DFI PC Health Status :toast:
DFI Memory OptionCode:CPU Core Voltage :
LDT Bus Voltage :
ATX +3.3V Voltage :
ATX +5.0V Voltage :
ATX +12V Voltage :
Chip Set Voltage :
DRAM 2.5V Voltage :
ATX +5VSB Voltage :
Battery Voltage :
CPU CORE Temperature :
PWM AREA Temperature :
CHIP SET Temperature :
CPU FAN Fan Speed :
FAN 2 Fan Speed :
CHIP SET Fan Speed :
There are many more... too lazy to check them allCode:Command Per Clock (CPC)
Auto
Enable
Disable
CAS Latency Control (Tcl)
Auto
1.5
2.0
3.0
3.5
1.0
2.5
4.0
4.5
RAS# to CAS# delay (Trcd)
Auto
00 Bus Clock
01 Bus Clock
02 Bus Clocks
03 Bus Clocks
04 Bus Clocks
05 Bus Clocks
06 Bus Clocks
07 Bus Clocks
Min RAS# active time(Tras)
Auto
00 Bus Clock
01 Bus Clock
02 Bus Clocks
03 Bus Clocks
04 Bus Clocks
05 Bus Clocks
06 Bus Clocks
07 Bus Clocks
08 Bus Clocks
09 Bus Clocks
10 Bus Clocks
11 Bus Clocks
12 Bus Clocks
13 Bus Clocks
14 Bus Clocks
15 Bus Clocks
Row precharge time (Trp)
Auto
00 Bus Clock
01 Bus Clock
02 Bus Clocks
03 Bus Clocks
04 Bus Clocks
05 Bus Clocks
06 Bus Clocks
07 Bus Clocks
Row cycle time (Trc):
Auto
07 Bus Clocks
08 Bus Clocks
09 Bus Clocks
10 Bus Clocks
11 Bus Clocks
12 Bus Clocks
13 Bus Clocks
14 Bus Clocks
15 Bus Clocks
16 Bus Clocks
17 Bus Clocks
18 Bus Clocks
19 Bus Clocks
20 Bus Clocks
21 Bus Clocks
22 Bus Clocks
Row refresh cyc time(Trfc):
Auto
09 Bus Clocks
10 Bus Clocks
11 Bus Clocks
12 Bus Clocks
13 Bus Clocks
14 Bus Clocks
15 Bus Clocks
16 Bus Clocks
17 Bus Clocks
18 Bus Clocks
19 Bus Clocks
20 Bus Clocks
21 Bus Clocks
22 Bus Clocks
23 Bus Clocks
24 Bus Clocks
Row to Row delay (Trrd):
Auto
00 Bus Clock
01 Bus Clock
02 Bus Clocks
03 Bus Clocks
04 Bus Clocks
05 Bus Clocks
06 Bus Clocks
07 Bus Clocks
Write recovery time (Twr) :
Auto
02 Bus Clocks
03 Bus Clocks
Write to Read delay (Twtr):
Auto
01 Bus Clock
02 Bus Clocks
Read to Write delay (Trwt):
Auto
01 Bus Clock
02 Bus Clocks
03 Bus Clocks
04 Bus Clocks
05 Bus Clocks
06 Bus Clocks
07 Bus Clocks
08 Bus Clocks
Nice bios... oskar wu :toast:
