Update.........
http://i50.tinypic.com/fdy4hj.jpg
Update.........
Just a quick question.
If you edit the clocks for the 3D mode in BIOS using RBE, and these clocks are going to be ABOVE the CC lmits, then flash this BIOS, will it work fine?
i5 750 @ 4,2
4gb ocz platium 2000mhz 9-9-9-31
2x HD 5850 in CF with MSI BIOS @ 975 / 1200, 1,225v
http://img29.imageshack.us/img29/353...l25kvantag.jpg
9.12 seems to be an improvement. :up:
http://img193.imageshack.us/img193/1469/912c.png http://img193.imageshack.us/img193/912c.png/1/w1288.png
So... ATI already released a Hotfix... :O
http://support.amd.com/us/kbarticles...912Hotfix.aspx
LOL
yah
9.12 is NOV 24th (8.861-091124a) 092500C (Sapphire) and 092499C (Official)
http://img697.imageshack.us/img697/3221/912.png
and
9.12 hotfix is DEC 14th (8.682.2-091214a)
http://i82.photobucket.com/albums/j2...g?t=1261092953
Hotfix also has Eyefinity working on Crossfire
indeed it does
Still on leaked 9.12 8.14.10.0716 beta drivers. Tried higher cpu clock but W3570 seems to hang in CPU tests at 4723Mhz for Vantage but fine for 4753Mhz 3dmark05 at least (max 3dmark05 benched on W3570 HT On H20 is 4803Mhz).
My first bench with GPU clocked at 1000Mhz @1000/1275 :D
System:
- Intel Xeon W3570 3847A696
- EK Supreme LT 1366 / FESER 480 / MCP655
- Asus P6T6 WS Revolution
- Gskill Trident F3-16000CL9T-6GBTD
- 3x Sapphire HD5870 CF flashed Asus bios 9.12 (8.14.10.0716 (3x hd5870))
- 750GB Samsung SATA
- Pioneer DVR-217 DVD-RW
- Corsair HX1000 PSU
- Dual Boot - WinXP Pro SP3 (nLite fully updated) with Vista Theme & Win7 Ultimate 64bit RTM
- 3D Vantage @1000/1275 = 36,703 http://service.futuremark.com/compare?3dmv=1696745
- 3DMark05 @1000/1275 = 42,414 http://service.futuremark.com/compare?3dm05=5088120
http://fileshosts.com/intel/Asus/P6T...ealtemp_tn.png
http://fileshosts.com/intel/Asus/P6T...5_42414_tn.png
Clocked my HD5750 to 800/1200 without unlocked bios. Can i use the HD5770 bios for my HD 5750 ?
BTW im waiting my HD5850 but still .. im WAITING !
Asus 5870 @ 1.25 volts
Stock cooler
9.12 Hotfix
http://img14.imageshack.us/img14/8752/48351541.png
Hey guys, how can i overclock both cores of the 5970?
I'm using MSI Afterburner or ATI GPU Tool. both only clock the first core.
thanks Chad :)
CPU @ 4.2GHz
Mem: 7-7-7-19-1T
Catalyst 9.12Hotfix
3DMark Vantage
ORB - Compare
[hwbot] result detail. - hwbot.org
CPU @ 4.4GHz
GPU @ 1000/1220 @1.252V
http://img12.imageshack.us/img12/923...ucovantage.jpg
3Dmark 06
CPU @ 4.2GHz
GPU @ 950/1200
ORB - Compare
http://img696.imageshack.us/img696/4...1200mark06.jpg
Stalker: Call of Pripyat
CPU @ 4.2GHz
GPU @ 980/1200
2048x1152, DX11, ultra, HDAO=off
57.3/61.7/60.6/42.5
2048x1152, DX11, ultra, HDAO=ultra
44.7/56.1/53.9/45.8
Crysis
CPU @ 4.2GHz
GPU @ 980/1200
1980x1020, v.high, DX10, AA=off
65.565FPS
Streetfighter Benchmark
CPU @ 4.2GHz
GPU @ 980/1200
2048x1152, ultra, AA=off
31,918 / 432.41FPS
Unigine DX11 Heaven
CPU @ 4.2GHz
GPU @ 980/1200
2048x1152, DX11, v.high, AA=off, tessellation=on
70.9FPS / 1725
DIRT II
CPU @ 4.2GHz
GPU @ 980/1200
86.2FPS
This is my best shot with the Official 9.12 (not Sapphire one nor Hotfix one)... i can't go higher...
Intel i7 950@4.6GHz HT On, Evga X58 Classified E759, CFX HD5870 1000/1350. Catalyst 9.12, Windows 7 64bits 30456 / 28139 / P29842
http://img7.imageshack.us/img7/8876/...2con950.th.png
Soooo close to 30k...
BTW... The 9.12 Hotfix, i have an issue... seems like my clock and temps in 2D mode of one of the vcard, the second one, just not work, it shows 0 in all (temp, gpu and mem clocks) only start detecting when change to 3D mode, then go back to 0 when return to 2D. weird :/ Same :banana::banana::banana::banana: happened to me with 9.11 Beta 5...
@kPablo great Vantage score :)
How safe do you say it will be to overvolt the 5970?
My environment is very cold mostly -1 to -10.
When I did 1000/1220 @ 1.25V at heavy load, temps of the GPU never got above 60c.
Thanks.
*honest to God I did not wrote the same thing.. twice! :shrug:
*double post - sorry*
MORE update.......
http://i50.tinypic.com/wv1vgm.jpg
Yesterday managed to break 20k vantage. But i ll post a screen when i find the max clocks for stock voltage :)
Someone who can modify Asus Smart doctor to recognize HD5850 flashed with Asus HD5870 bios?!
When I flash my Sapphire 5850 with Asus 5850 bios everything is ok, but with Asus HD5870 bios Smart doctor gives me an error "Can't find video cards information" :mad:
I need more vcore above the MSI Afterburner 1.35v limit.
Now with Asus 5850 bios and 1.4v I can get 1123MHz GPU, but RAM works better with 5870 bios:
http://img191.imageshack.us/img191/6...9821851.th.jpg
What is the Xcode thing that Saphhire have in their DL page? The name is:
"Catalyst 9.12 Windows 7 Xcode (64-bit) for Windows 7 64-bit Edition" 29.16MB - Release date: December 21
Also they have a set of 9.12 dated December 21.
are the drivers improving Crossfire performance much? I know the first reports of 5870 Crossfire setups was disappointing.
WITH 9.12 my xfire 5870s have improved
http://service.futuremark.com/compare?3dmv=1699858
My XFX 5870 ( @ASUS BIOS), runing at 950 on GPU and 1250MHz on Memory, stock voltages.
http://img63.imageshack.us/img63/8220/9501250.png
Stable in FurMark, and Games.
LOL at 82% fan speed. For benchmarks is fine but i cant even think about gaming with a Hoover next to my left ear. Max i got with 1.162v is 980/1300. I ll test 990 today.
