Yep I did 471 FSB on 0308 Rampage BIOS with 1.61 NBv. I can POST at 500 FSB but it would just stop at the microsoft loading bar. Maybe if I was on water and crank up the NBv more it would probably boot.
Nice FSB clocking, kindly post your full BIOS settings for others to ogle at, thx.Quote:
BIOS settings:
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 8.5
FSB Frequency : 471
PCI-E Frequency: 110
DRAM Frequency: DDR2-1132
CLOCK SKEW Normal both channels
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 55
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: Enabled
Ai Clock Twister : Stronger
Transaction Booster : Manual
Common Performance Level [7]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
CPU Voltage : 1.33725 (1.32 actual)
CPU PLL Voltage : 1.50
North Bridge Voltage : 1.61
DRAM Voltage : 2.12
FSB Termination Voltage : 1.4
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63X
North Bridge GTL Reference : 0.67X
DDR2 Channel A REF Voltage : DDR2-REFF
DDR2 Channel B REF Voltage : DDR2-REFF
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.5
Thx for the settings, Futastic. :)
stop that. 1.55v is more then enough... try to raise fsb to 1.4 or even 1.45v, vPLL to 1.55v and be sure your DDR aren`t holding u back, relax it on level 1, use the lowes frequency avaible 1:1 and use 2.00v cause this board overvolts it a bit. FSB strap set to 400, gives me better stability over 520mhz fsb, and also better bandwitch in read and write.
Bios 410 is great try it, I am at 601 now... @ 530x8 e8400 e0 @ 1.28v
Barr3l Rid3r I tried everything...
I probably gonna change my board
Hey mate, I'm pretty much having the same problem as you are...
Look a page or 3 back (at max) you'll see my description and settings.
I'm currently running 9*445 which >seems< stable. But I cap around that max too. 4.2GHz for example is a no go for me (which is 9*460 or so)
Well I finally booted up at 481 FSB, had to lock my PCIE Frequency at 100 to get it stabilized =)
http://i37.tinypic.com/2w71xfq.jpg
Update to my misery : Maximus Formula aint available in my country anymore and they offer me Maximus Formula ll instead.So i would get new MF2,its more expensive here but some how i dont fancy any P45.Other option is to take that RMA as in money (210€) and buy new mobo from their shop (they cover 210€ of my new mobo and refund the rest if i take cheaper)
I got Asus P5Q pro as a replacement board atm but i really dont like it at all.Any ideas?
- To get new Maximus Formula 2 cause they dont have the original Maximus Formula X38.
- Get 210€ (price of my X38 MF) to the shop and choose other motherboard,if i get cheaper they refund.
- Put more money 210€ + X amount of €uros for new mobo ( dont see any sense in this cause i7 came out to waste lots of money to high end socket 775 mobo.)
It has taken 4 weeks from them and if i understood correctly MF2 is 8x in crossifire and MF X38 is 16x.So i basically feel im getting more expensive but more suckier mobo.I got 280GTX but they dont know that in the shop so...
I also got Asus P5Q-pro mobo but im planning to sell this cause i really dont like this.
There is basically my options.Im planning to keep this pc for a while to till the i7 fuzz settles and i can get them for reasonable price (6-12months)
Your only oprtion for a motherboard is a MFII?
Futastic, pleas post your exact BIOS settings. It might help me to figure out what to do with my E8400 C0.
I'm about to go from extreme air cooling to wc, it's "officially" unstable at 4GHz..
MIIf is a solid board, it clocks great
If your running a single GPU you will get FULL 16x, CF is limited to 8x but its only noticable in benches.
My only suggestion/advice is to reseat the NB when / if you get it and run bios 1307 anything higher is craptastic for now. Maybe Asus will close the bar and let the bios engineers sober up so they can get it right.
I have both boards MIIF and Maximus X38 I doubt you'll be disapointed with the choice.
