Don't know Puni.. mine also yesterday had one day to expiration date... :(
hello, yesterday mine showed only 1 day and today it says that i have 3 days...Quote:
Originally Posted by Punisher!
so try to reopen it or redownload it and try again to open it...meaby it will works... :)
Could someone dump the OCZ VX PC3200 for me or would it be ok to use the VX PC4000 dump on them? (dont know if maybe there's a difference in secondary timings.....)
UP please :worship: :worship:Quote:
Originally Posted by Langley
When im home, i will get the geil one es dumps from a friend
Thank you very much ;) :banana:Quote:
Originally Posted by Waus-mod
Does it work?Quote:
Originally Posted by [ITA]SEREUPIN80
I have a pair of Geil One-S TCCD 512MB,and this is the dump, may be someone need it
http://www.xtremesystems.org/forums/...1&d=1140420522
Hi, what's up??? Did you found the Dump of Geil One S or ES ???Quote:
Thanks ;)
@Waus-mod
I have 2x512 OCZ PC4000 VX mems, and I crashd one of them it with 3,7v vdimm in a dfi nf4 board, but it isn't any phisical demages on the stick, but it doesn't gave me any signal.. :nono: what do you think, can I fix it with this spd change??
and where can I find for my mem spd bios?
thx :rolleyes:
@achill3us : if one of them still good, you can make dump from it, then rewrite it to the bad one ...
@zungkono
I'm trying, I'm trying.. and I havent said that my bad stick works fine if i put it before useing in the icebox for 15 minutes :stick: but I shotdown my machine, restart, and no signal again..
Somebody can give me a 100% good OCZ5001024ELDCGEVX-K dump? pls :D
A picture of those pins that should be left open would be a good idea? :)Quote:
Originally Posted by Micutzu
(Not everyone sees those tiny numbers on PCB)
http://img106.imageshack.us/img106/3...19af5rd.th.jpg
The red pins need to be left uncovered. Sorry i couldn't find a Mushkin pic :)
Heh, i don't mind about it :)
@Waus-mod, can you put that image to first post as well?
My friend has give me the dump of 1gig OCZ 4000 VX Gold, but my problem stays, I think I must move my ram back to OCZ :(
But If somebody need this dump, here is the good one.. ;)
Could you clarify exactly when you inserted the stick?Quote:
Originally Posted by snatchmonkey
Anyone else attempted this?
yes, i think that it worked well last time that i used it:)Quote:
Originally Posted by Achill3uS
great ! thank you man... do you have some idea about the why your ram is dead ? i also lost one module 3 weeks ago...:confused:
my crapy mushkin pc4000 stick still doesnt work even after flashing! it works only if installed while red dram led is lighting! i guess it means that ps is turned on and there is voltage in ram slots! but after shutdown and and turning on, board just beeps error sygnal! so i have to get red led lighting again and then install the stick again!
I'm going to use an old-school BH-5 spd at a BH-UTT stick to see if it fixes the problems that the intel 865 and 875 chipsets can't do high speeds with this RAM.
I need a 256mb BH-5 single-sided spd proferably Kingston or another high overclocking BH-5 brand. I see a lot of spd's but no users have specified if they are single-sided or double-sided sticks.
Can someone please posts a 100% confirmed single-sided spd or can say which spd that has been posted already is single-sided?
Thanks ;)
Alex, it doesn't matter if the sticks are SS or DS, the SPD is the same; you can use any 256MB BH-5 SPD posted here, any of them will work just fine.
And by the way, SPD can make a difference in max clocks only with motherboards that don't have full options for setting the RAM timings or when you are using "Auto" settings. If you are manually setting all the timings, the SPD won't make any difference.
Edit: i've used Corsair 3200LL SPD on a 256MB single-sided BH-5 module i have made, and it works OK.
you wellcome :) I havent got a clue.. but it was interesting, I give them 3,7v on the window, it was -10C, the mem was icecold, and everything was fine, but after this shutdown, and restart doesn't work as befor.. :stick:Quote:
(a little off, but its amazing too the ups send the memory to ocz tech. in netherlands for ~70$ :slobber: )
I have a single sided 256mb bh-5 here, it was a-data in the old times :D i can dump for you today.. (on 3,8v can ~285mhz 2-2-2 :) )Quote:
Originally Posted by alexio
Thanks man, but not really needed. First I'm gonna extensively test the new BH-5 spd on the 865 chipset. This include maximum full PAT testing. I'll let you know how it went, or even start a thread if the outcome is thread-worthy.Quote:
okay, gl :)Quote:
hm I dont have long time ago the dothan rig, can you tell me about pat? how can I test this on 915 chipset?
@alexio
here it is..
Hi!
I have four sticks, two are mushkin blue (is bh-utt) and the others Gskill gh (bh-utt too), my problem is that i'd like to use the best module of each set, i mean, my best mushkin module and my best Gskill at the same time (like dual channel, since in reality are the "same" chip) but the problem is the spd because are diferent, mushkin is 2-3-3 and Gskill is 2-2-2 and if i put the sticks together i only get beeps from my motherboard, with this method can i flash one of them, for example mushkin with gksill gh spd?
Yeah you can do it, but AFAIK Mushkin Blue is CH-UTT ;).
resurect your ram? that is truly amazing, thanks for the tip! :D
Hi i have a pair of mushkin black level II pc3500 bh-5, and one of the sticks shows nothing at all when they are in dim slots no mather wich, one shows good and runs good at 278mhz on 3,7v, i can have both sticks in dimslots and all boots fine but when i check cpuz only one stick are there.
question is the one that there no showing compleatley dead or is there any way to bring it back to life again ????
Try if taiphoon detects it.Quote:
Originally Posted by chefnr1
actually what does you all mean by "dead" sticks?
no, taiphoon and cpuz dont detect at all, must mean it´s totally dead or am i wrong???
If neither cpuz/or thaipoon cant find the mem/spd there is something wrong.. Try other motherboards hopefully they will work!
ok will test that on my second rigg nf7-S ver 2.0 it.s my only that can take ddr sticks, i've just sold my rdx200 board, i'll report how's it goes..
nothing happens att all just beeping when the bad stick is in slot, i tested all slots, as i did on my ultra-d i think it's compleatley dead:(
we got the same problem today.
BUT WE GOT THE MEM BACK UP AND RUNNINGGGGG:toast: :toast: :toast: :toast: :toast: :toast:
TNX wouter:clap: :clap: :clap: :clap:
btw 3.8 allready 1M pistable with 780 and ln²:D
I have 2x512mb OCZ EL Platinum Rev. 2 (TCCD) and I've been seeing performance degradation for no apparent reason for the last 6 months. It's to the point where I can't boot into windows with a CL of 2.5 or 3 anymore; it'll only accept 2. I tried to rewrite the dump with the dump posted here but there's no improvements. Anyone have any ideas as to what I can do to get it to work?
Hi Guys,
Anyone have the dump file for Geil One ES and Geil One S ???
Thanks :worship: :worship: :worship:
i had to get my old AMD rig out with an abit AT7, because my sticks wouldnt show. when i used it in my p4c800 it wouldnt post and in my intel shuttle it gave memory beeps.Quote:
the one that i suspect is dead dont show on dfi ultra-d,rdx200, beeping on nf7-s v2,0 so i give up this chip:(Quote:
Originally Posted by Stigggeh
Strange...
My Muskin Redlines PC4000 can´t boot at 6 different Boards (3 x NF4, 2 x i875, 1 x i855) after a CmosClear. They started only from my DFI with 3 V, even I dumped them with the file from the first side.
I don´t know, what happend to them, I bought them used (but dead, what I realized to late).
And now, nothing more to loose I used the file from my OCZ Gold VX PC3200.
Result: they boot after a CmosClear with 2,6 V - now Prime running and testing :banana:
Funny: they are still programmed with 2.0-3-2-6 and shown as Mushkins :confused:
Enclosed the dumpfile from my OCZ VX...;)
i got my OCZ 2x512mb EL Platinum REv.2 @ 3.1Voltage and its not overclockig anymore beyond 220Fsb and i cant run CL-2.5 or 3 because i overvoltage it..
so does that program will fix my problem?? will the OCZ REV.2 will be able to overclock agian @ 300FSB??
if so.....then its miracle
Strange, did it again and now my Mushkins are OCZ, and also the SPD-timings were rewrite...:rolleyes:
From originally 2.0-3-2-6 now to 3.0-3-3-8 and the DFI ist booting with 2,6 V. At the first trial it worked, but after removing and put it in again into the slots the RAM didn´t start.
It still didn´t start from my DFI 855GME...:(
I think, the RAM has a hardware damage from to much voltage...:(
Could somebody recommend a dump-file for a CH-5-Kit with CL 2.5?
stummer... as said in the startpost.. please watch out with placing other spd's in youre mem then the original!
good job
Would anybody upload a SPD Dump from a Twinmos Pc3200 256Mb ?
It's a stick with Powerchips ( AADT )
@Waus: I got you...;)
But they are damaged anyhow, so I don´t care about them.
I dumped the OCZ on the Mushkins, but didn´t work either. So I dumped back with the file in Post #1.
But they still run only with 3 V, doesn´t matter which timings @ 200 MHz.
I have a Twinmos Speed Premium BH-5 with a Mushkin LVL2 dump... Works nice... Had to do it otherwise they wouldn't work together in my DFI Ultra-D...
hy,
here are my SPD:
OCZ EB PC-4000 2x1024MB Platinum Edition (OCZ5002048EBPE-K)
For those who are interested:
I made a custom SPD-ROM for my Infineon 6-A modules (rebadged Winbond BH-6) with the optimal Winbond timings. Should work on all BH-5 or BH-6 based sticks, but no guarantee on that. ;)
For 256MB sticks:
http://www.fh-augsburg.de/~madocer/R...H-5%20BH-6.thp
For 512MB sticks:
I want to modify the ram's of my notebook(2x512 mb with samsung chips)! They are rated @ ddr 333 mhz, but I want to make them @ ddr 400. Can someone upload a dump from his notebook memory (ddr400, 512mb) to try?
Thanx in advance!
I need your help guys, i'm looking for a SPD from a 128MB DDR stick, no matter what chips, rating or timings; it just needs to be 128MB DDR memory. If you own such a stick and want to help a fellow overclocker in need please upload the dump here, thank you.
today, sucessfully modded my Laptop memory with the Hex-editor from CL2,5-3-3-8 to 2-2-2-5 and i enjoy the new performance
well done
oktavius can you upload the old dump 2,5-3-3-8 here? It is 512MB right? :)
yesQuote:
Originally Posted by soki
here it is
TMTc DDR400 PC3200 CL2.5 Notebook Memory
here another one for G.Skill TCCD-431
G.Skill F1-3200DSU2-1GBLC (TCCD)
Anyone have a copy of the OCZ PC4000VX UTT 2 x 512MB dumps?
do you need that? :)Quote:
Originally Posted by shadowing
Thx man. Great to see the XS community help each other. :)Quote:
you are welcome man. :toast:Quote:
I ve just fixed my PQI TURBO module with a hot swap!:banana:
Do hot swap do not be afraid!
Did you switch the modules each other or add the "bad" one to the other slot after load windows?Quote:
Originally Posted by micdoc
can you mod khx3000 so that the pc thinks it`s pc3200 ?
Have a freind that have problems with his msi nforce 3 it wont go fsb 200 with them
Need some additional clarification before I try this:
Do I just boot with 'good' stick into Windows? Then add the 'bad' stick while it is in Windows?
I took 4 sticks of KHX3000, burned the Mushkin lvlII spd into them, they behaved better but still just arent as good as the other BH5's. But it was worth doing.
When I did it I put the bad stick in as soon as the screen came on i.e before or during POST... worked fine :D Didn't try any other way.Quote:
Can the mushkin spd work with my hyperX 3500 CH-5?Quote:
They dont run 2-2-2-5 in 200mhz gives erros every way :mad: but in 198mhz they run without any error.
No :) make sure youre working stick is in slot 1 and the other in 2 or so.. then you can boot in windows and have fun again :DQuote:
Does anyone have a bios dump for 1 gig Gskill HZ with UCCC chips?
i have dead stick of geil one bh5 that my dothan adaptor done in
they done 250 1.5 2-2-5 at 3.1 volts all day mem test passed
try this later :woot:
thanks walrus mod
the strange thing is that my mushkin black level 2, boots fine on ultra-d but thats the board that can boot with it have tried several of mb and the just beeping , but when they are in ultra-d it boots fine but taiphoon just read one stick att org spd, will try it later with my new sapphire pure board an se if it can find the bad on that board, have'n give up theese stick because the where very fast and the living stick just do about 280+ with 3,7v vdimm.
pleas some comments..
Sorry to ask, ignore if you feel it's noobish.
1.Assuming you have a speed-binned bh-5 module. Does programming it with a different dump remove that 'limit' ?
2. Say from your kit, you have a weaker and stronger stick. I presume copying the one from the better stick into the weaker one does help right ?
3.And let's say that my module does 265Mhz 2-2-2-5. Does programming it with a dump from from a memory that does 275Mhz 2-2-2-5 help in the performance of your ram ? Or is it the IC and PCB that comes into play over limiting the peformance of the ram itself ?
*All these provided that dumping a different type of memory does work on the ram itself.
**Anyway, thanks to Waus-mod ! I'll be trying to get my Corsair Bh-5s up to standard [hopefully] once i get the full rig to test :D
1. NOQuote:
Originally Posted by farksy
2. NO
3. NO
The answers are as simple as that. The SPD-ROM can't change the limit of the hardware itself. If the chips' limit is, let's say, ~260Mhz, then programming the SPD might change something if it includes weaker timings, but it won't change anything concerning the max. overclock if it doesn't change any timings. The SPD_ROM just includes info about the RAM sticks and the timings it needs, nothing magical about it.
oh ok thanks alot ! =D.Quote:
did u used the original spd to replace the bad one? if not this could be the problem!
The problem is that the taiphoon doesnt see the bad mem it's invisible it find's only the good mem the other bad stick is like it's invisible and i'ts only on my DFI U-D that i can boot with both sticks in. and i have saved a dump from the good mem and the spd is ok on that, it's just that the bad one dont show up. :(
so it only sees the good spd or both?
yes only the good one,and only on my DFI U-d board on other boards it's only beeping when i try to boot with them in the slots very strange i think..:confused:Quote:
yes only the good one,and only on my DFI U-d board on other boards it's only beeping when i try to boot with them in the slots very strange i think..:confused: but when i only have the good one in on the other board it boots just fine...Quote:
It may already be in this thread and I missed it, but there is Ver 2.0 out.
http://www.softpedia.com/get/Tweak/M...n-Burner.shtml
Thaiphoon Burner is the first known software that provides the easiest way to edit and flash SPD of RAM in Windows without using any additional hardware components! The second version supports 8 new Intel ICH7 series peripheral controllers, nVidia nForce 3 250GB and MCP55 controllers. In addition, Thaiphoon features an enhanced HEX Editor that enables to move the cursor by arrow keypad.
Was wondering if anyone had a dump for Mushkin EM3200 (PC3200) 1GB stick running 3-3-3-8 @ 200MHz.
I am running three sticks of ram on my NF7-S, two of which are OCZ UTT 512's and the third a gig of PQI turbo.They run together on the latest Abit bios at 200 mhz with 7-3-3-2 timings. They will not run any other speed without errors, even 201 mhz.
The timings on the OCZ were not matched to the stickers on the ram.It is marked 7-3-3-2.5 but the spd says 8-4-4-2.5. The PQI Turbo's SPD is 5-2-3-2. I am aware that the fastest timings on an NF2 are 7-3-3 and all sticks are capable of diong that up to 216 on their own at default voltage. I am thinking that the vast difference in SPD's are keeping them from going past 200 together.
Do you think that flashing all of them to an SPD with the same timings would allow them to run better together and pass the 200 mhz barrier?
<font color="red">people. you still need to watch out with re-programming youre spd with other spd's then original. There are second spd's that you CAN'T reprogram but still work! this can coz problems, where i dont want to be responsable for!</font>
It is not uncommon for the SPD timings to be more lax than what the ram is capable of running in order to increase the compatibility with more motherboards. You first boot at the more relaxed timings per the SPD, then you adjust them through the BIOS to the more aggressively rated timings. I don't think this should be a concern for you.Quote:
Originally Posted by shadowdr
You know wht they say about where angels fear to tread. I did try several flashes of the 512's without any help for my situation and did notice that on one module the part number would change while the other stayed the same. Strange that that would happen but did not seem to have any affect. Great program though for someone with serious compatibility problems or dead ram.Quote:
problem is your chipset.Quote:
Does anyone have dump for crucial ballistix BL6464Z402 (512MB) ?
does anyone got the dump for 512MB Mushkin PC3200 Level II (990989) ?
Link not working ATM... I work at a computer shop so I could dump many sticks SPDs including high-end memory, could be useful for the community!
nm.. new version:
http://cbid.amdclub.ru/files/thphn30.zip
Resoldered SPD chip, rewrote SPD and saved bh5 module :D
But this is only if your SPD is totally dead.
maybe you guys can help me
i've got 2x512 Twinmos AA4T CH5
they run 255 2-3-2-5 with good alpha timings
but there is a problem with them ..
my pc doesn't want to boot with them everytime (DFI gives me 3 red leds error)
sometimes it will turn on ... usually after a long wait before pushing power button (around 30minutes) .. then i can do every thing (they run normaly as allways at 2-3-2-5-1T rock stable) accept powering down my machine ... 'cause they will not boot again :/
both stick act like they were dead on other motherboards :(
when i stick them in yellow slots and some good ram in orange slots, system boots up perfectly but doesn't see those AA4T sticks .. however CPU-Z can read SPD from every stick...
http://chaos.dracopc.com/pub/ch-5_problem.png
i tried to reprogram spd with thaipoon .. but after reboot they are like they where before .. :(
anybody can help me?
p.s: sorry for my english :rolleyes:
Which VDimm do you set?
I have a pair of defect Mushkin Redlines here, the show similar thing, the don´t boot most of the time, need more VDimm to wake up.
Do you run your DFI with 2 x 512 and 2 x 256?
i set vdim 3.3v + 0.03Quote:
Originally Posted by stummerwinter
@3.4v and above i got errors in memtest and they are unstable
and YES .. my DFI runs with 2x512 and 2x256 perfectly .. but with 2T...
Before i go to sleep I removed 2x256 and i put my 2x512 in the orange slots...
I wake up this morning pressed power on my PC ... and voila ... I'm in Windows now with 1gb of ram..
http://chaos.dracopc.com/pub/ch-5.png
i don't know why they behave like that :(
I can add support for nForce 410/Geforce6100 if you need.Quote:
Originally Posted by kiwi
Used this on my Geil One BH5 and returned a stick of my finest bh5 from the dead cpu-z had some how rewrote its size to 16180mb if only it was true lol
thanks Waus-mod
Anyone need a dump of Geil One bh5 512mb stick p.m me
To VVJ:
Can you add support for Geforce6100/nForce410 for me ,please? I'm using Biostar TForce6100,my email:ahxxy0378@sina.com.Thanks!
Can you guys help me? The program can't work on Biostar TForce6100 with Geforce6100/nForce410.THX!
Thaiphoon works on i845D well (a lenovo's PC,QDI motherboard,Ramaxel's DDR266 memory module).
