Does same happen with only 6GB memory or non-raid SATA disk array ? Does it happen at lower cpu clocks i.e. 4Ghz or 4.2Ghz ?
Only problem I can think about is getting the x21 multiplier working with Windows 7. You might need to download Real Temp 3.30 or an application called ready boost to get it going right.
Otherwise, the board works fine for me :)
Win7 multi issue is fixed with new beta BIOS 0724. I've checked with Win7 RTM.
so no dfi old diseases like ... "will not power up" , suddenly crushes , etc ... ?
Nope, no "will not power up" , suddenly crushes , etc , here. My setup has been running rock solid in several weeks now, but I'm keeping it at summer-OC @4GHZ(211x19) 1.15v 24/7 for now.
Even tho i didn't need/use x21 for now, but my only concern has been x21 multi, and it is working just fine with the new BIOS, now :)
http://img199.imageshack.us/img199/30/superpi32m.th.jpg
The next fun will start at the autumn, with keeping this hot babe cool enough @4.4GHZ 24/7 on air-cooling ;)
ok thank you :)
i just recently burned evga classified e760 and had no warrnty :(
so i looking for a solid mobo with great overclock potencial , features and tweakable bios ... so far DFI UT X58-T3EH8 answers to all of those.
i have great cpu ... I7 920 (batch 3849B203) that doing 4.7 on air and 5.2 on dry ice , great memory sticks ... mushkin redline 1600mhz cl6-7-6-18 and great air cooling ...Prolimatech Megahalem + panaflo 120X38 medium.
all is left is an awesome mobo :D
Did somebody try the new bios? i'm havin' problems. they're the same as the 6/19 bios, but more evident. Can't get the cpu stable >3.6ghz and uncore >3000mhz
I keep getting this thing where prime95 LargeFFT just turns off, like it restarts the computer with no BSOD, yet when I do the testing for core voltage, it doesnt reboot?
Any ideas guys?
ChaosMinionX
Vcore?
Temp PWM?
1.4375v on Vcore.... PWM temp is almost always under 60C
I could try it only 6gb to see what happens, only get about 1hr a day to play with it. It didn't do it at 4ghz but I will try 4.2ghz now...
I don't see why the raid would matter.
This is the first computer I have that will stress test stable but idle it BSOD's :ROTF:
Bha, i'm gonna hate this mobo
I don't have the UT but the DK version... finally got the 21x MP working under load :D
A real DFI board lol... you have to get to know it to let it work for you :D
any one else experience this kind of problems?
also , any one experience overclock crushes that couldn't be fixed by taking of the battery or restrating bios by jumper?
and the only solution was takin the powering of the PSU and disconecting the 24pin cable ... like in the old dfi boards ...
So i'm the only one that can't get the pc stable with uncore >3000mhz?
Ah, one question. Is there any option to save energy (C1E-Cstate) without losing stability?
do not use C1E - it's 100% crashing for idle. may be it dropped Vcore and x22 multiplier for a core
my settings 200*21 for save energy:
and Get:Code:Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Enabled
Thermal Management Control: Disabled
EIST Function: Enabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Channel Interleave Setting: AUTO
Rank Interleave Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: 1N
CAS Latency Time (tCL): 7
RAS# to CAS# Delay (tRCD): 7
RAS# Precharge (tRP): 7
Precharge Delay (tRAS): 19
REF to ACT Delay (tRFC): 60
Write to PRE Delay (tWR): 10
Rank Write to Read (tWTR): 6
ACT to ACT Delay (tRRD): 6
Row Cycle Time (tRC): 30
Read CAS# Precharge (tRTP): 6
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: Auto
CPU VID Special Add Limit: Enabled
CPU VID Special Add: 109.92%
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.620v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.31
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Enabled
1 core Max Turbo Ratio: 22x
2 core Max Turbo Ratio: 21x
3 core Max Turbo Ratio: 21x
4 core Max Turbo Ratio: 21x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: 4.8GT/s
CPU Base Clock (BCLK): 200 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: 8x
UnCore Frequency: 16x
CPU Spread Spectrum: Disabled
IDLE - 200*12=2400MHz Vcore=1.056V, CPUvtt=1.28V
and full load:
http://img145.imageshack.us/img145/5...hrprime.th.png
Thanks guys :)
@Factotum, 110% gaves me a too high vcore, what can i do? can i decrease it?
I'm going to try the latest beta BIOS today but I do have a question about my setup. Specs are in my sig. I'm having a hard time getting 4.0GHz to be stable. I'm running 20x200, RAM at 1600, etc., basic 20x200 settings. For my setup to run Prime at all it requires 1.32vid and 1.32vtt. PLL I have at 1.85, everything else is default or auto. 4.0GHz shouldn't be difficult to get stable, suggestions?
