tried another power supply yet?
yep i tried it on other p5w as well, vice versa psu and motherboard still it occurs only to my board
Question please.
In the standard motherboard setup (no ahci), is the rear panel e-sata really an e-sata port or just a standard port? If I plug a e-sata drive into this port when the computer is on, am I taking a chance of corrupting the e-sata drive or risking damaging the MB?
Not really clear about how the e-sata works in the standard setup. :shrug:
Thank you
Does this mother have 1t/2t option to change in bios ? i have a problem, i have a supertalent blue 2x1gb at 5-5-5-15 2.0v 800mhz and the memtest 3.6 of windows show two errors at 8 hours approximately, but if i change de timings at 4-4-3-8 the errors are show in lower time, i think that the problem is a configuration of the bios, the timings, fsb of this motherboard maybe? (now i have setted in 400 but the processor is stable) or the ram are broken, i don´t know, help please
and what do the option "write recovery time"? how can i know what is the best clock for my RAM
thanks.
Hi All,
I'm having a major problem with my rig: Every time I try to reboot after shutting down, I cannot past the post screen by being stuck at the Welcome screen. The only way that I can boot up again is to reset the bios.
It all started about a couple of months back with frequent "Checking NVRAM" deaths and I had to do the same thing. Then I figured it might be the BIOS and I updated to 2504, no help; then I figured it might be the power supply, changed it, no help. Finally, I found that one of the ram seems to have a problem, I took that away, it worked! But not for long. Now I'm out of luck.... Is it because my overclocking?
Configuration: P5W DH Deluxe BIOS 2504
CPU: Intel C2D E4400 Overclocked to 3GHz
Memory: Buffalo Firestix 3GB DDR2-600 4-4-4-11 2.1v
Power Supply: Corsair 750W-TX
Help please!!!! Thanks!
George
I only used my eSATA box for a while, then moved the drive inside my PC when I found myself leaving the enclosure on all day when the PC was off.
It worked fine when I plugged it in hot. The other JMicron SATA connector near there is the only other one I found that worked hot. If you attach an eSATA adapter like the one that came with my enclosure to the other SATA ports, you will have to reboot to have the drive recognized. It also gets lonely if you disconnect the drive: the PC seizes up every once in a while looking for the drive to respond.
I now use SATA trays instead, one is for backing up the PC with a pile of 500GB drives I've collected, and another is there for when I decide to fill it permanently. There's no fan on that though, so I'm going to work on that before I use it all the time. Lucky for me the SATA RAID adapter I bought at Best Buy also hot-swaps, so with it set to Big and only one drive on it, I can hot-swap either tray...
Hi everyone,
I'm trying to set up RAID on this board......what a PITA....
I tried it like this
but when I start installing windows and prompts me to press F6 I have no power in the keyboard....it powers on when windows starts installing(when it asks if you want to install XP, repair or quit).
I just can't figure out how to load the RAID drivers.
I have 2 500 GB 7200.11s in the 2 black SATA connectors(SATA 3 and 4). I tried to leave the jumper on or taking it off...same :banana::banana::banana::banana:.
Any ideas before I torch this mother:banana::banana::banana::banana::banana::ban ana:??
Thanks fellas.
I'm guessing you have a USB keyboard. If you have a PS2 keyboard, use that for the install. If not, then check you have 'Legacy USB' enabled - this 'should' allow the USB keyboard to be recognised during the install.
Alternatively, you could slipstream the RAID drivers onto the WinXP installation CD with nLite.
I just bought a PS2 keyboard from the thrift store....wasted 3 dollars.
Now the kb has power during the install(num luck light is on all the time) but still teh system doesn't respond when I hit F6.
After that it prompts you to press F2 if you want to start automatic system recovery...when I press F2 it works....un:banana::banana::banana::banana:ingbeli avable
any other ideas?
thanks
hello everybody,
i got my E8500 and change to bios 2602...my board revision is 1.02 (the old one)
iīm not able to fix the multi manually at 9,5...i canīt select the half mutli...
also the vcore only works at AUTO...manually i can select 1,45 to 1,7...but it doesnīt work, if i select 1,45V...
does anybody know the problems?
thanks godsmack
Half multi's don't exist on Intel.. only AMD
Don't know about your vcore problem.
I updated to 2602 yesterday, works OK except that EIST doesn't seem to work on it's own anymore. I needed to enable C1E too. 2406 worked fine with just EIST enabled..
That's no longer true. The new E8x00 processors from Intel now use half multis.
Eg. E8500 runs on 9.5 multi @ 333Mhz = 3.16GHz.
I think the board will require a new BIOS to handle this. Whether Asus will provide one or not is another question.
Oh ok, haven't been paying much attention recently :P
EDIT: But surely this will be a chipset issue. I'm pretty certain 975x can't run half multis..
I think you're right.
Just checked compatibility on Intel's website and their 975 chipset is not compatible with the E8500 processor.
the bios recognize the E8500 and it´s using the 9,5 multi...but in the bios i onley can switch between 6-9 multi...9,5 doesn´t available...
actualley my system runs with 9,5*380...
i hope asus will published an new bios wich give better support to EIST, C1E, manually vcore settibgs and 9,5 mutli ;)
thanks.
I have problem with my computer after half year. When I turn it on, from outlook everything work well like fans, light.... But mostly it does not post anything on the monitor. It always says "No signal".
However sometimes (rarely) when I turn on it works normally. I notice it only works when the light on the case blinks during booting process.
I tried to test PSU. Chipset, VGA Card, HDD in anther computer and they are working fine. The only thing left is mobo.
What's wrong with my mobo? Is there anyway to fix it?
Thanks!
Ash:
90% chance it's the memory.
Try a different set of RAM in that computer and I bet it will work every time.
Alternatively, try your existing Ram in another PC....
I'm probably going to be selling mine in the next couple weeks if you're interested...
