Originally Posted by Metroid
Sorry my bad.
I have confused 1 with the other.
This is 5 Phase power for budget. The official date is july 23 but I think it is coming before. The prices will be around 70£ or 120$. It can overclocks up to 320, but with a new bios might go as high as 975x is, may not be stable as 975x is.
Look more below.
PCI Express Frequency (Mhz)
Auto Set PCI Express frequency automatically. (Default value)
90~150 Set PCI Express frequency from 90 MHz to 150 MHz.
System Memory Multiplier
Wrong frequency may make system can't boot, clear CMOS to overcome wrong frequency issue.
for FSB(Front Side Bus) frequency=533 Mhz,
3.00 Memory Frequency = Host clock X 3.00.
4.00 Memory Frequency = Host clock X 4.00.
2.00 Memory Frequency = Host clock X 2.00.
2.66 Memory Frequency = Host clock X 2.66.
3.33 Memory Frequency = Host clock X 3.33.
2.50 Memory Frequency = Host clock X 2.50.
Auto Set Memory frequency by DRAM SPD data. (Default value)
for FSB(Front Side Bus) frequency=800 MHz,
for FSB(Front Side Bus) frequency=1066 MHz,
4.0+ Memory Frequency = Host clock X 4.0+.
Memory Frequency (Mhz)
The values depend on CPU Host Frequency (Mhz) and System Memory Multiplier setting.
BIOS Setup - 45 -
English
DIMM OverVoltage Control
Normal Set DIMM OverVoltage Control to Normal. (Default value)
+0.1V Set DIMM OverVoltage Control to +0.1V.
+0.2V Set DIMM OverVoltage Control to +0.2V.
+0.3V Set DIMM OverVoltage Control to +0.3V.
+0.4V Set DIMM OverVoltage Control to +0.4V.
+0.5V Set DIMM OverVoltage Control to +0.5V.
+0.6V Set DIMM OverVoltage Control to +0.6V.
PCI-E OverVoltage Control
Normal Set PCI-E OverVoltage Control to Normal. (Default value)
+0.1V Set PCI-E OverVoltage Control to +0.1V.
+0.2V Set PCI-E OverVoltage Control to +0.2V.
+0.3V Set PCI-E OverVoltage Control to +0.3V.
FSB OverVoltage Control
Normal Set FSB OverVoltage Control to Normal. (Default value)
+0.1V Set FSB OverVoltage Control to +0.1V.
+0.2V Set FSB OverVoltage Control to +0.2V.
+0.3V Set FSB OverVoltage Control to +0.3V.
(G) MCH OverVoltage Control
Normal Set (G) MCH OverVoltrage Control to Normal. (Default value)
+0.1V Set (G) MCH OverVoltrage Control to +0.1V.
+0.2V Set (G) MCH OverVoltrage Control to +0.2V.
