Mushkin Redlines would be a good choice there a decent performer
with this setup you should be golden
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : Auto
FSB Frequency : 420
FSB Strap to North Bridge : 266 or 400
PCI-E Frequency: 100
DRAM Frequency: 1000-1066 are
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 4
Row Refresh Cycle Time : 60
Write Recovery Time : 6
Read to Precharge Time : 4
Read to Write Delay (S/D) : 10
Write to Read Delay (S) : 4
Write to Read Delay (D) : 5
Read to Read Delay (S) : 6
Read to Read Delay (D) : 6
Write to Write Delay (S) : 5
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 6
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 6
ALL PRE to REF Delay : 6
DRAM Static Read Disabled
Ai Clock Twister : lighter
Transaction Booster : Manual
Common Performance Level 8
concessions can be made after the rig is stable to tweak maximum performance.
