more like 1.775 to 1.825 for the 2300-7-9-6 would be the range I'm guessing. Hard to tell as it appears my set isn't that great.
well not quite 2300 but this only took 1.77v:D
hopefully the new set will be better
http://i51.tinypic.com/315bara.jpg
http://i52.tinypic.com/23kvfw4.jpg
Shaved 6 seconds I see :up:
At least 4secs is due to timings. The 20 mhz cpu is worth maybe 1.8 secs at best.
Hmmm it all depends. I think it can probably do 108 with these sticks.
Here's the run msimax and I did with that chip.
http://www.hwbot.org/community/submi...in_58sec_703ms
Hey guys... I just got this memory and im wondering whats the best settings for 24/7 use for gaming and occasional benchmarking ?
Thanks in advance.
6-8-6:shocked:
wow and I was getting happy about 6-9-6, these G Skills are turning out to be great clockers especially for the price, it doesn't make me feel bad for selling my hypers:D
http://i54.tinypic.com/2uqeirq.png
6-8-6 good luck, havent seen it run yet with sb..
you can do it B, I know you can :p
6-8-6 only got me barely over 1900ish mhz (blue 9-11-9-27 kit) Haven't tested the Flares with 8 setting...
I've been running these @ 7-9-7-24 1T @ 2133 for the past 4 days now without a hickup. I think they are doing just fine :up:
C6 results all updated page 1, that preety much concludes testing. Moving on to another kit and another thread but first i need to swap OS's as a 32 bit OS won't cut it for the next review.
How much can it do for superpi 32M with Thuban?
hope for about 1950-2000 MHz 8-8-7 for superpi 32M :)...
8-8 don't think so :p but I hope your kit can do it...
brian
have you gotten black pcb version?
drats..was hoping to see a better response against the hypers with the black kits :D
some quick runs here +2300 7-9-7-24-1t 1.78
http://i54.tinypic.com/1rutma.jpg
http://i55.tinypic.com/2a5yji8.jpg
good to see u back hiwa been a while m8! 7/8/7 possible?
