The old versions have winbond UTT on them, de newst tccd/tcc5.Quote:
Long time bump, but:
I can comfirm that the Samsung OEM PC3200 is in fact, TCCC on a Brainpower pcb. I would take pictures, but my camera batteries have neough juice for one picture per charge. It was purchased OEM from a local computer store for $38 per 512. The serial number is:
250330009 CS
64*64D40SAM32*8 B6U808
512MB DDR400
WARRANTY VOID IF REMOVED (oops)
Im pretty sure oem's usually use whatever is availiable and cheapest at the time.Quote:
Originally Posted by Bbq
Are these: http://www.sallandautomatisering.nl/?pid=872Quote:
Originally Posted by The Runner
The same as the ones mentioned in the startpost by The Runner?
No, the ones you mention are TWINX1024-3200C2PRO. And depending on the revision, they use different IC's, although I think the pro and non-pro did use the same IC's on the same revision.
It's hard to tell from that link that they are offering Revision 4.1...
OK...second try,
Does anyone know if these: http://www.pcgate.nl/product_info.ph...oducts_id=3816
OCZ modules have Samsung TCCD? :)
I think i found the exact same modules just without any fancy led displays
http://www.icomputers.nl//product_de...776&SSS_ID=665
What drive strength/data drive do TCCD like?
Those have 100% Samung TCCD with a brainpower PCB :banana:Quote:
Originally Posted by Da_maniaC
There are two completely different PCBs used in the ICs. One is sort of brainpower, but not exactly.Quote:
Originally Posted by The_Hardstylez
Plaease add Team Xtreen TXDR512M600HC25
Heat spreaders removed, confirmed.
Nobody seems to update the list...
Corsair CMX512-4400C25 - TCCD on Brainpower - confirmed ...
TCCD like "weak" ;)
Confirmed a LONG time ago :)Quote:
Originally Posted by dracoonpit
The Official Corsair IC Inquiry Thread
You gotta know, wired :d
G.Skill F1-3200DSU2-512LA with TCCD 431 inside ;)
superpi 1m maximum: 365 mhz @ 3-5-5-5 cr 1t @ 3,16 v cooled by air...
validation is 388 mhz @ 3,23 v
prime rocks around 345 mhz @ 3-4-4-5 cr 1t @ 3,15 v
i have 2 pairs of them the next pair i will testing next time...
this sticks dont like much volt my geil one tccd loves voltage to 3,58 volt for validation with 363 mhz @ 2.5/4/4/5
