No problem at all in ubuntu with wine emulator.
Thanks a lot.
Thanks a lot.
Props to you mate this thing is very helpful! :up:
I'm sorry, but I fail to see how this is helpful. If you have any of those scores, you would've run the benchmark, right? So, you should've gotten your results right?
Maybe someone can explain?
It helps you calculate the impact of every score in the total score. Of course those calculations are pure theoretically (ex: with the same VGA but different CPU you will have different SM2/3 scores)
It is also helpful for those who have a target score and need to improve one of the 3 scores.
Example : You have 5000 SM2, 5000 SM3 and only 2000 CPU. If you want to see how will you're system will aprox. score with a better CPU you only have to input a larger CPU score (3500-4000 for example).
thanks a bunch for this!
http://i223.photobucket.com/albums/d...DM-06_calc.jpg
and the result of futuremark:
http://service.futuremark.com/compare?3dm06=5505215
:up:
Thanks, it's very useful for me...;)
quite nice, now we can see what we get
:DCode:---------------------------
3DMark2006 Calculator
'h4x0r' is not a valid floating point value.
OK
Now just add a hardware database to it, so we can select cpu model, frequency, ram ammount, timings, fsb, chipset type, gpu model, shpu clocks, and it calculates the score for us - that might friend, will deserve a $10 donation from me :)
That cant be made, because :
- tweaking
- optimal fsb:ram ratio
- gpu, memory, shader clocks
- vga memory timings
- drivers
- os used, etc. :).
This program is more for verification and/or to check how many points you need to obtain a score, and where..
good tool
nice work mate :up:
r the links working or not???
i think links r dead or some thing is wrong ...
This thread is 2 years old so no links dont work
The first link is working well, the second isnt..
Well, with formulas you can make calculator by yourself
you need just excel :)
but I had some problems with Vantage final score
GPU and CPU scores are almost ideal
Weighted GPU and Weighted CPU must be constant, but it seems they vary depending on whether CPU score is higher or GPU
Final score is calculated by formula
3DMark Score = (Weighted Graphics + Weighted CPU) ÷ ((Weighted Graphics / Graphics Score) + (Weighted CPU / CPU Score))
in performance test must be
Weighted GPU = 0.75
Weighted CPU = 0.25
but let's see some pictures
here
http://hwbot.org/signature.img?iid=3...se&iehack=.jpg
CPU score is 33% more then GPU score
and we have some changes
Weighted Graphics is about 0.8
Weighted CPU=0.2
another one
CPU score is 3.5 times higher then GPU score and
Weighted Graphics=0.93 !!!
Weighted CPU=0.07!!!
and final example
CPU score is 63% of GPU score and
Weighted Graphics becomes 0.66
and Weighted CPU=0.34
so if CPU score is... well let's see... about 2 times higher then GPU score then you don't have to push your CPU any harder
it won't make sense...
but if your GPU score is much higher then your CPU score you can improve 3Dmark vantage result by pushing CPU harder or changing it with better one
3D mark 01, 03, 05, 06 and Vantage calculator
see attachment
3D mark 01, 03, 05, 06 and Vantage calculator V. 1.1 :D
Fixed bug:
Calculate 06 score when HDR/SM3.0 Score N/A
Added:
Calculate 06 score by FPS in each test
Thank u soso ! :)
that's pretty cool
