Eh..I just popped the IHS off my 165, and I am running into a lot of problems. With the IHS on I was hitting the low 60's with both the AMD heatsink, and my Zalman 7000B. I used several different installs of AS5, and I assure you it was appiled right.
So I knocked off the IHS, except my temps are exactly the same. I've tried multiple mounts, and used silly putty, and electric tape to try to get a more stable mount with the 7000B. It seems that no matter what I do at this point I can't bring my temps below 60c. My lidless Venice ran everyday at 2.8/1.6v, and never once hit above 50c.
There are a couple of things. When I took off the IHS I completely tore off a capictator from the core. The chip still works, but something tells me that broken capicatotor is causing more voltage to be sent cpu. This would explain the high temps, and that fact that the 7000B "seems" to making good contact with the core. I can't be to sure however, and after 6 hours of testing I'm to tired to even realize it anyway.
The chip has potential too. I got a 3.0ghz validation screen just before 80c temps crashed the system. :(
What I need for you guru's is someone expriences with the 7000B, and a lidless X2. Also if the broken cacpitotir is the cause of my problems. I'm really thinking that the problem is just I can't get a good mount with the cpu.
I think the best option is to just replace the HSF, but the lack of bolt-through heatsinks limits my options. I'd love some help.
