maybe stick to 5ghz
maybe stick to 5ghz
Very nice Loud ,this is how we all improve our times,pushing each other
http://www.sendspace.com/file/gmyl0h
but try to find your best CW manually...
Tried original sammie HCH9 again with tight timings under 2666 strap.
Tommi_Vercetti - 6:01.453 - 49x102 - 1361.00MHz - 9-12-12-15-105-1 - ASROCK Z87-OCF -Sammie Original DH0-CH9 4GB x2- 2.2v - CPU H2O/RAM AIR
http://i.imgur.com/3PqV0b2.jpg
So had 3 lrts of ln2 left and thought I give 5ghz another go,learn t a fair bit from my last few runs.Had a few better then this but was loosing efficiency by the end,may need fresh install
bullant - 5:55.406 - 50x100.6 - 1400MHz - 6-10-6-24-64-1 - OCF - GSkill Pis 2x2GB/PSC - 2.18V -CPU-25,Memory Ln2 -160
http://s13.postimg.org/kys6gl4d3/fyuop.png
Awesome run again Bullant.
Thanks Hiwa,had a few better ones when I 57xxxx available real memory but was getting some shut downs about loop 14,they were looking like 55.2--,will keep working on my waza
Ananerbe - 7:21.875 - 39x102.6 - 1368MHz - 9-12-12-12-105-1 - M6E - Samsung HCH9 - 2.25V -CPU/Memory -Air
http://i.piccy.info/i8/25fe3d56a77df..._07_41_500.jpghttp://i.piccy.info/a3/2013-09-22-14...72x354-r/i.gif
Crazy run, bullant, nicely done! :up:
Bullant you're the monster of Pi )))
MaJ0r - 7:21:640 - 37x108.13 - 1405 / 9-12-12-21 - AsRock OCF - Team Group 2800CL11 2x4GB Samsung - 2.05V - cpu@air/mem@air Core i5 4670K
http://i.piccy.info/i8/88100f0ca970d...ot0032_500.jpghttp://i.piccy.info/a3/2013-09-22-20...00x313-r/i.gif
Does anybody can make a video how to do right copy waza? Seems I can improve my result at these frequencies but I really don't know how. Maybe I have to reinstall OS or try tight timings, if you have some ideas about it please let me know )
I do the CW like this: http://www.youtube.com/watch?v=njAKckLyrEk
Note how the more times you make the last copy, the less PF seems to be occupied by win processes. This helps to boost the "available" and "system cache" numbers.
Alternative video is here major
http://www.youtube.com/watch?v=QPhmuUlzDDA
Thanks Sam. In the video the size of 1.rar was 1.96GB, wasn't it? How many times you copied this file?
P.S. I've been doing CW this way: did 31 copy of 3d mark 01 at disk D, then moved them to disk C, waited about 30 second and after that started superpi 32m. But SuperPi there is at ramdisk, so I think I've been doing something wrong )
I hope you will understand my bad English ))
Major all my runs are like you said 31 X 01 D to C one time then i check available and system cache when available stops run Pi
Tapakah way is also 100% correct he is trying the old way and he checks superPi mem usage when its about 200/250 ( continuing copying file) he close task manager and wait
everyone has different way,first file is made with fsutil
fsutil file createnew D:\cd 647168000
(1000*1024*632)
this is to make 632mb file
rar first 2 X 632mb and try
i remember a friend zip the 3 files each time he wanted to run 32m and delete the created file each time, this way you will have higher system cache.
My video is to show how to prepare CW..
here you find my post with another link to italian forum, i explain all about how to 32m
http://www.xtremesystems.org/forums/...=1#post5203428
MaJ0r - 7:20:860 - 39x102.61 - 1436 / 9-12-12-21 - AsRock OCF - Team Group 2800CL11 2x4GB Samsung - 2.1V - cpu@air/mem@air Core i5 4670K
http://i.piccy.info/i8/e90a7e272fbd9...ot0002_500.jpghttp://i.piccy.info/a3/2013-09-23-09...00x313-r/i.gif
25L later. . . .
http://i.imgur.com/3RgnSQg.png
New cpu made little to no difference, must be the memory, guess it is time to start testing the other good kits.
Sooooo humid as well tonight, I have no idea how you guys in wet environments manage. Was only able to bench about an hour or so before everything was wet, oh well there's always tomorrow.
tRDRD = 5!:wave:
John Lam - 5:57:922 - 49 x 102 - 1429 MHz - 9-12-12-17-108-1 - ASRock Z87-OCF - Corsair Dominator 2666 C10 - 1.98v - All Air
http://www.hkepc.com/forum/attachmen...fc5ee2f157.jpg
http://www.hkepc.com/forum/attachmen...6828eb30bf.png
will max my samsung on this chip :
http://www.youtube.com/watch?v=VXnDwcTPBfI
nice john :) getting better
Thank you Splave222 !!
