just ordered my pII since i was falling so fast on the list :D anyone know a board that will quintfire my 4670/4850 1gb/4870/4870x2 ;) lol naw but on a real note the 4870x2/4870 combo is gonna make some noise next week =)
Time to get back into first 5!
http://img3.imageshack.us/img3/3812/3dm0622586by3.png
http://service.futuremark.com/compare?3dm06=9934231
Score - 22586
SM2.0 - 8282
SM3.0 - 11590
CPU - 5967
Phenom II 940 on AIR !!:D
HD4870 CF 850/1050 AIR Stock coolers!
Finally CF is back in my RD790 ;)
nice light but after next weekend you will have to do it again ;) shooting for 24/25k 2x 4850's :D
way to climb the charts lightman
*updated*
a little fix needed in this
3 cdawall 8800 GTS 512MB 800/1080/1960 - Amd PHII 940 3913mhz 16668
should be phenom II 945ES
soon Im going to be off the top 5.........I sure gave you guys a run for your money though, and Im surprised Im still there:cool:
Well, you already know I am intrigued;). I am going to go for a nice single 4850 score tho. Here is my best single so far.
http://service.futuremark.com/compare?3dm06=9924498
http://3800z24.info/Phenom/Deneb/XP3...0-800_1180.JPG
Time to update my score
Cracked 23k
3DMark06 23044
SM2.0 score 8509
SM3.0 score 12298
CPU Score 5600
http://service.futuremark.com/compare?3dm06=9975682
Phenom II 940@ 3.922Ghz
M3A79-T
CFX 3x 4870's 780/1000 512
4GB (2x 2GB)@1130
Vista Home Ed. 32bit
Cat 9.1
http://i231.photobucket.com/albums/e...r/TopScore.jpg
:up:
Here is a revised score. I lost my resistor for my Mod...I will have to go back to the Shack. I modded the bios to work with 9.1 so I could raise MEM a lil more. still tweaking.
http://service.futuremark.com/compare?3dm06=10007037
Phenom II 940 4ghz-2600HT-2600NB
4850 800mhz-1200mhz(2400)
4850 665mhz-1150mhz(2300)
M3A79-T DLX
OCZ 2x2GB 1066mhz
H2O
Cat v9.1
http://3800z24.info/Phenom/Deneb/XP3...NB_x2_4850.JPG
Nice score there Charged!!!! Nice stepping you have there, you got lucky,,yours 0850BPMW.......You got the letter "M" :up:, they will OC better
Thanks, I am working on a doing DICE run soon (anyone from ohio near dyton ish area wanna join?). I want to get the other card tweaked and modded first. I have another 4850 that just came in tonight. I am testing it right now. I will try a Tri way this weekend hopefully. Any one notice any difference going from 2 to 3 cards?
Just got a new 940BE to replace my old 9950BE..!!
Only had it here for few hours, this is what I got so far...!!
And yes I have got the same stepping...LOL... even though I Copied and pasted the format of your specs to overtype with my own, I actually have got the exact same stepping... my last 5 digits of S/N are: 80294
Phenom II 940 3.8Ghz-1800HT-2200NB ( CACVC AC 0850BPMW )
2 x 4850 CF 700/1150
ASUS M3A79-T Deluxe
G.Skill 2x2GB DDR2-1066
H2O
Cat v9.1
Win7 Beta
Compare:http://service.futuremark.com/compare?3dm06=9996881
http://i91.photobucket.com/albums/k2...l/3dm0620k.jpg
Yea bump up your NB and HT, we have same mobo, cpu and 4850's here is mine
http://service.futuremark.com/compare?3dm06=9813912
http://img6.imageshack.us/img6/1892/...enom940ri8.png
Bump me up a couple more places if you dont mind MSI.
This is about as good as it gets with the 940's I have, but Ill have a 945 in a couple days and that should carry me up into the top 5 anyways.
940@3900mhz NB@2600mhz
HD4870x2 @ 800/950
Win7 64bit
http://i303.photobucket.com/albums/n...Capture2-1.jpg
Thanks guys...!!!
I hope it will get up to where your at Charged havn't had a chance to try much yet, I only got it late yesterday, and hadn't slept the night before (pain problems - long story..!!) by time I got it installed and did some quick OC'ng to get it to 3.8Ghz, and did some stability testing, I had to get some sleep..!!
Going to try for a bit more today...!!
Little better..!! Still got some work to do though..!!
Phenom II 940 3.8Ghz- 2400HT-2600NB ( CACVC AC 0850BPMW )
ASUS M3A79-T Deluxe
H2O
Cat v9.1
Win7 Beta
3DMark Score: 20355
SM 2.0 Score: 8022
SM 3.0 Score: 10016
CPU Score: 5250
Compare: http://service.futuremark.com/compare?3dm06=10011317
Probably as high as I'm going to get with the 4850's...
Phenom II 940 3.83Ghz- 2484HT-2691NB ( CACVC AC 0850BPMW )
ASUS M3A79-T Deluxe
H2O
Cat v9.1
Win7 Beta
3DMark Score: 20717
SM 2.0 Score: 8193
SM 3.0 Score: 10107
CPU Score: 5400
Compare: http://service.futuremark.com/compare?3dm06=10011950
I'll take you up on the offer of settings if thats OK..???
I've tried a few things, I'm fairly certain my RAM won't go to 1200Mhz, I've tried upping the vDimm from 2.1 to 2.3v and still no go..!!
Possibly 3.9Ghz may be able to hold on long enough for a 3DM06 run, not sure.... I usually give it a quick check with AOD stabilty test all tests, if it lasts 30mins then I stop it and run a bench.. if it fails I try upping volts notch at a time...!!
Thats why its taken me so long to get up to 1.53v from 1.4625v..:) One setting at a time, try, fail, try again. fail, try again, fail...........
At 1.53v idle temp was 38C load temp well it got up to 46C before crashing, which most of the time has been 2-3mins into testing...!!
Any suggestions would be welcom..:up:
