Originally Posted by audiofreak
I think that the problem is with the photographer, not with the camera.
1. You have uneven lighting (right side of picture is darker)
2. You were too close to use the flash (better to move away and zoom in, or turn the flash down a notch if possible)
3. Exposure was bit too long (right ear is blurred)
4. If camera has bracketing you should have used it (or if it doesn't you should have fired one underexposed right after the first one and compose them).
5. If you used macro mode, then you were definately too close (barrel distortion on the shelf is visible and cat head looks larger than it should)
Most of this can be fixed one way or another but the burned details in the white fur cannot be restored in any way.
