@M3kk looks nice is that the orange Phanteks or is just the color off?, I know what cooler ill be getting next
Yes, its the Orange version :).
Nice bend
Height limitation, or just for the looks ?
nice
Like? :)
http://s018.radikal.ru/i517/1201/45/95adfcbc6d34t.jpghttp://s017.radikal.ru/i408/1201/26/3360ad594972t.jpghttp://s018.radikal.ru/i526/1201/ea/c5847729ffd7t.jpghttp://s015.radikal.ru/i332/1201/b5/d0acf0687d01t.jpghttp://s010.radikal.ru/i311/1201/19/fca377b1aebct.jpghttp://s018.radikal.ru/i520/1201/ab/201b036ad864t.jpghttp://s018.radikal.ru/i520/1201/76/a7a35586d382t.jpghttp://s018.radikal.ru/i525/1201/1c/f122971b7455t.jpghttp://s50.radikal.ru/i129/1201/c5/8b2147334d1ct.jpghttp://s018.radikal.ru/i525/1201/3c/da8b53313db9t.jpghttp://s017.radikal.ru/i408/1201/26/3360ad594972t.jpghttp://s018.radikal.ru/i506/1201/c6/fb34fe77451at.jpghttp://s011.radikal.ru/i318/1201/9a/c9767071f684t.jpghttp://s014.radikal.ru/i327/1201/51/7af08aa8d49dt.jpghttp://s018.radikal.ru/i510/1201/61/11ec3c55495ct.jpghttp://s018.radikal.ru/i519/1201/8b/f19652ce42bbt.jpghttp://s018.radikal.ru/i524/1201/50/8c48f5727837t.jpghttp://i045.radikal.ru/1201/68/d9be2fc3e420t.jpghttp://s017.radikal.ru/i417/1201/43/74d070ee83d8t.jpghttp://i024.radikal.ru/1201/7c/697fa8b3b73at.jpghttp://s017.radikal.ru/i435/1201/86/6c96b33be028t.jpghttp://s010.radikal.ru/i314/1201/13/382c39684759t.jpg
WHY DO 90% OF THE RAM KITS HAVE SPIKY HAIR?!
And now I go and try to grab the 2x4GB G.Skill Eco CL8 1600's and find out the've been discontinued! The best I can get's some Corsair Vengeance white 1.35's if I want 16. :(
Edit: I'm not paying $80 more for better timings, lol.
http://img201.imageshack.us/img201/4347/img0006ax.jpg
http://img802.imageshack.us/img802/2135/img0015bv.jpg
http://img85.imageshack.us/img85/6816/img0018qp.jpg
http://img51.imageshack.us/img51/6269/img0012dj.jpg
Config :D
AMD Phenom II 1055t
Gigabyte 990FXA-UD3
Corsair Dominator 8GB DDR3 PC-1280 @ 1600MHz
Gigabyte HD6970
Hitachi 500GB 7.200RPM
Huntkey X7 900w
Lian Li PC-X1000
Noctua NH-D14
Very high enclosure.
What is the height of the computer casing?
Lian Li PC-X1000 is very tall and height
Added a pair of the Corsair Vengeance Arctic White Low Profile, Low Voltage kits today!
https://lh3.googleusercontent.com/-i...4/IMG_4248.JPG
spring-cleaned my yr2008 rig...still alive and kicking...
http://i278.photobucket.com/albums/k...9/IMG_0753.jpg
http://i278.photobucket.com/albums/k...9/IMG_0754.jpg
http://i278.photobucket.com/albums/k...9/IMG_0756.jpg
http://i278.photobucket.com/albums/k...9/IMG_0751.jpg
http://i278.photobucket.com/albums/k...9/IMG_0705.jpg
http://i278.photobucket.com/albums/k...9/IMG_0719.jpg
http://i278.photobucket.com/albums/k...9/IMG_0726.jpg
Super stacked fans, well done.
A few quick pictures of my new system, will take better ones soon:
http://img163.imageshack.us/img163/136/r0026233.jpg
http://img100.imageshack.us/img100/1287/r0026159.jpg
http://img825.imageshack.us/img825/3531/r0026176.jpg
http://img29.imageshack.us/img29/9426/r0026178.jpg
http://img845.imageshack.us/img845/5056/r0026177.jpg
http://img692.imageshack.us/img692/6281/r0026167.jpg
As you can see the Ninja 3 JUST fits under the sidepanel...
http://img215.imageshack.us/img215/8784/r0026169.jpg
http://img46.imageshack.us/img46/8246/r0026173.jpg
The Aux. power connector is located in a poor position, cannot use any fans thicker than 25mm.
http://img576.imageshack.us/img576/9940/r0026185.jpg
http://img408.imageshack.us/img408/9255/r0026181.jpg
The filters actually work, I was expecting them to do nothing because it's pretty much just screen door mesh.
http://img607.imageshack.us/img607/6639/r0026160.jpg
http://valid.canardpc.com/show_oc.php?id=2213269
http://img560.imageshack.us/img560/7439/cpuidu.png
http://img263.imageshack.us/img263/3...etempscrsv.png
http://img841.imageshack.us/img841/8065/weixv.png
Specs:
-Intel 2500K @ 4.2Ghz
-16GB Corsair vengeance DDR3-1600
-OCZ Vertex 3 120GB SSD
-Asus Maximus IV Gene-Z Gen. 3
-Scythe Ninja 3 (hate the stupid tramp stamp tribal flame, will try to strip it)
-Corsair HX650W PSU
-Lian Li PC-A04
-Pioneer DVR-219
-Windows 7 Professional
-Dell U2412MB Ultrasharp IPS Rev. A02
-No graphics card yet (Intel HD3000), thinking of a 7xxx
Currently at 4.2Ghz, mild OC using the Asus CPU Level Up in BIOS, running at 40C on all four cores with fans at 500rpm (inaudible), full 100% load using Prime95 is around 65C. The Ninja is passive right now, probably won't feel the need to add a fan to it anytime soon. I will be changing out the top fan to a ball bearing or a Scythe Gentle Typhoon soon however, the sleeve bearing is driving me nuts with the whirring. Cable organization is a terrible in the case, the space in between the sidepanel and the mobo tray is too narrow for the ATX cable, couldn't even hide that. Thinking of swapping fans so the cables aren't tucked in yet. I cut down one of the SATA power cables and modified the length to make it fit better in the 5.25" bay area, have provisions for my Blu-Ray burner, as well as a 3.5" data drive.
Did I mention the SSD is FAST? Like holy crap fast. Before installing any programs (standard Windows installation), boot up was around 14 seconds (no optimization), currently it's at around 22 seconds, with 77 processes. Not too bad at all.
I wished I could get rid of the BIOS alarm at the beginning of each boot, I have the top fan plugged into the chassis connector instead of the CPU since the BIOS fan controller won't let me reduce my speeds below 1000 RPM.
Brendan
http://img707.imageshack.us/img707/3862/10687828.jpg
http://img72.imageshack.us/img72/3249/25665045.jpg
http://img821.imageshack.us/img821/6119/57819721.jpg
http://img3.imageshack.us/img3/5788/83223608.jpg
http://img842.imageshack.us/img842/9637/88284767.jpg
http://img689.imageshack.us/img689/322/44328189.jpg
http://img515.imageshack.us/img515/7928/68274263.jpg
http://img215.imageshack.us/img215/2906/65937002.jpg
http://img836.imageshack.us/img836/7804/92772249.jpg
http://img838.imageshack.us/img838/2958/77941877.jpg
http://img714.imageshack.us/img714/6748/82044528.jpg
http://img593.imageshack.us/img593/2496/11870508.jpg
http://img140.imageshack.us/img140/9533/89292521.jpg
http://img29.imageshack.us/img29/1133/87321492.jpg
:D
a rework of a old case
http://desmond.imageshack.us/Himg259...jpg&res=medium
http://desmond.imageshack.us/Himg31/...jpg&res=medium
http://desmond.imageshack.us/Himg26/...jpg&res=medium
http://desmond.imageshack.us/Himg813...jpg&res=medium
http://desmond.imageshack.us/Himg339...jpg&res=medium
http://desmond.imageshack.us/Himg62/...jpg&res=medium
Here's my mATX gaming setup.
http://img21.imageshack.us/img21/4756/kuva33.jpg
http://img834.imageshack.us/img834/2316/kuva22h.jpg
"World First at Cartago"
The NEW be-quiet! Dark Rock Pro 2
http://www.abload.de/img/_sam22552upci.jpg
http://www.abload.de/img/_sam2256jbq0k.jpg
http://www.abload.de/img/_sam22579opgo.jpg
