A79L0009C)
Bios version: IP96A803TSA
Changes compared to bios IP96A803
Fixed 1001 one typos
Added DMI information
Updated Memtest86+ v1.60 -> v1.65 (for Core 2 support)
Added RAS to CAS Delay (tRCD) 1 & 2 CLK options
Added RAS Precharge (tRP) 1 & 2 CLK options
Added Write Recovery Time (tWR) 1 & 2 CLK options
Added Internal Write to Read Command Delay (tWTR) 1 CLK option
Added Spread Spectrum option
Added Auto Detect PCI Clocks option
Added Enable / Disable L1 & L2 Cache option
- The Stilt - 08/04/2006
I´m currently using this very same build and it is working fine.
IP96A803TSA
Use included WinFlash to update the bios.
Ensure that you have "Update All" box ticked.
:toast:Quote:
Originally Posted by The Stilt
Link and price? realy interested, got a crappy infinity and a good asus here, wanna try this one.Quote:
Originally Posted by Pt1t
http://users.skynet.be/pt1t/biostar/memtest.jpg
Memtest is working fine :D
can you run memory below 1:1
no , there is only , 533 - 667 - and 800 in bios. :DQuote:
Originally Posted by dinos22
Linky not workin'Quote:
here you go:Quote:
Originally Posted by LowRun
http://www.compumsa.be/scripts/foxis...Item?id_art=43
SLI on Biostar TForce P965, sure :D
http://service.futuremark.com/compare?3dm05=2143183
http://www.armada.fi/TForce_P965/TFo...00GT_SLI-2.jpg
The slots are actualling working with x16 & x4 speeds, so it is not a bug.
http://www.overclocking-masters.com/...-duo,t3427.htm
my thread on overclocking-masters :D
super 1M @ 475 fsb, it can do little more but i directly tried 500mhz and ... it crashed after 1sec :mad:
http://users.skynet.be/pt1t/biostar/1M_475X8.PNG
i don't understand.........so you're saying 1:1 and higher......533 should be 1:1 yeah?Quote:
it s 533 minimum for 266fsb
Not working either :confused:Quote:
Originally Posted by Ferry82
What's the error?
The site has just opened, so the dns are maybe not redirected for usa...
One question to The Stilt: How can you run sli on it when it only has one PEG-slot?
Cut the plastic at the back of the PCI-e x4 slot so you can put a PCI-e x16 card in it ;)Quote:
Originally Posted by elmor
wow this board is really giving the pack a run for their money!
hhmm newegg doesnt even have this baord... odd.
because i have a 6600 i always gotta ask.
what are you guys, in general seeing for 9x multi's for max bootable FSB>
i just bought this board, gonna test it now and will sell this if it is worse than my DQ6! :(
So, most of the pins are just for show, or are they only needed when running it in a higher-speeded PEG?Quote:
Originally Posted by DaWaN
