No, got sidetracked with a phone call.
All 9 shots sent you bastage!:rofl:
Hmm--how expensive would a setup be now-a-days? With an ATX board--I can't use eATX.
Guys since the Iwill DH800 uses the same ICS
has anyone tried clockgen ?
In seven different languages, probably. These boards are exceptionally resistant to overclocking by any means.
Since every ones going to figure out what I have been upto, I will post in the open.
Past couple of days, I have been working extremly hard trying to edit / unhide options in the intel based BIOS.
But i have not had any luck.
- Below I will give you the reasoning
Please see screen shot
This is visiable to us guys,
http://www.ibby.co.uk/xs/amibcp.JPG
As you can see it has fields pre filled in, some are user selected others are "refresh only"
the ones I was intrested in were
"FSB" "Freqancy"
http://www.ibby.co.uk/xs/offset.JPG
After days atlooking at the code, I managed to figure out how to change the headings, but was unable to change the field we most needed (Access / Use)
More hunting, and looking at the code and comparing code whilst i was changing settings, made me belive and has been confimed by another source that if the settings are not in AMIBCP, then you can not change or edit any settings. - Becuase the orginal coder has not put the options in.
(well you cant access them with a high level encoder)
And most people will ask the question, why not put the settings in.
Well in plain terms the settings can just not be put in. they have to be coded to the chipset/ics cpu and other resources.
The BIOS nowadays are coded diffrently with a higher based software encoder, which is not avalible to us.
Iam not giving up, but iam sorry for letting the team down.
I think for any part
(injecting the microcode into the BIOS is probably going to be the easy bit)
However ...... does the Aopen board meet the regulations of PMW?
The issues here I belive is, we need to make the board belive ... that its a 200FSB processor.
without having a board here (Dave) I have afew ideas :up:
I see!
FANTASTIC!
unplug the cord ...and get your number changed now :sonic:
OK, so we've brought in ibby who is good with BIOS's but is running into issues here so i sent a PM to a gentleman who has offerred to help.
I don't want to see him get a 100 PM's from the guys on this so I'm not naming him but it's fair to say that he is one of the best people in our hobby.
IE: If he can't figure this out no one can..;)
Anyone got the Intel white papers on this motherboard?
I had them at one time but they are gone.
Alos any board documentation or links to any of this.
Thanks!
I just saw a SE7520BB2 board for $19!
2GB RAM for $37!
Now to find CPUs and heatsinks! Unless I can rig up a way to stick two old AXP heatsinks on there :idea:
I'm tempted, if you couldn't tell :p: I would think that one of these would easily outdo a couple AXPs and an A64 or two?
Boards at Citrix correct? I just bought 3 last week.
and you need the special HS.. Only place in the world that has them is 19 miles from my house..They charge $25.00 to ship two of them and $20 for the two HS=$45.00/pair
I'm making a trip there in the next week to get more as that way no shipping charge to me and maybe $10.00 to ship to you not $25.00
Yep that's where the board is.
No way to stuff a different heatsink on there huh? Dang, oh well :lol2:
Board and RAM look good and cheap, and the heatsinks (through you if you don't mind) and I have an HD (IDE but it works) and a PSU. Biggest cost is CPUs it looks like, haven't been able to find much.
THE case to put a sammy in is a Lian Li PC62..:up:
Classey, and not bad in price..
It's the EATX version of the PC60:
$100.00
http://www.coolerguys.com/840556007340.html
Old tech now and why it's so cheap..
2-80's front, one rear.. Not enough for todays hot systems but plenty for sammy
If I went with the 1.67 GHz sossamans I could do the BSEL mod to 2.67GHz - if the chips can handle that? I don't know :shrug:
Found them here for $45 each but they are in Canada so I can imagine what shipping would be. Not sure if that is $45 CAD or USD.
http://www.itxchange.com/shop/proces...9Y6598-02.html
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110328758720
He's on the forum under the same name..
$67.00/pair delivered..
PM him and bypass ebay fees for him..
I bought a pair from him.. good seller
He's got more on ebay but at a higher pricepoint now $60 for one + shipping
http://cgi.ebay.com/Xeon-Low-Voltage...QQcmdZViewItem
