beautifully done seba and kuti :up:
Thanks man!
:D
Not the greatest compared to some, but hey, it's my first water cooled setup.
http://www.blamstorage.com/upload/fi...1228_thumb.jpg http://www.blamstorage.com/upload/fi...1237_thumb.jpg
Click to enlarge.
Ok painted the inside and re-did the loop a little.
http://i206.photobucket.com/albums/b...k/100_2196.jpg
Ilkka`s "Dubbel"
http://www.aijaa.com/v.php?i=4530347.jpg
http://www.aijaa.com/v.php?i=4530360.jpg
http://www.aijaa.com/v.php?i=4530374.jpg
http://www.aijaa.com/v.php?i=4530389.jpg
http://www.aijaa.com/v.php?i=4530394.jpg
Not happy yet, ... Oh, maybe newer :)
Gigabyte 3D Aurora 570. Dual loop, twin D5s and twin EK res 250s.
EK Supreme on an E8400 (waiting for a deal on a Q9650) and Ek nb/mosfet blocks on a GTX360 with Pana ultras. EK VGA Supremes on 4850s with a BIX240 up top with a custom aluminum shroud and Scythe Ultras.
http://i307.photobucket.com/albums/n...5/IMG_0075.jpg
http://i307.photobucket.com/albums/n...IMG_0052-1.jpg
http://i307.photobucket.com/albums/n...5/IMG_0051.jpg
http://i307.photobucket.com/albums/n...5/IMG_0061.jpg
http://i307.photobucket.com/albums/n...5/IMG_0057.jpg
TopFuel1471
:up: It`s monster PC!
Malik,
What fans are those?
Xigmatek ( orange ), Nanoxia ( green ), Noiseblocker ( blue )
Wow.
I'm totally excited as all heck to start watercooling ... only a matter of time.
I figure my first loop for my ATCS 840 will run me about $270 or so. Then I'll throw in a second loop for the GPUs later.
You guys are an inspiration.
Your build are always on point Malik. I love them.
Man I wish I could build a new PC every month!
My 2 versions.
Here are my most recent ones - I'm still not happy with the red coolant (Pink TBH) My next setup when I switch to i7 and things will change pending the costs!
http://i39.tinypic.com/14e5bsy.jpg
http://i42.tinypic.com/1199jqt.jpg
http://i41.tinypic.com/2emo9j6.jpg
Cable Management - :) http://i43.tinypic.com/33zg32w.jpg
Rebuild my rig. This time I used Bitspower fillports with barbs on both sides instead of putting the tubing through holes in the panels with sharp edges. Much better. Still I have to extend the wires of the UV bars.
http://recore.info/images/cosmos1.jpg
http://recore.info/images/cosmos2.jpg
http://recore.info/images/cosmos3.jpg
Another LC system from PL ;)
http://img93.imageshack.us/img93/3917/dsc1842.jpg
http://img11.imageshack.us/img11/9558/dsc1824axs.jpg
http://img11.imageshack.us/img11/86/dsc1831x.jpg
http://img11.imageshack.us/img11/7872/dsc1884.jpg
http://img11.imageshack.us/img11/3028/dsc1893.jpg
http://img204.imageshack.us/img204/2520/dsc1814.jpg
All pics in gallery ;)
Looking good there seba :up:
Hi all...first post after months of looking at all the awesome builds. Here is my modded alienware p1 case from an old system. This was my first ever pc build as well as watercooling experience. Hope you like......:)
Specs as follows:
- i7 920 DO (oc to 4ghz)
- Kingston hyperx 1866mhz (oc to 2000mhz)
- Gigabyte x58 UD5
- Gainward gtx 295
- Be Quite! Dark Power Pro 1200watt (serious overkill imo but want to keep future upgrades possible)
- Seagate Barracuda 1.5tb x3 and 500gb x1
- some pinoeer bluray reader etc...
- Hanns G 28"
WC spec:
- XSPC Dual DDC Bay Reservoir with ddc+1 ultra 18w
- ek supreme acetal
- ek gtx 295 block acetal
- black ice extreme 480 rad
- 3/8" id 5/8" od green/uvgreen xspc tubing
- primochill anti kinks - green with size as tubing above
- primochill ice clear with liquid utopia fluid added
- push pull on rad using xigmatek - orange ones
- zalman fan controller
- full ek gigabyte x58 kit for mb.
http://i25.tinypic.com/2s18wnb.jpg
http://i29.tinypic.com/bfku8i.jpg
http://i26.tinypic.com/o85d14.jpg
http://i30.tinypic.com/34xkh8n.jpg
http://i29.tinypic.com/esok8k.jpg
http://i32.tinypic.com/116hp2f.jpg
http://i25.tinypic.com/6rhh12.jpg
i really like that set up in the alienware case. Great job. Just paint the inside black and it would be killer.
Little update from me and my DragonGirl project, working on cable management now :)
Hardware:
- X6800 (@3.6 Ghz)
- GSkill 2*2GB @ 1080Mhz
- ASUS P5Q Deluxe
- MSI 8800GT
- CM Silent Pro 600W
WC:
- XSPC Reservoir with ddc 18w
- EK Supreme Acetal
- D-Tek Fusion GTX
- Swiftech MCR320 QP
- 1/2" to 3/4" XSPC UV tubing
http://media.snimka.bg/3751/013756721-big.jpg
http://media.snimka.bg/3751/013756723-big.jpg
http://media.snimka.bg/3751/013756724-big.jpg
