nice chip Beastlock. 2.5 on stock air is excellent. looks like these 3000+'s could turn out both very nice.
These 3000 chips are good overclockers. We'll see how they will do against the P4c chips.
OPP
OPP: Is this done with the Gigabyte K8N pro?
Nice OC btw, what is the stepping/code of your CPU?
Yea it's on my K8N.Quote:
week 43 chip.
OPP
Great!! :D I can't wait how my A64 will perform on water.Quote:
Originally posted by OPPAINTER
Yea it's on my K8N.
week 43 chip.
OPP
So the K8N is PCI locked? Or are you using a PCI controller?
Because at 300fsb, the HD would not survive that.
Correct me if im wrong..
I use a Fast Track 100 raid controller. Not sure if matters or not, clockgen only shows the PCI clock at 34Mhz.Quote:
I'll also be putting this on water, to replace my 3.2 P4.
OPP
Indeed :DQuote:
Originally posted by TheDude
Bowman,
Please let me know when you get the ovp figured out for the Chaintech.;)
Mickey,
I need the Chaintech bios that allows memory settings. Do you still have it or a link to it?
Anyone have a link to clockgen for the Chaintech? Not sure which one to use? Thanks :D
Just now setting mine up in Mach2...I've had it for months...first chance I've had to install it...using it in Mach2 review/guide along with regular AMD install.
I'm also going for a Chaintech so a OVP mod would be handy :toast:
Nice oc OPPAINTER :toast:Quote:
OPP
Welcome to Xtreme:toast:Quote:
Originally posted by Beastlock
Nice oc OPAINTER :toast:
Runs stable at 2940MHz on my 404a MachI.
OPP
thanksQuote:
OPP
The 3000+ Are nice chips :cool:
Whit my boxed cooling I have my 3000+ Prime stabel@2,5ghz :D
Only my Radeon9600 Pro does not like the AGP bus speed :mad:
Maby its time for me for a 5900xt :D
OK...the all brands clockgen works fine but I still need the Chaintech bios with ram timings. Mickey, I know you used it once, where can I find it? Bowman doesn't have it anymore.;)
I can't believe I spent twice the cash for a 3200 and Opp is blowing it away with a 3000. :shrug:
I think Opp is an Android.;)
Thats life :) But verry nice scores damm :P i hope to have my A64 soon :DQuote:
Haha Insane clock on that little 3000 chip there OPP! :toast:
It will kill all P4Cs no doubt about that :D
is it green or brown?
Nice Oc on that 3000+.
What Vcore you using for that?
Huge difference @ oc between green or brown ?Quote:
Its a greeny, uses about 2.07V for running 03 at 2940MHz.
I have one big problem though, I can't install W2k for anything.
It doesn't matter what I have the bios set to, it doesn't matter if I use my seperate IDE drive or my Raid card. I get blue screen when all files are loaded and it goes to Windows setup. This is with 3 different w2k CDs.
XP loads with ease. I'm going nuts!!
OPP
I have a AMD 3000+
ADA3000AEP4AP
CAAOC 0343UPMW - 9459245K 30068 (brown chip incase anyone is curious).
Waiting for my mobo to arrive tomorrow to start playing though. In the mean time, I'm growing bored, and this IHS looks so ugly compared to that beautiful nekkid die.
Anyone know a good method for removing the TIM on an AMD 64? I heard it's a chalky compound that's harder to remove than well cured AS Ceramique.
I'm having a problem getting the Mach2 evap head to meet the die on my a64/3.2 since the heatshield was removed. I took 2 of the 3 spacer washers out of the a64 install hardware, but it still does not give me an imprint of the die in my thermal paste. Has anyone else had this problem? How did you overcome it? I don't want to have to put the heat shield back on the die because of this. Would it hurt to remove the remaining rubber gasket and washer too?
Have to dremel away at the bottom plastic piece. Lower the plastic that attaches to the mobo and the evap will reach the die. You may have to carve out some spots for mobo components to fit under.Quote:
OPP
ouch....was hoping there was an easier way. Damn...what a pain.
Well thanks for the tip Eric...appreciate it. ;)
Yea I hardly have anything left on the bottom plastic, works for a good tight evap fit though, and yes it's a pain:D
Was wondering how much you had to take off. Cut some....fit it. Cut some more....fit it...etc Can't wait....but it does have the advantage of a nice tight fit as you say. I may try grinding it down instead of cutting it off...until I get to having to notch it for stuff sticking up on the board. I guess it's worth it....everyone says the temps improve quite a bit with the shield off.
Do you have some pic's of the mod ?Quote:
I heard you will get a 7-9 c lower temp :)
if u gain 9C with the removal of the heatspreader, then i'll do the mod too :).
dont feal bad,i have the same problem right now on the gigabyte.excate same problem.Quote:
OPP
so i pulled it.i figure the board is screwed.
i have been out at the beach so i havent had anytime to work out the ovp mod on the chaintech either.i did get it working on the shuttle so i am pretty sure it will work on the chaintech and gigabyte.i just need some time to test.
and by the way...good clock there OPP.just i am worried even with the higher clock(which i am sure it is from the lower 512kb of cache.)that it wont run with the 3200 or newer 3400,i personally would like to have the 3400 with my ram that will run 1:1 up to 285 should scream.
Sorry to get a little off topic with my last post, here's my chip
ADA3200AEP5AP
CAAMC 0342VPBW
9452345J30107
MALAYSIA
Dude you get the rig running yet.?
you can always stick the spreader back on to play on it.i have stuck my spreader back on mine while i have been testing it is easier when you are taking the evap on and off a dozen times or so.
I had it running on air into the bios. BTW HS/F for 64 coming your way. I picked up one.
Sooner or later I will have to trim the install kit down for permanent installation in the Mach2. I guess I could stick it back on and then do it when I'm not so pressed for time.
I had a hard time finding ram it would boot with consistently. It's a picky :banana::banana::banana::banana::banana:.
If I put it back on, what should I glue it down with and should I put some Alumina in between the die and the spreader? I kind of have mixed feelings about that cause it adds another layer to the mix....maybe a real thin layer?
BTW: soldered the vcore mod back up.
just place a small dab of alumina or something on the die and press it down.then i lift to make sure it has full contact.and then repress it.the alumina will hold it down until the evap head can hold it.Quote:
you can use black silicone and apply a small amount around the spreader and the reapply it.wipe the excess silicone from around the chip and spreader.let it set a few hours with some pressure applied and it looks like the factory job.
it real easy.
Good idea about letting the tgrease hold it down until I get the evap on it. That way I can trim it to fit later. I should have thought of that. Brain isn't firing on all cylinders right now. ;)
Bowman,Quote:
Are talking about a 3000 chip or are you having the problem with the 3200 chip? I could have sworn I installed w2k with my 3200 chip on this mobo.
Maybe I need a different mobo :D Fricken pain.
And your right, the 3000 doesn't look to great as far as performance compared to a 3200 chip, it reminds me of a Celly vrs P4. Not enough cache, no action.
OPP
I think that W2K needs to be slipstreamed with latest SP, as they don t support A64. Same goes for WinXP. (SP1 is need it) I m not sure though...
well no its not my chip,or not that i think so.i have 2 chips now,and a new 3400 on the way.Quote:
Bowman,
OPP
the gigabyte was working fine.i pulled it down to work on some mods with the shuttle and chaintech.the shuttle would give me super fsb speeds but its 3d proformance wasnt up to the gigabyte.even with only 3500 sandra scores the gigabyte will beat the shuttle that getting 4300 sandra at the same clock(or very close)
so i reset up the gigabyte.first i noticed i couldnt restore a ghost,keep telling me corrupt image so i tryed fresh install.
would load but keep saying was missing files.tried 3 differant w2pro disks.
so it was running perfect but now its gone.strange.
i could try another chip to see.i have a brown week 41 i have that will post 2950 mhz i didnt try that one.
come to think of it i was running the chip you sent me.but i think it is board related.i must of done something to the board.i may try on air and see as soon as i get another heatsink.right now i am out.
New 3400+ chip ?? sounds great :DQuote:
Chaintech is up and running 3200 with XP on Mach2...doing all the stupid updates and security patches. Glad I have 1.5 down DSL. ;) Mach2 display shows -57 bios shows -9
For those of you that have had a 3000+ and a 3200+, what kind of difference did the cache make?
That's what Opp had to say about it.Quote:
I knew it would be less, but if it's really like the celly and P4, maybe the 3200+ is worth it.
If anyone could give me some 3dmark compares It'd really help.
I tried searching, but I couldn't find much on the orb.
Most reviews show a small difference say 5-10% in 3DMark scores, but the real difference will show up once the 64bitness arrives on the marketQuote:
10% i can't believe that. you do realize with a great setup that could be around a 2500 point loss just cause of half the cache?Quote:
amd chips have never shown anywhere near willamete -> northwood gains when the cache is increased.
5% loss possibly at more normal user settings.. 10% if you get nearer to 3ghz... maybe?
Do u got any SuperPI results at that speed?Quote:
OPP
I was wrong about the 3000 chip, I did a clean install of XP and chip seems to run 3D very nicely, I only wish I could get w2k to install. I'll be back with some Stock radeon XT scores.Quote:
Bowman,
OPP
OPP
I curious about the 3dmark 2001 scores because 2001 is more cpu dependent.Quote:
OPP
Here's my Radeon XT running at stock speeds.
CPU at 288x10,, mem at 240MHz.
This is an easy 29k score if the card was overclocked,,I think:D
OPP
Alright, thanks Opp.
you had me worried about the 3000+ not running 3dmark very well.
Sorry about that, my wrong:)
OPP
haha, no problem.
Damn nice score's OPP :)
23k on stock XT is nice
Running 288fsb on a gigabyte or shuttle?
How much should i could get out of a AMD 64 3400+ ?? Approx ?? :)
That depends of the Cooling.
If you have som Prometeia then about 27-2800 Mhz..
If you get a lucky chip 2850.2900..
2900 at MAX...
On air 2500 Mhz..
I think.. :rolleyes:
This is the max stable of my 3200+ without the VMod on the memory (only 2.7v).
http://home.kqnet.pt/wo034892/CPUMark_357_2800.jpg
Pedro
What mobo are you Using?
Gigabyte, but I can't get w2k to load and I'm running XP. I have to try another type of mobo.Quote:
OPP
Gigabyte K8N "non pro" (really unexpensive - 90 Euros) :)Quote:
Originally posted by JacobHansen
Pedro
And the heatspreader was removed ? Verry nice resulds from both you guys :banana: :cool: :banana:Quote:
OPP
Pedro Rocha What is the stepping of your cpu that thing rox
:D
Tak JacobHansen :)
Godt nok at her er andre fra lille DK :p:
I have H2O Cooling - EVO360 and soon i will get a Maze4 that will fit on my 3400+.
Should i could reach 2500Mhz with a Chaintech mobo ??
With a bit of luck u will even get 2600 or 2650. I have seen some A64's run @ 2600 on WC :).
2500 is very doable with some big-ass aircooling. With that WC u will be able to get that without any real struggle i think :).
Sounds NICE!!! :D
I will post some results when i got some :d
nice - Jeg håber du kommer højt.
I hope you will reach some high mhz :D
I've bought a Gigabyte K8N pro motherboard and I would like to change the memory timings...
But in the original bios I cannot do that.
Does anybody know how to change them?
Tom's Hardware just made a review of four chipset:
http://www.tomshardware.com/motherbo...105/index.html
You need to hit ctl-F1 when your in your bios.Quote:
OPP
I am going to sell some stuff and see if I cna get a a64 or would it be better to get a fx-51:D
Pedro/OPP:
Are you using a PCI controller like promise? Or have you tryed not using the PCI controller card?
I've got the same motherboard as you (k8N pro), but I can't go beyond 225MHz HT.
Might it be the PCI thats not locked??
I set VDDQ tot +1v, VHT to +1 and Vdimm to +3v.
I'm useing both, right now I'm testing with just a IBM on one of the IDE ports. No problem at 290 FSB.
OPP
So there is a lock, or your HD is very tolerant. :DQuote:
OPP
Which bios version are you using?
I'm now testing 220x10 with 1,65v. No probs in windows.
But when I set 230, I can't go further then the post. (blue screen)
Is the VDDQ and VCC12_HT important with OC? and what is the best LBT speed?
My mobo is not yet been modded.Quote:
Originally posted by MickeyMouse
drop "LDT" from 3x to 2.5x or if at 2.5x to 2x the fsb will now move alot high depending the cpu can run the faster MHZ..
best bet do this
max vcore
max vdimm
set ldt to 2x via the bios post at 215-220mhz fsb
use clockgen in windows to see the max "STABLE" the fsb you can achive ;)
I bet you pass 230mhz if the cpu can handle the new speed same goes for ram
BTW what DDR are ya runing ?
vDDQ and VC12_HT is set to +0.2v.
My memory is running at 191MHz @230FSB.
This is because i have PC2700 memory and I can't swith to 1:1....
I think with a mod I wil come a lot further, because now I need more Vcore and more Vdimm to run my memory @400MHz 5-2-2-2.
I know, this ram only get fast with high voltages...Quote:
lol im not talking about any mods ther eis a bios setting for
HT/LDT 3x/2.5x/2x or maybe its like this
600mhz/400mhz/200mhz lower that ;)
also drop that ddr that is hoildiing you wayyyyyyyyyyyy back get real ram that is "MADE" to run with the full speed of thre onchip ddr controler. :)q
It can max out to 500MHz with 3.3/3.4v. (5-2-2-2)
Im now looking for BH-5 memory. :)
And thanks!
250 2-2-2-5 is normal for BH5 at 3.3v.....
You sure BH5 will do any better than what you have?
That's a damn nice clock for Infineon 2700...
I haven't try 3.35v and higher on my Infineon USA PC2700.Quote:
On my 4pda2+ I maxed out 490MHz 5-2-2-2 3.34v
But a to high DDR voltage might damage the onchip memory controller...
But the BH-5 will do better at lower voltage than my Infineon.
Verry nice clocks there I'm doing 233 @ 3.1 @ my pc3500 ( BH - 5 Corsair )Quote:
What can I expect to hit?
Just got my 3000+ (0344) and receiving my Chaintech nForce3 tonight.
I've got some Corsair PC3200 TwinX (Ver. 1.1), VapoChill XE and WaterChill for the NB.
Without a VMOD - is 2400-2500 possible?
Soundwave - with that new chip 2400-2500 should be attainable. especially with below ambient cooling. post results later?
MickeyM. Where Can I find your guide. I'm not that skilled in MOD's but I know someone who can do it for me.
Ive just heard that the AMD 3200+ droped from $417 to $278 !!
So it will be the best for me to buy a 3200+ :)
SW --> Ej er du nu også her ?! :D
2 WRs :
403.88FSB with MemoryFSanMax PC3200 BH-5 256MB / DDR266 / CL2.5-2-5-2-8
VDDR : 3.39v
VIO : 3.73v
CPUFAthlon 64 3200+ 0334MPMW
JAP guy (NEWBEETLE) DETECTED :smileysex
http://homepage2.nifty.com/NewBeetle/img022.gif
and
Wow 43sec in pifast is amazing :)
Running 1:1 ? :)
cpulloverclock - Let us know how long that A64 lasts on 3.7v...
AN50r
3200+@240x10@1.65 Just AIR
Died, after 2 days.
Just the board died?Quote:
Originally posted by gabbax
AN50r
Died, after 2 days.
Well, to be hounest(spell:)) I do not know, it refused to start, so i RMA it to the store, i hope il get some new stuff next week:)
And i did test all i could do, just dead, wont boot at all...(i think the CPU died,and the motherboard still alive)
Yepp, the "buffert" or Full load temps are Amazing with DIce, i did test it on my P4, and it just rice 1-2!! deg under SuperPi in 4100...
http://www.watercooler.com.br/copyman-modshop.jpg
While my gigabyte doesn't arrive and my r404a 1,1\4hp 890w@-35c chiller not this finished, oh they are my results full rock solid and stock air cooled
system
asus k8v deluxe " argh " bios 14
a 64 3200+ @ 2470mhz 1,75v stock cooling
xms 3500 2x256 mb 3,25v 2\1 247Mhz 2 2 2 5 11 16
9800np san 3,3 ns @ 9800pro 535gpu (air cooled) 384 mem
(one among 23 different bios of 9800pro's that I got to do to rotate solid to 247mhz " 82mhz agp ")
25.781kmarks
http://service.futuremark.com/compare?2k1=7425759
In one day with win2000 and rotating the tests to punctuate, and increasing a little the over of the videobord hopes to kick 26.6 26.8 totally air cooled with to 9800 np 3,3ns san and that horrible motherbord...
I find good results tends in view the system of refrigeration and the used mothebord, and mainly gotten with air cpu (stock) and gpu.
I thanks the friends a lot (mickey ,major, OPP, macci, Bownman, mister ice and among others) that always helped me in a lot of doubts them and they never stop answering a tread or mp
You are incredible
If somebody has interest in information on my vmods topic
http://www.forumpcs.com.br/viewtopic...a027281d7b3a93
or super chillers
http://www.phase-change.com/phpBB2/v...?p=10084#10084
cya
in time...
i got, after changing 23 bios of 9800pro's, to find one the to work more than 82mhz in the agp
I think with it you can play a little more with the 9800pro without collapse of the agp with via bords
I have some 12x 9800pro original home, but I didn't have time of trying this bios in it.
none of those 12 9800pro nor it mines 9800xt it was besides passing from 71 to 74 Mhz in the agp
a lot of game for today the night
who wants to try this bios in your 9800pro´s to rotate in high values of agp, only to order me a mp ok
I just read this:
http://www.theinquirer.net/?article=13525
I hope it's true
pretty long, as long as you don't use Shuttle mobo.Quote:
2500mhz air cooled
CAAMC 0339WPMW
9446548130306
http://eshbach.s5.com/2500.jpg
Here is mine so far
3.0 GHZ :D
I'm Getting a CAAMC 0349 RPMW. I have heard people score bad with this core :'( People here who have seen it run good clocks ?
I was unable to run 2400MHz stable with Vcore 1.6 ~2.0V with that stepping code. The temps where good (38C).Quote:
Originally posted by Astennu
3.0 GHZ :D
I think my K8N pro is holding me back, i dont know.
If i was you, give it a try.
fine stuff. can't wait to see what happens with 9 microns. how many chips you had so far jason? whats your take on the best steppings?
3012 1.95 ADA3200AEP5AP Abit KV8-MAX3 Zalman CNPS7000A-ALCU 21567
someone from the cpudatabase got 3.01ghz on abit Kv8-max3.....
1.95Vcore
and also it seems that amd made some tweaks on the a64 3400+
people nearin' exceedin' 3ghz
soccrstar - you get 3ghz on air??? :slobber:
how stable is that
ohh daz HSF? :confused:Quote:
how stable is that
didnt kn0
s0rrie
i ordered a athlon 64 3200+ wit abit K8v-max3 motherboard
and OCZ PC4000 (ddr500) gold edition 2x512mb DDR memory
and antec 550 trupower power supply
anyone with k8v-max3? how is it? good? no multi changed? tried upgradin bios to see if they added that feature?
(currently got p4 2.66@3ghz, gigabyte 8KNXP (canterwood), 4x256mb cas2.5 memory.)
i get 1min 10sec in superpi 1mb
[edit]
is it worth it to watercool a athlon64 northbridge?
I think he means he saw someone with this entry in the database.
I find 3Ghz on air hard to believe, any more proof ?
Regards
Andy
seems nearly impossible to me to reach 3ghz on air, especially while putting 1.95v in it. . you just couldnt cool it enoughQuote:
1.95Vcore
just IMO anyway
how are you people gettin' past the agp not bein' locked?
my motherboard i can change the agp clock by itself (non-amd)
to c the tolerance on my r9500 to prepare for my athlon64 comin' diz week.
and it wont post @ 74.
how much of a OC from a 64 3200+ would i have b4 the agp reaches that bus speed?
soccrstar - nforce3 chipsets have locked agp bus. often the pci bus is unlocked though.
man someone had recommended me the abit K8v-max3
now i wont go pass like 210fsb becuz of my radeon9500. it cries even b4 it even reaches 74mhz agp freq. on nother board.
