Originally Posted by Roger_D25
Thanks for the correction t024484, I have assumed for sometime now that you had to modify both the card and BIOS to get the 2d/3d voltage change to occur on cards that didn't come that way? For example with my 2nd RMA'ed 7900GT (7900GT CO) I actually tried flashing the BIOS with the eVGA 7900GT SS version hoping to get the separate 2d/3d voltage changes. Unfortunetly nothing happened (had 1.2v on both 2d/3d), from what I understand it would have been possible but only by modifying the card with some additional components, and then modifying the BIOS.
I could have misunderstood Orian24 but I thought he was asking if it was possible by only modifying BIOS? In fact you are one of the few people who have come up with a step-by-step method for adding the correct hardware so that their non-switching cards can switch voltages in 2d/3d modes?
On a different note, it is possible to modify my 7900GT SS card's 3d voltage, (which already has the added components for separate 2d/3d voltage switching) so that it goes from the stock level of 1.45v to say 1.5v or 1.55v corerct? I have a feeling you have explained this many times but I have been unable to piece the info together enough to make it happen.
Do you remember if you have already posted this info t024484 in this thread or on extremesystems somewhere? You certainly don't have to explain it once again but if you could point me in the right direction that would be great!
