that is weird shi(f)t, never seen that happen on 1204, 1303 or 1485, have you tested with other known good components?
PS2 keyboard FTW !! I loose both USB2.0 ports (near the PS2 connector) if I push the timings of my rams to 6-9-6 (above 1233Mhz) CL7-9-7 they continue to work... tighten up the USB ports are inop
Can someone show me a link for turbo v(evo) that working properly with m4e?
yep no boot drive detected... it goes into bios all the time...
Hello everyone.
I just installed a i7-2600k Q12X ES D0, and by measuring the CPU temperature is showing 1C-5C. Does anyone know how to fix this bug?
The program is showing both Real Temp or Core Temp.
http://www.abload.de/img/semttulo1n8o.png
Temp Amb. 18ºC.
Ur cpu-z and realtemp are kinda old. Pls google for the latest versions.
Hi guys! Got 2600K yesterday and M4E the day before. Just finished reading whole thread and I'm overwhelmed with info. :confused2
A few questions:
Can you post another link, this one doesn't work?
Where do I get Mem-TweakIt? :D
GOOGLE is your friend. :up:
I just got this board as well. I'm Linx Stable at 4.9ghz at 1.4v. 5ghz will run, but fail 3 tests into a 20 test loop. I have very little configured. I'll have to do a run through and see what I can change.
I love this board, it's excellent. :up:
One question (for now), should I move from 1303 to 1485? Will that possibly net me that extra 100 mhz I need for 5ghz stable?
I'm lazy and copy and pasted. Laziness wins in this case. :D
Glad you found it. :up:
EDIT:
Does anyone know of a walkthrough to get an android phone working w/ the RC bluetooth connection? I tried this:
http://www.asusrog.com/forums/showth...luetooth-guide
I cannot find the Program under the Maximus IV, only under rampage extreme III. I tried that and it won't work. I've been able to install RC Bluetooth on my EVO 4g, but even when I try to install the bluetooth driver, it will tell me to turn on the bluetooth and that always fails. I also updated the bluetooth driver and I had the same issue.
Thanks! :up: Let me try to return the favor. :)
You can DL from the support site, or from the main site, or manually select download on M4E page, then choose Android as OS, and you'll get applications for Android, Symbian and Windows Mobile.
Thanks.
Here's the trouble. I have RC Bluetooth on my Evo. If I install the bluetooth driver and application in Win 7, it never initializes. It'll say something along the lines of "bluetooth not found, or something along those lines...
Now I am even having issues installing the driver. I get this message:
http://i56.tinypic.com/fxb995.jpg
I click OK and the driver sits and sits. Then the message appears again.
Any ideas?
I'd love a walkthrough? All the explanations I see leave out a lot of info. I basically want someone to hold my hand as I just cannot figure what is wrong, lol. I guess that's the point of a walkthrough, right? :D
Edit:
The phone will see the PC and can pair, but does not connect. :shrug:
A quick question: I recently rode my SB, I'm trying to stabilize at 4.5GHz, but when he begins to stress the processor (LinX, after 2mins), the multiplier drops from 45x (100 x 45x) to 37x (3.8GHz), anyone know why? What option have to disable in the BIOS? I want to make the amount I put in the BIOS, do not want this to happen. Thankful who reply!
