What about modding HR-03 plus to cool CPU :shocked::shocked::shocked:
I have HR-03, but i dunno how to bend the heat pipes so they don't touch the mobo's mosfet heatsink ????
Can anyone make a guide how to bend heatpipes without f*ing them up?
I just do it by hand...
If you want a more technical way to do it you might have luck using some pipe to brace against or help apply force against a fixed item (bench vice or whatever is handy).
wow such nice ghetto mods!
i especially love the NB heatsinks on the HDD's
i was thingking about that...
added an accelero to nb of dfi x38:eek: cracked 1 heat pipe:shakes:
wasnt doin a good job so i modded a xigmatek 1283:D
http://i74.photobucket.com/albums/i2...CIMG1200-1.jpg
Cut from a 1U heatsink with a dremel. For digital vrm's on video cards, and other small hot things.
zsamz_, how did u mount the XIGMATEK 1283 to the mobo? i wanna copy u:D
first i moded a 939 backplate "not puttin it on without a backplate"
i had to dremel the sides cause its too wide to fit the srews gotta be carefull not to cut the heatpipe i almost did :rofl:
when i take it off soon i'll post the pic i'm dumpin my x38 cause it dont like my e8600@ high fsb
i'll slap it on my ut p35;)
Those are crazy coolers! :up:
Northbridge heatsinks from Dell P4's.
Cut with dremel and mounted with AS thermal adhesive to motherboard mosfets.
http://i74.photobucket.com/albums/i2...o/CIMG1203.jpg
http://i74.photobucket.com/albums/i2...o/CIMG1205.jpg
Plan.B, What is dark sh*t around the cpu? :D
it's coax-seal, for insulation yes
Made this custom heatsink for my striker 2 extreme northbridge, the stock one sucks and gets really hot, i think its going to work well, will be testing this weekend.
got any differences in temps?
Yes there is quite a difference in temps, idle is about 37c, full load is in the 40s depends on what your running, so made a big difference. Stock i was hitting 60c +.
Hi all, that's my first post... i want to show you what one boring day and a 4830 with a Twin and a HR-03 gt can do...
http://img26.imageshack.us/img26/9157/pic0269.jpg
http://img530.imageshack.us/img530/2928/pic0247.jpg
http://img530.imageshack.us/img530/6834/pic0238.jpg
Tell me what's do you think.
Pretty nice job you did there, what kinda temps you getting ?
Idle 27; Full 30, max 32...
Amazing temp, aren't they?
Very nice job there Pardulo :clap:
Thanks a lot...
I hope to use another HR, maybe soldering both to have a unic heatsink.
Also, the temps are really good, here's a screen:
http://img25.imageshack.us/img25/7399/capturexwx.png
As can you see, the delta is about 3-4 degrees from idle to full.
