Heat sink is warm?
It look's strange.
Heat sink is warm?
It look's strange.
Got an E8600 running for quite some time now, and thought I'd share some results.
I am not unhappy with this chip but it doenst compare to some chips I had in the past, it needs a lot of volts. It's a Q820 with 1.25 VID. System in sig.
Any suggestions for improvement? Would like to hear some.
FSB 440
Multiplier 10
Vcore +375Mv (=1.408v under load)
Vdroop control enabled
PLL volt 1.55v
FSB term 1.15v
NB Volt 1.3v
GTL 0/1 0.61
GTL 1/2 0.61
NB GTL 0.58
DRAM Volt 2.1v
333/1057
http://www.nietbelangrijk.nl/download/file.php?id=3012
hi
I noticed you have some really high fsb on your e8600, how did you manage that, i am struggling to get past 470, you manage 600, dont suppose you could post all your bios settings for me,be interesting to see if it would work for me, i assume this is on air.appreciate it zuker if you can do that.
regs
paul
hi there
3 days ago i ordered mi E8600 from a local shop for 255Euro and today I tested it very fast in SPI 1M on my crappy WC system ...started slowly on lovered vcore 1,168V 4G - sayed wow, gotcha go higher 1,272V 4,5G- thats the way :rofl: , the final clock booted from the bios 500x10 w/ 1,448V SPI 1M stable
stable 24/7 settings I post latter :)
Great Cpu :) mine did 5,3 with cooold air and watercooling and 1.76v ;)
trough 590 max fsb, cold air do much.
Your sensor is "stuck", and will only change if it goes higher. This means one of two things. You're never going over 39C-4-C, or it's realyy running a bit warmer but is still stuck.
Sensors are wonky on these 45nm CPUs. My old E8400 always said it got into the 60s and 70s, but I could touch my heatsink's heatpipes at the very bottom, and it was a HDT design, and I was feeling barely any warmth (yes, it was applied correctly as well as was the thermal material, before the basic and obvious question gets asked). I should have burned myself. I stopped trusting that CPUs temperatures entirely.
I'd wager that if you have a good cooler, go with my first guess. If it's at stock speed, it still might be running that cool.
hallo people!!! :D i wanna give you some results :)
1.072 |400x10 | Q822A435 | 1.1250 | H2O | Asus Maximus II Formula | 41° | Screen KURTZ
4600mhz / 460x10 / Q822A435 / 3A0151 / 1.264V / ASUS Maximus II Forumula / 2x1GB CellShock PC8000 / H2O / KURTZ Screen
5000Mhz / 500x10 / Q822A435 / 3A0151 / 1.360v / Asus Maximus II Formula / 2x1GB CellShock PC8000 / H2O / KURTZ Validator
Do it!
done :D please click over the 'screen' link :D
ps. my chip has 1.125 VID MAX, and 0.935 VID MIN ;)
http://img13.imageshack.us/img13/6452/oce8600.th.gif 4,3mhz multi x10 430fsb
vcore 1.28v xD
nb 1.40v
pll 1.50v
fsb t 1.24v
divisor 3:4 rampage formula x48 bios 803
occt 3hr stables jejejejejje
KURTZ and 0Ro! where did you guys buy your chips at?
for that matter where are the good one being bought at?
im going to be buying one in the next two weeks and would
like to know where people are getting the best batches from.
i know it mostly luck when buying from e-tailers but any info
would be greatly appreciated.thanks
I got mine from a local PC store in Slovakia...that was the first time I had realy luck for a good chip :)
thanks guys.
Still havent learned all, and im sure i can push my E8600 , Q822A435 further, but these are my results so far:
I can do 4500Mhz @ 1.280Vcore stressed.
http://www.thijskramer.nl/tweakersdo...cpuz-thumb.jpg
Max Mhz with 1,45 IDLE Vcore. booted @ 4600mhz, and setfsb right up to 500fsb!
Prolly could have done it with a bit less Vcore aswell, but that was for stability :)
http://www.thijskramer.nl/tweakersdo...0x10-Cpu-Z.jpg
Max superpi, havent done any tweaking at all, mainly due to the fact im not really in to SuperPi just yet, need to read up on some proper tweaking :) :
http://www.thijskramer.nl/tweakersdo...18-4950mhz.jpg
Havent made a pic of it, but highest 1M so far is 4975Mhz, 9.186Sec
Received my Doublesided D9's this week, highest FSB so far is 615. But the DFI P45 T2RS+ is most deff a challenge, and isnt very forgiving when it comes to all the settings, they need to be spot on.
Hopefully i can get 5Ghz to 1M , and validate 5100Mhz :)
VID = 1.0250 btw ( according to coretemp )
not bad dude :D
Heres mine i just got.Its set at 1.2v in the bios.
http://img.techpowerup.org/090617/8600.jpg
I'm gonna have a twiddle with it later and see what it will do.I am on water cooling,i expected the temps to be a bit lower but *shrug*
Edit- 4.5ghz at 1.32v set in bios-
http://img.techpowerup.org/090617/cpuz.jpg
http://valid.canardpc.com/show_oc.php?id=588279
http://img.techpowerup.org/090617/4500.jpg
Ti66er
Got this chip the other day.
VID = 1.1125v
http://i720.photobucket.com/albums/w...00VID11125.jpg
Max boot and SS on air @ 1.552 vcore (idle)
5062 MHz
http://i720.photobucket.com/albums/w...Hz1552vair.jpg
Max SPI 1M on air @ 1.552 vcore (idle)
5035 MHz
Batch CryptiK?
435 of course :D
I wish it was a Q822A435, I have been trying to find one of those for awhile now without luck, I'm still trying. Kurtz if you ever want to sell yours, please let me know.
My chip is a Q820A722.
