:( unfortually i dont have a cam
its like on 2 corners where the ceramic comes from 2 corners into a point , that point is slightley chipped off revealing only a !VERY! small ammount of metal
the only thing i can think of that will stop this working is if the pelt had an atmosphere that was made for it inside it when sealed
to be careful ill put the chipped side on the cold side because i know epoxy fails under heat , have no idea under cold
i just woke up and im inspecting the epoxy
ich epoxy tastes weird
Does anybody know the fail temp of West systems 105 using slow hardener 206?.
i looked around and couldant find anything. about the fail temps
there's some on my old server i used as a workbench its a Compaq prolaint 3000 so its big enough when i get home i think ill see if its set and get my infra thermo and heat it with my heatgun untill it fails then il get some baseline
Woot another injury
oh well i think its sealed ill do more sealing later tonight ill go and make this heat sink smooth :( the only other massive heat sinks on my powersupplys rectifier meh and ill need that for to power it up,,, meh maby a few seconds wont hurt just to see if it works MEH what better way to check it then replicating it on a :banana::banana::banana::banana:ty 40w :D HOLY @@@@ TECS ARE FRAGILE, mk the 40ws unsealed now , ill power it up
